UE55D8000 Power Cycling On Off Issue
  • mrdiy88
    • Nov 2017
    • 59
    • United Kingdom
    Hi Guys,
    I have a Samsung UE55D8000 with an issue of power cycling. The TV would have come on and start to cycle after a while. It used to come on for perhaps 15 minutes then start to cycle.
    I disconnected the main board from the power supply and it stopped cycling so I thought then that the issue was with the main board. The votages on the power supply tested ok.
    So I then ordered up a main board BN41-01622C (BN94-04313T) and carefully replaced the old main board. I was gutted to see when I turned it on that the power cycling issue is still there.
    The LED lights come on, then off and I can hear the relay clicking on and off. All caps look perfect on the Power board.
    Can anyone suggest where I go from here? This has been driving me crazy and I would love to get this set fixed.
    Cheers guys!
    • 12269
    • U.S.
    Re: UE55D8000 Power Cycling On Off Issue
    Could be a backlight issue, the replacement mainboard might be bad.
    • mrdiy88
      • Nov 2017
      • 59
      • United Kingdom
      Thanks, I will test the backlights just in case, although when it was working they all looked good. The main board I bought was sold as fully tested and it was packed very well so I am hoping it wasn't bad (I doubt it) but will test on further. If you have any other advice fire away
        • 12269
        • U.S.
        Can you post really good detailed pictures of the top and back of the mainboard?
        • daz2206
          • Oct 2013
          • 50
          check the cable between psu and mainboard, i had the same problem with a ue55es8000 (year younger model) and it was the connecting cable shorting (mine was burned in the pin holes)
          • mrdiy88
            • Nov 2017
            • 59
            • United Kingdom
            I will do this now, I have checked the pins though I didnt notice any shorts on the 13v side or anything, they look good. Will post images now, thanks guys
            • mrdiy88
              • Nov 2017
              • 59
              • United Kingdom
              Here is the images of the main board hopefully all clear enough
                • 12269
                • U.S.
                How bout some good clear pics. of power supply board, just the top should be good for now, just for testing.
                  • 12269
                  • U.S.
                  See if you can get a good picture of the little legend/map with the expected voltages also.
                    • 12269
                    • U.S.
                    You do have a multimeter for testing?
                    • mrdiy88
                      • Nov 2017
                      • 59
                      • United Kingdom
                      Here is the Power supply images and the legend. I do indeed have a multi meter. Thanks
                        • 12269
                        • U.S.
                        Hmmmm, I wonder if there's an easy way to test the backlights on this model?
                        • mrdiy88
                          • Nov 2017
                          • 59
                          • United Kingdom
                          Thats what I was hoping. I'm not sure the best way to go about it. Although with the led connectors removed it still cycles off and on endlessly.
                          I am making it my mission to get this one fixed if its the last thing I do lol
                            Can we at last see the pictures of the whole backside of the TV so we can see how all the boards are connected together?
                            • mrdiy88
                              • Nov 2017
                              • 59
                              • United Kingdom
                              No problem. Here is the image showing the back. Thanks
                                Power supply- LED driver board BN44-00428A, same as used in UN55D7000LFXZA.
                                Disconnect the cable between power supply and the main board then plug the AC plug into the outlet and see if the backlights will come on and stay on or flash on for seconds.
                                Pictures provided by shopjimmy.
                                • mrdiy88
                                  • Nov 2017
                                  • 59
                                  • United Kingdom
                                  I can confirm that from disconnecting the cable going from the power supply to main board the tv does not cycle on and off and the leds do not light at all. It clicks once as if the power supply is on but no leds light at all. Many Thanks
                                    So you are 100% sure that the backlights did not even flash on for seconds at all, correct?
                                    There are 4 sets of LED Voltage booster circuits (for 8 strings of LEDs)so if we have one bad string, the backlights should flash on for seconds then the error detection circuit will kick in and shut down the backlights circuits. There are many threads about BN44-00428A in Badcaps.
                                      BTW, you should also try re-soldering the transformer pins and devices' leg, especially those that are soldered to the through hole rivets.
                                      • mrdiy88
                                        • Nov 2017
                                        • 59
                                        • United Kingdom
                                        With the cable to the main board removed they do not flash at all when ac is switched on. I can hear the relay click on but definately not even a flash
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • yaya3gmax
                                          Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                          by yaya3gmax
                                          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                          Symptoms:
                                          • Laptop works normally on a pre-charged battery.
                                          • Battery does not charge when adapter is connected.
                                          • Without battery:
                                            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                            • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                          08-21-2025, 07:16 AM
