Have a samsung LN32a300 with a dark smeared over tinted picture, don't believe its backlit related. Anybody seen this on a LCD set or have any ideas ??
ln32a300 dark picture
Re: ln32a300 dark picture
That is bad GAMMA Voltage reference issue on the T-CON board, more likely the GAMMA IC P/N AS15 or AS19.
Please up load the good clear pictures of the T-CON board, there should be GAMMA Voltage test points on that T-CON board.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
https://www.badcaps.net/forum/attach...5&d=1522204903
IC on the bottom left, what is the P/N as printed on top, AS15?Never stop learning
AS15-G, that is common failure on T-CON board, there are many many threads about this IC.Never stop learning
You can verify the VGMA Voltages first if you want, I cannot see the test points in your pictures.
Ah, your pictures came back up!
https://www.badcaps.net/forum/attach...1&d=1522205818
I see GM1 ~ GM14 for the GAMMA Voltage test points.Last edited by budm; 03-27-2018, 09:45 PM.Never stop learning
TCON voltages with no video input are
GM1 = 13.05
GM2 = 10.43
GM3 = 9.69
GM4 = 9.05
GM5 = 8.6
GM6 = 7.49
GM7 = 7.1
GM8 = 6.66
GM9 = 6.21
GM10 = 5.05
GM11 = 4.7
GM12 = 5.06
GM13 = 3.03
GM14 = 5.2
Vref = 13.3, VCM = 5.88, VDA = 13.74, SDA = 3.3Comment
Bad #12 and #14. See the pattern?Never stop learning
Thanks for the follow-up.Never stop learning
by DanstonaWas watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal... -
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... -
by Bazfletch3Hi all
While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
From there I envisaged that the backlighting wasn't working, however... -
by shelby5041hi
i have a samsung lcd tv
it powers on with sound and backlight but no picture
all voltages from PS are good 12v 3.3v and 5v
whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
no 12v at the tcon fuse
i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
the odds of having 2... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
- Loading...
