Vizio M65-C1 won't power on
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Vizio M65-C1 won't power on
Per your report per post 12 without having the main board connected, the 12V is not steady at all.
That is why I suggested to have resistor load connected to the power supply to see if it will be steady or not.
CN9101 -
PIN 1 - +5V/+3.5V - 0V
PIN 3 - +12V - 19V
PIN 5 - +12V - 19V
PIN 7 - +12V_A - 19V
PIN 9 - GND - 0V
PIN 11 - GND - 0V
PIN 13 - 3D - 0V
PIN 15 - ON/OFF - 0VComment
I am having the exact same problem with my TV which is the same model. Here is the link to the bad caps thread I started.
https://www.badcaps.net/forum/showth...t=vizio+m65-c1
Also noticed the large caps(See the 4 pic in first thread. bottom 3 caps on hot side)like to hold there charge for some time they do not drain very quickly so just be careful don't want you to get a nasty jolt.
I have the same issues.
flashing led light on video board.
when video board ribbon is removed I have steady 19 volts in the same locations. with video ribbon in circuit voltages are fluctuating.
I found a shorted mosfet at q911 replaced but still having a issue.
Thank you for the clear pic of IC U911 I will order one of those now.
Budm question that IC U911 which drives that Q911 I have a eeprom reader writer can i heat up IC u911 and save the data and write to a new chip is that possible for the fix for this tv??Comment
I believe IC 9111 part number is SP6018E instead of 1BE.
Here is the data sheet I found on it.
https://cdn.badcaps-static.com/pdfs/...156cf77ffc.pdfComment
We still need to test the power supply by itself using the load resistor to draw about 1A to see if it will be stable or not with resistor load.
The output may be fluctuating due to main board is over loading the power supply or the power supply cannot put out steady Voltage with load, right now it is steady without load (main board).Attached FilesNever stop learning
How would I go about doing that? Do I need to purchase a resistor? Sorry, all of this restistor talk is completely foreign to me.Comment
I have a Vizio M65-C1 that won't power on. I've purchased a replacement power supply and main board but the TV exhibits the same behavior. I've purchased a multimeter, I'm just not sure where to start.
I've attached pictures of the boards, courtesy of shopjimmy. Watching some YouTube videos to test the power supply, I wanted to test the standby power voltage. I couldn't find any pins labeled as standby, so I'm assuming it's pins 1 and 2 on the power supply. They are labeled 5V/3.5V.
The only indication that I have power is a constant flashing blue/purple LED401 on the main board anytime I provide power to the TV.
Can someone point me in the right direction? I'm new to TV troubleshooting.Comment
Hey I wanted to update everyone and let you know I was able to repair the power supply by following this YouTube video https://m.youtube.com/watch?v=fesJGOLurBgComment
Question for the OP:
How did the youtube steps work but not replacing the power supply? Did you fix the power supply with the newer main board or your original?
I ask because I have the same set that turns on, but only to display the Vizio logo for a few seconds. The backlights stay on inside the set for about 30 seconds then off for 7 and it goes like that over and over. It used to startup after doing this for 30-40 minutes but now won't.
I found the same video and opened my set. My issues didn't seem to follow the youtube video in that the diode portion was registering correctly although the resistor did not seem to be registering correctly on my multimeter. Should it also be 8ohms? This is for the R9114.
I ordered this piece but, after weighing the task I decided to punt and get a new power supply completely. It arrived today but I have the same issues.
It's possible my issue is completely unrelated and I may post a new thread about it. I'm willing to attempt to fix the R9114 resisitor BUT I just don't see how that could work if a whole new PS board didn't work.Comment
Well if the resistor and or diode are ok on the board you did not fix, then it's a different issue no doubt.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
