Panasonic TC-P50VT20 10 Blink Code
  • GermanPlumber
    • Jun 2006
    • 11
    Ok I have a Panasonic TC-P50VT20 TV that is exhibiting a 10 blink code error.
    I have done some basic troubleshooting and hopefully someone could shed light on what is happening so I can replace/repair the correct board.
    I have read the few documents on this issue related to 2010 models and it basically says, it's the A board, P board, SS board, or SC board.
    I also read through this page https://www.badcaps.net/forum/showthread.php?t=46753 and they had similar problems.
    What I have tested so far.
    No visible arcs, marks, blown components, but the SC board side of the TV smelled a little off, like electrically burned smell.
    Tested SC2 connector on SC board for short. Seems good. Removing SC2 connection and turning on gives 7 blinks, but I think that is normal.
    Tried to do the A board isolation test by disconnecting P6 and P7 on P board, disconnected D5 ribbon from D and A board, and also installing a jumper on P34 connector from pin 1 to pin 3. My P7 cable has a
    a jumper between pins 12 and 14, so I also tried it there as well. Did not get a white screen.
    Tested "After Power SW ON,F_STB 15V outputs at P6’s pin 9 15V outputs at P6’s pin 1 before Shutdown?" I get 15V on Pin 9 but I get 0V at Pin 1 for that 15 second period.
    Panasonic's documentation say bad P board, but I want to make sure I am not missing something.
    Thanks for any help.
    Edit: I have dealt with a few panasonics, and it seems to always be SC related, and that smell of burnt electrical had my brain thinking, so I did a another look around, and I think i may have found my culprit.
    Do my symptoms look to be just a bad SC board and nothing more?
  • GermanPlumber
    • Jun 2006
    • 11
    Re: Panasonic TC-P50VT20 10 Blink Code
    Due to the damage on the SC board, I am going to get that repaired first, have the buffers tested for damage, and then will diagnose from there. The no white screen makes me think a bad power board or SC board.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      The power board, at least according to some folks, should result in code #2, (SOS #2/ 2-blinks) but I dunno...
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • GermanPlumber
        • Jun 2006
        • 11
        Ok good to know. I'll report back with my findings after the SC board is fixed.
        • GermanPlumber
          • Jun 2006
          • 11
          SC board repaired and TV is back up and running. I did have someone verify the buffer boards were still good. Ribbons had to be reseated (TV power off and disconnected from wall when reseating) as they werent inserted perfectly. Hopefully this helps the next guy.
          Obvious things I learned.
          1.) Look for obvious burn marks and off smells.
          2.)The 10 blink diagnostic code was helpful, but it pointed me to a bad main or power first and that wasn't accurate. If I didn't see the SC board damage, I wouldn't have guessed it.
          Thanks again.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            SC is the Y-sustain, according to Tom66.
            Arc A770 16 GB
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              After all of...
              07-13-2024, 08:14 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • tiku
              Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
              by tiku
              Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
              I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
              09-05-2021, 05:02 AM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
