"Please go into service mode and set" message
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I have a seemingly easy problem on my hands here, but just can't find what I need. It's a Samsung ue46es6530 and every time I turn it on I get a message saying "Please go into service mode and set below options. Type, Local Set, Front Color Option". The thing operates normally if I just click OK and bypass the message, but it shouldn't happen to begin with. The reason I say it seems easy is because all I'd need to do is either reprogram the EEPROM or indeed set those options, but neither of these work: can't find a dump and those options are grayed out (poor quality picture there, I know - it was zoomed in since I had the cable already plugged into the phone and didn't want to go through the whole loading process again just to download one photo)....what to do ? Any thoughts ? Perhaps someone can provide a dump or some tips. Cheers and thanks.
    Wattevah...
  • gabiz_ro
    • Mar 2011
    • 167
    • Romania
    Re: "Please go into service mode and set" message
    Search on sammygo for 3speed command.
    Then you can enter deep in service menu and set required.
    • vinceroger69
      • Mar 2012
      • 6714
      https://wiki.samygo.tv/index.php?tit...%2B3SPEED_keys
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Found that article a little while ago just before you replied Now, admitting I DO get in there, what do I set them to? I can't figure out how the panel type is determined. I mean right now I have 46R1AF6E there. 46 makes sense (it's the diagonal in inches and the same as the TVs model), but where do I derive the other info from ? I took pictures of everything just to be safe
        I already made a cock-up, excuse the language, by trying to erase the ATMLH214 chip which resulted in the TV showing me the smart TV logo and then rebooting over and over....I managed to resurrect it SOMEHOW by messing around with the SDA-SCL pins on the board and shorting those to VCC until the TV finally came on.....NEVER do that again
        Wattevah...
          • 12091
          • U.S.
          This might show how to get in there, don't know what the values should be. https://wiki.samygo.tv/index.php?tit...3_simple_steps
          • gabiz_ro
            • Mar 2011
            • 167
            • Romania
            You touch only what you need is service menu.
            Can\t remember what's required
            Locale set front color type
              • 12091
              • U.S.
              It must be some sort of a well kept secret or someone here would know it, you would think.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                That was my original concern: not knowing what they should be set at. On what IC is this info stored exactly ? I read something about a WellTrend IC, which I indeed located in the bottom-right of the board...I was hoping I'd be able to remove the IC, replace it with a new one and not lose this original semi-functional configuration (which turns on despite the error message), but seeing the IC I doubt that's possible, plus I'd need a way to copy the info from it onto the replacement chip and mess with that one and the cost would outweigh the result...
                Wattevah...
                • gabiz_ro
                  • Mar 2011
                  • 167
                  • Romania
                  That is MICOM
                  Dont't touch until is really needded otherwise you'll get a brick
                  And need to be reprogrammed again.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Then it's probably stored on the ATMLH IC I messed around with and almost bricked the thing...very dedicated and hard to find those chips...no datasheet, no nothing...
                    Wattevah...
                    • gabiz_ro
                      • Mar 2011
                      • 167
                      • Romania
                      Just an I2C eeprom
                      https://cdn.badcaps-static.com/pdfs/...6af683d34e.pdf
                      See on page 12 marking example.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Makes me wonder my programmer didn't read it properly...actually it DID read something off of it, but when I tried erasing it it told me it's not empty and then when I tried writing back what I saved onto it anyway, it would give me an error saying "chip and contents are in disagreement", or something along those lines, though this varies from programmer to programmer of course....could be that the chip itself is faulty. Given it's similar to a 24c512, I could technically replace it with one of those...
                        Wattevah...
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Ok, I managed to get the TV up and running...a series of fortunate events happened, so let me see if I can remember them all so I can run you through I first found a replacement EEPROM, erased it correctly this time (the software was set to 5v instead of 3.3v, if that makes a difference) and installed it onto the board. Just like before, the error message popped up, but this time I was determined to get in there and set the SOB to what it's supposed to be. I took an LG G3 I had lying around, since my Galaxy S3 doesn't have an IR blaster, installed the app from the link you guys provided, got into the super-duper-mega unlocked service menu and manually set those options it was asking for. For the region, I just took a guess and set it to EU Germany....don't know if that's right, but my exact country isn't listed, so I picked the closest option (plus when I was a little kid, I had a TV tuner installed in my PC and my dad told me to leave the region set to Germany, so I coupled with that info too ). The TV now works correctly, though I haven't tried searching for channels yet to see if that works. Other than that, perfect. Changing the IC was all optional though, since I highly doubt that was the critical factor - setting those options is what actually got it going. Cheers guys.
                          Wattevah...
                            • 12091
                            • U.S.
                            Well done, nice work.
                              LCD LED TV Service Menu Codes
                              ALL LCD LED TV SERVICE MENU CODES
                              Service Menu Code with Board Name
                              China Universal Board / Jumper Board Service Menu Code
                              Changhong Ruba Service Menu Code
                              Ecostar LED TV Service Menu Code
                              Orient LED TV Service Menu Code
                              Haier LED TV Service Menu Code
                              TCL LED TV Service Menu Code
                              Samsung LED TV Service Menu Code
                              LG LED TV Service Menu Code
                              Videocon LED TV Service Menu Code
                              Supra LED TV Service Menu Code
                              Toshiba LED TV Service Menu Code
                              Symphony LED TV Service Menu Code
                              Veste/ LED TV Service Menu Code...
                              10-31-2024, 03:58 AM
                            • RRice25541
                              Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                              by RRice25541
                              So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                              the color is all outa wack, like the settings have been corupted,
                              I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                              so
                              The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                              when i bring up the menu and type the pass codes to access either mode the menu disappears...
                              05-13-2022, 10:44 PM
                            • thesame
                              JVC LT-40V750 stuck in service mode switching colors.
                              by thesame
                              The tv is stuck in service mode, i have unpluged it for several times, tryed to power it separate from remote , tryed some reset method using menu button and 4725 typed twice in a row to enter or disable the service mode but it didn't work. The board has no damaged components, could it need a fresh firmware or the emmc could be dead?...
                              01-12-2024, 10:39 AM
                            • Francesc V.
                              Technics SA-AX530 in protected mode. Overload message
                              by Francesc V.
                              I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                              I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                              I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                              (Pin 13 goes through...
                              11-18-2024, 12:39 AM
                            • alext28
                              latitude 3510 service tag manufacturing mode on 10th gen Dell bios
                              by alext28
                              Hello everyone, on the new dell bios interface when the manufacturer mode is activated and I will enter the service tag in the field provided for this purpose and save everything, the bios does not save the new service tag ... does it have one more manipulation that i don't know to apply the service tag ??
                              I'm stuck still entering the tag service, save and quit and still restarting no service tag registered ... the problem occurred on a latitude 3510
                              thank for your help !
                              06-10-2021, 03:31 PM
