Hi folks, just turned on my spare bedroom TV and found this... any idea where to start? Barely 2 years old Plasma TV
Samsung PN60F5300B colorful panel
Re: Samsung PN60F5300B colorful panel
Search the site to find how to run the self test patterns. If the test patterns run OK then it would look like a mainboard faultWilling to help but I'm no expert. -
Looks like mainboard fault. NVRAM. Yes run test patterns on logic board.Did I leave the soldering iron on?Comment
Can you can post pictures of your boards which would be helpful. It may be integrated on the mainboard.
Does this match your set?
https://elektrotanya.com/samsung_200.../download.htmlLast edited by dick_barton; 04-16-2018, 04:55 AM.Willing to help but I'm no expert.Comment
Hi dick_barton... link takes me to a search and not a specific page, so I don't know if it's my set or not. I'll send photos tonight, but it would be great if I could get service manual with schematics so I can troubleshoot. Thank youComment
Haven't had a chance to open up this beast.. but looking at the photos, does anyone with Plasma expertise know if this is a main board / Logic board issue?
Menus seem to be fine, it's just video / audio sources are corrupt it seems. The "Test picture" as part of troubleshooting seems to show the same corrupt image. I'll get the boards pictured tonightAttached Filesif you find these attachements useful please consider making a small donation to the site
Looking at the first picture I would think there's a fault on the mainboard, however I would wait to see what others think since I'm no expert. Have you tried inputting a signal on any other input, ie HDMI, AV, USB?
Is this your control board?Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by dick_barton; 04-24-2018, 12:10 PM.Willing to help but I'm no expert.Comment
Is the circuit board in post#8 the same as in your set?Willing to help but I'm no expert.Comment
here is the beast without a cover on. Jumper 3 4 is labeled NT. Is this the one I'd short to get the test pattern?Attached Filesif you find these attachements useful please consider making a small donation to the site
Just shorted 3 and 4 pins, disconnected the LVD Cable.. and I got the full screen colors, white, then red, green, then gradiant, vertical horizontal diagonal.... so on..
So I guess that says it's the main card?? is it a reflow of bga issue, or Flash chip replacement?Last edited by jason123; 04-24-2018, 04:54 PM.Comment
It generally points to a faulty mainboard if it runs the self test with the mainboard disconnected and the pins on the control board shorted.
It tends to very hit and miss when heating up the mainboard and often if successful is (but not always) short lived.Willing to help but I'm no expert.Comment
It may well be but I don't have enough experience to offer further advice on any mainboard fault.
You could try to do a factory reset or a firmware update to see if updating the memory IC's cures the problem.Willing to help but I'm no expert.Comment
Thanks.. I did the reset and same results. I attempted a firmware update - it reported that there is no valid firmware present (I'm guessing it's because the firmware I have 1006.1 is the same as what it currently has in it)Comment
Suggest you try:
1) www.shopjimmy.com to see if they sell a repair kit for your main board.
2) www.ptselectronicsinc.com to see if they offer a repair service for your board.
3) check eBay and shopjimmy for a price of a new main board.Comment
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by triplefourTV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
tcon is built into mainboard.
Only one cable goes to panel boards.
there is a cable from one panel board to the other that links them.
cost cutting measure that results in us having harder time to diagnose.
removing the link to the second panel board allows TV to stay on with stable backlight but no image.
used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board.... -
by NWArkGuyWell, I will be the first to admit that I screwed up...
In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
I have 2 that I have found and have in my possession. ... -
by KYBOSHI came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
Later I checked for shorts on the panel PCB boards but could not find anything.
When I took a look with the FLIR i noticed the 2 resistors... - Loading...
