VIZIO XVT473SV has PSU Problem. only 10v on 12v rail.
  • triplefour
    • May 2014
    • 1747
    after reading some of the other posts, im a little wary of putting money into this tv only to find it also has mainboard issues (which seem real common)
    i have a less common problem, where the PSU is not producing enough voltage.
    when i first got the tv, it shows the amber light when plugged in, which changes to white when the power button is pushed. then it cycles back and forth between amber and white about 30 times before finally staying solid white for about 5 seconds then back to solid amber.
    i took the back off, and disconnected the psu from any other boards, and tricked the pwr-on signal to turn on the board.
    the 5vsb is fine at a solid 5v but the 12v is wavering between 9.8v and 10v
    and the 18v is waving around 14.8v~15.2v
    if i also trick the backlight_on pin, i see the psu going into a resetting condition where the 12v line starts at about 4.5v then falls over 5 seconds or so to 2v, then resets back to 5v
    the 18v also does this but from 5v down to 0 and back again
    the LEDV+ seems ignorant of this resetting the rest of the psu is doing. it starts at 8v and slowly creeps down to 0v over many many resets.
    i actually never watched it go all the way down to 0 cause it takes forever, but thats where its going.
    PFC seems fine. 168v when in standby and 400v when turned on.
    i can find the PSU on ebay for 60$ and i would be happy to spend 60$ for this tv as it is pretty nice with the 240hz refresh rate and all, but having no idea what else might be wrong has got me thinking twice.
    would be nice if i could actually repair a PSU for once!
    Don't fear the repair...
  • Agent24
    I see dead caps
    • Oct 2007
    • 4950
    • New Zealand
    Re: VIZIO XVT473SV has PSU Problem. only 10v on 12v rail.
    5vSB is generated from a separate circuit and it's probably fine.
    Sounds like the main PSU is having a problem. Could be bad capacitor, a leaky rectifier diode, maybe faulty PWM controller.
    What voltages do you get if you plug the boards in, and power on with the power button?
    -David VanHorn
    • CapLeaker
      Leaking Member
      • 8119
      first i'd be disconnecting the main board from the psu and force the psu on by itself with the back lights connected. To do that, take a 1k ohm resistor from stby voltage to PSon and another resistor from stby voltage to BLon. Then measure all the voltage rails again. Unless this is one of these Vizio's that generates the stby on the main board.
      • triplefour
        • May 2014
        • 1747
        capleaker, i hadnt wanted to do that because i was seeing low voltages and worried what would happen if i tried to drive the LED's with insufficient voltage but i decided what the heck and left the driver board connected as you said and tricked the BL_ON and PSU_ON pins (and mb disconnected) and voila, the psu is producing correct voltage on the 12v and 18v rail, it is outputting 14.3v on all the VLED (6 of them) to the driver board, and all the backlights are coming on, and i can see the screen is in good shape, not cracked. and the Blue LED on the driver board is blinking on and off, infinitely.. is that blue LED on the driver board supposed to do that in normal operation?
        strange, i guess this PSU wont make with the correct voltages unless the load is connected?
        • triplefour
          • May 2014
          • 1747
          agent24, if i leave all board connected normally with no tricks, and take measurements during while its going amber-white-amber-white, i see only the 5vsb. very low voltage on the 12v and 18v. something like .05~.09
          this PSU is proving that not all PSU are the same, so i shouldnt expect anything anymore! i think i have a good PSU but a bad MB that just isnt properly turning the PSU on as it should when pressing power...
          which falls more in line with everyone else saying the mb goes bad in multiple ways on these things. is there any hope?
          not a bad price for this board actually, considering everyone else is asking around 100, even for the repair services
          https://www.ebay.com/itm/Vizio-47-XV...X8H8a#viTabs_0
          er...ahhh... but its showing a picture of the TCON not MAINBOARD! ???
          are there any other TV's that have a compatible Main board?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4950
            • New Zealand
            Sounds like the mainboard may not be sending the PS_ON signal to the PSU, then, when you press the power button?
            Your low rails when everything is disconnected might be the PSU not liking having no load.
            -David VanHorn
            • triplefour
              • May 2014
              • 1747
              yes the mainboard never sends even the slightest PSON signal when pwr button is pressed...
              and yes at least for this psu, no LED LOAD = incorrect voltages
              • Agent24
                I see dead caps
                • Oct 2007
                • 4950
                • New Zealand
                You need to trace/look at the PSON generation circuitry on the mainboard to find out where the signal is missing. Either there is a fault there, or the CPU is not outputting the signal to begin with.
                If the CPU is not outputting the PSON signal, likely causes are bad EPROM, bad power regulator on mainboard, bad crystal, bad buttons/IR receiver, bad BGA soldering, some shorted part.
                -David VanHorn
                • triplefour
                  • May 2014
                  • 1747
                  lotsa bad reviews on this tv....its a nice tv but it breaks a lot
                  https://www.amazon.com/VIZIO-XVT473S...R3210B8FO7CNNT
                    • 12123
                    • U.S.
                    https://www.bonanza.com/listings/Viz...CABEgIbx_D_BwE
                    • Nagy Daniel
                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                      by Nagy Daniel
                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                      So, I generated a table with AI so I can...
                      03-04-2025, 08:24 AM
                      by momaka
                      03-15-2023, 10:17 PM
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      by sam_sam_sam
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                      This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      09-12-2024, 02:30 PM
                      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
