Sharp LC-70LE660U, single blink error code
  • Truncatedhose
    • Oct 2014
    • 343
    The backlight DOES NOT flash momentarily in my unit like the following threads mention, but here they are linked for the photos:
    https://www.badcaps.net/forum/showth...ht=lc-70le660u
    When I plug the TV in, the power led comes on solid and stay solid for about 10 seconds and then goes out. After, another 5-10 seconds it starts to slowly blink 1 time every second.
    I will post the service manual for any who want to peruse it.
    The service manual states that it is a "Lamp error", but I tested the 3 LED arrays with my LED tester and all three read 95.6 volts exactly, so I doubt that is the problem. I also tried disconnecting the panel ribbon one at a time and I DO NOT get half a picture, nor does the blink code go away.
    I would like to try forcing the unit on and clearing the error, but the service manual doesn't seem to say how to do that.
    Help would be greatly appreciated.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sharp LC-70LE660U, single blink error code
    https://www.badcaps.net/forum/showth...akaftr8&page=3
    Read post no. 50. Key code combination to bypass lamp error.
    • Truncatedhose
      • Oct 2014
      • 343
      Thank you, Freak, I read the below post from that thread, but when I do that, I still don't get a picture and sometimes it seems like my white LED will stay solid and never flash and I can turn the TV on off (make the LED go on /off), but I never see any backlight flash or image.
      "okay guys it's working now I don't know how or why but as soon as I did a series of tests I tried another key combination back on the keyboard this time I used volume up and channel down well plugging in the TV at the same time and long and behold beautiful picture came up. Obviously volume up and channel down reset the main board to factory specs. I didn't look to see how many error counts are in there but it works!
      now here's the kicker as soon as you unplug to TV plug it back in it's back to the one fast flash one slow flash lamp error. But if you do the vol up channel down its back in action and powers up and off with no problem.
      I did notice OFL pin is 3.3v constantly now when on."
      • Truncatedhose
        • Oct 2014
        • 343
        Turned out this one was a bad panel, not bad LEDs. Swapped the main board (because the error could not be cleared for some reason) and still no picture, but error code gone. Then unplugging half the panel made the other half of the screen work, but had tons of vertical lines in it. Hope this helps someone else.
        • budwich
          • Jul 2015
          • 3097
          not so fast.... depending on what is happening, the panel may still be saveable.... got a picture of the "half unplugged display"..... sometimes side issues impact the vertical.... hence the question/request.
          • nomoresonys
            • 12206
            • U.S.
            Could still be a bad t-con right? how did you conclude bad panel?
            • freakaftr8
              • Oct 2012
              • 3743
              99% of the time when one side is disconnected and the other side suddenly works after a no picture event, its usually a shorted panel. Albeit a shorted MLCC capacitor on a source driver board or a shorted out side gate driver. In your case it may be a shorted MLCC If they were all vertical lines on one side, decent picture on the opposite.
              • budwich
                • Jul 2015
                • 3097
                the better test is to disconnect the corner ribbon cable (one at each lower corner interconnecting the bottom edge boards to the side edge boards). This "test" takes out any possible "corruption" of the bottom edge boards by "compromised" side tabs... which might sometimes cause vertical issues as well as horizontal issues. It isn't a given but as freakaftr8 suggests, that there might also be "fixable" capacitors on the lower edge boards that may be an issue.
                • nomoresonys
                  • 12206
                  • U.S.
                  Thanks for clarification.
                  • charlie555
                    • Feb 2018
                    • 76
                    • usa
                    I have the same tv. If I unplug the ribbon cable on left side looking from the rear of the TV I get back lights the whole screen.If I unplug the right side I get nothing. No power to main bd and no backlights,
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
                      LCD LED TV Service Menu Codes
                      TCL LED TV Service Menu Code
                      LG LED TV Service Menu Code
                      10-31-2024, 03:58 AM
                    • rmacintosh
                      Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                      by rmacintosh
                      I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                      The symptoms of the tv ar as follows:
                      • Plug AC in to back of TV
                      • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                      • The 3 blink code is given by the power LED
                      • If the TV is unplugged and then
                      03-14-2020, 12:24 AM
                    • SdlewisSr
                      Sharp LC-80LE632U 2-5 blink code
                      by SdlewisSr
                      I have a Sharp LC-80LE632U with a 2-5 blink code. I have narrowed it down to the T-Con/Panel. I get the error if both or either ribbon cable is connected between the T-Con and the Panel. If I disconnect both ribbon cables, I get no error and the TV powers up just fine.
                      Does anyone know if this is a definite bad Panel or is there a chance that the T-Con could still be at fault?
                      07-11-2021, 07:36 PM
                    • reporter1979
                      2 red blink code on old led tv Sony KDL-40W2000
                      by reporter1979
                      Hi all, the TV KDL-40W2000 was flashed by a lightning.
                      Firstly I got the 3 red blink code.
                      Following other threads I changed the power supply board and got always 3 blinks.
                      So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                      The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                      What else can I do?...
                      02-17-2023, 11:50 AM
