55PFL5505D/F7 image upside down and mirror
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Tv on bench is a 55PFL5505D/F7 LCD
    Donor tv is 55PFL7505D/F7 LED
    Hdmi ports on mainboard fried,found this 7505 model with identical mainboard with cracked screen.
    Swapped out the mainboard,now picture is upside down and mirrored.
    062596+menu followed by diversity code should correct panel. Then 062598+info should get you into sam menu.
    I don't have the info stickers on the panel that should show those codes.
    Better yet,can't even get those menus to show up with the original remote.
    Question now is: Would it be easier to just swap the eeprom? And then,what chip is the eeprom on this board.
    Or how do I set this up correct in the service menu?
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • 12206
    • U.S.
    Re: 55PFL5505D/F7 image upside down and mirror
    Service menu-mirror mode, set to on.
      • 12206
      • U.S.
      PHILIPS-1
      # Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
      or
      # Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
      or
      # Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
      # Turn the TV off to exit the Service Menu.
      PHILIPS-2
      * Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
      or
      * Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
      or
      * Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
      * Turn the TV off to exit the Service Menu.
      PHILIPS-3
      * Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
      or
      * Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
      * Turn the TV Off to exit the Service Menu.
      PHILIPS-4
      * Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
      or
      * Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
      PHILIPS-5
      * With the TV off:
      Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
      To Factory Mode:
      Step 1 : Select the source "PC" and then turn off LCD-TV.
      Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
      Press "menu"button and bring up factory mode indication
      L7.1A CTV Service Mode
      With special service remote control. Or short M25, M25
      on board and then switch on TV. Exit: st-by.
      Philips Y6 CTV service mode
      Use the standard remote control an key in a special sequence 0 6 2 5 9 6 followed by pressing the 'MENU' button. If the main menu also appears with the service menu just press 'MENU' again to clear it.
      Philips VR220 service mode
      Reset to factory settings Disconect from the mains power supply. Press and hold the STANDBY/ON button on the device and reconnect to the mains power supply.Release the button when 'OSD' appears in the VCR display
      RELATED SERVICE CODE / MODE
      AIWA AKAI AKIRA BUSH FUJITEC CHINA GOLD STAR HITACHI HONDAI ICHIKO JVC KCL LG MAGNAVOX MITSUBISHI PANASONIC PHILIPS SONY SONY-2 SAMSUNG SANSUI SANYO TCL TCL-2 TOSHIBA VIDEOCON
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        So with 062596 info I got into the menu.
        I got to this page (see pic) and it shows the current panel thats selected and then the options you have. I need the ccfl 55" option I'm guessing but I have no idea how to select that one. Pushing random buttons so far doesn't do more then getting me stuck in a color display loop thats almost impossible to get out of.
        I thought I was smart and DL the software update for the 5505 but the 7505 caught on to that and didnt accept the update
        2nd pic I turned it around in paint to make it easier to read lol
          • 12206
          • U.S.
          Maybe try control+alt+up arrow.
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            There are no control and or alt button on my remote
              • 12206
              • U.S.
              Ok, thought that looked strange, they mustve been on a pc.
                • 12206
                • U.S.
                Be very careful, if you change any of the wrong items you can damage the tv beyond repair. You are looking for the setting called either Flip, Mirror, or Vertical flip (v flip). You'll change that to the opposite of what it is set on now.
                  • 12206
                  • U.S.
                  I have an older lcd philips, I can't find anything related to picture flip, I know it's pretty simple in lg tvs, can't seem to find any definitive info on flipping a philips screen tho. Curious now, I will find out, even if I have to go to the dark web, lol.
                    • 12206
                    • U.S.
                    http://www.supportforum.philips.com/...creen-rotation
                    This guy says you can't rotate image, I think he means in menus, starting to believe it.
                      • 12206
                      • U.S.
                      I guess if all else fails you could do the pc screen flip and use it as a big ass monitor.
                        What is the LCD panel number? Sometime it has control line to set mirror mode.
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Originally posted by budm
                          what is the lcd panel number? Sometime it has control line to set mirror mode.
                          +10
                          • martino
                            Not so "senior"
                            • Aug 2013
                            • 997
                            • canada
                            These are the stickers on the panel. Hope they make sense to you as they are not making sense to me lol
                              • 12206
                              • U.S.
                              https://www.usa.philips.com/c-f/XC000010530 another reset procedure, hard to tell if it will work.
                              • martino
                                Not so "senior"
                                • Aug 2013
                                • 997
                                • canada
                                Well,I'm not looking to reset to default.My problem is that this mainboard is from a 7505 LED model that I'm using in a 5505 CCFL model. If I could only flip the image I'd be golden
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  lcd panel specs link
                                  http://www.panelook.com/LTA550HJ01_S...iew_12171.html
                                    • 12206
                                    • U.S.
                                    Did you try naming it 5505 in menu? might brick it tho.
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      So,I now have this thing stuck in a permanent loop of showing all the colors.
                                      Which IC would be the eeprom,I think the fastest would be to just swap them out and be done with it.
                                        LCD LED TV Service Menu Codes
                                        ALL LCD LED TV SERVICE MENU CODES
                                        Service Menu Code with Board Name
                                        China Universal Board / Jumper Board Service Menu Code
                                        Changhong Ruba Service Menu Code
                                        Ecostar LED TV Service Menu Code
                                        Orient LED TV Service Menu Code
                                        Haier LED TV Service Menu Code
                                        TCL LED TV Service Menu Code
                                        Samsung LED TV Service Menu Code
                                        LG LED TV Service Menu Code
                                        Videocon LED TV Service Menu Code
                                        Supra LED TV Service Menu Code
                                        Toshiba LED TV Service Menu Code
                                        Symphony LED TV Service Menu Code
                                        Veste/ LED TV Service Menu Code...
                                        10-31-2024, 03:58 AM
                                      • cstout
                                        DeLonghi AC Remote only accepts 3V
                                        by cstout
                                        Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                        The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                        I can't find any schematics...
                                        06-03-2024, 03:53 PM
                                      • Mc_Millian
                                        Toshiba 50lf711u20 fire tv remote not pairing
                                        by Mc_Millian
                                        I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                        The Tv model number is: 50lf711u20 Rev B.
                                        I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                        I've tried 3 different remotes which should be fully compatible with this TV.
                                        Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                        The power button, along with the volume,back,select, and directional...
                                        04-07-2022, 12:15 PM
                                      • edugimeno
                                        HiSense 55A7500F won't obbey to remote after power on
                                        by edugimeno
                                        Hi! I have this TV set that does the following:
                                        1) I press the red power button on the remote
                                        2) The TV turns on normally
                                        3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                        4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                        Then after it's off, it would again accept the TURN ON from the remote and same again
                                        BUT:
                                        -The remote does show the correct IR beam while observed thru a phone camera
                                        -The TV works fine while using the MiRemote...
                                        03-14-2023, 11:22 AM
                                      • wattage
                                        AOC AG493UCX 49-inch monitor - Firmware request
                                        by wattage
                                        Hello Badcaps Community,
                                        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                        07-13-2025, 04:41 PM
