Tevion LCD 4040 main capacitor failure
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Tevion LCD 4040 main capacitor failure
    maybe wait and sees what budm suggests regarding the capacitor so the old one is 220uf 450v and your replacement 220uf 450vdc
    also to save you blowing fuses have a google search and build yourself a dim bulb tester that way if there is still a short the bulb will light bright and wont blow the fuse on the psu (saves you money keep buying fuses and causing more damage)
    • divy
      • Mar 2018
      • 24
      • czc
      No old one 220uf 450vdc capas and replacement 220uf 450v capas
        https://www.badcaps.net/forum/attach...4&d=1521402936
        I do not understand about the new cap not being DC rating, it has (-) bar on one side as shown in your pictures so it is polarized cap.
        • divy
          • Mar 2018
          • 24
          • czc
          Hi my TV power supply I have change capas 220uf 450vdc which capas to good to buy https://m.ebay.co.uk/itm/MAL21594722...QAAOSwEK9UCJ9R https://m.ebay.co.uk/itm/CAP-ALU-ELE...&ul_noapp=true
          • ayhan yılmaz
            • Mar 2018
            • 40
            • TÜRKİYE
            Hi Man 220UF450 volt muadil 330UF450volt ok
            • divy
              • Mar 2018
              • 24
              • czc
              #26
              So u mean to say 330uf 450v OK to use
              • ayhan yılmaz
                • Mar 2018
                • 40
                • TÜRKİYE
                #27
                Yes Man scrap power supply card block capacitor Disassembly Change
                • divy
                  • Mar 2018
                  • 24
                  • czc
                  #28
                  I don't understand what you saying mate
                  • ayhan yılmaz
                    • Mar 2018
                    • 40
                    • TÜRKİYE
                    #29
                    Divy power supply problems ok
                    • divy
                      • Mar 2018
                      • 24
                      • czc
                      #30
                      No man steal problem with power supply if can help me out
                      • cheeky2
                        by cheeky2
                        05-25-2024, 03:27 AM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • howardc64
                        HP Inkjet printer main board bulging cap failure
                        by howardc64
                        Fixed a 10yo HP inkjet with a bulging cap on the digital computer power rails (1 to 5V). Unstable voltages causing these inkjets to not boot properly or crash quickly. Seems like more and more of these are showing up nearing the 10 year mark. Board design seem to look similar for many of these printers.
                        https://h30434.www3.hp.com/t5/Printi...t/true#M997922
                        02-03-2025, 09:50 PM
                      • Asraf Atb
                        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                        by Asraf Atb
                        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                        01-27-2025, 05:02 PM
                      • JSin21
                        Compatibility of main boards between different variations of samsung MU6100
                        by JSin21
                        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                        I have Samsung Smart TV UA65MU6100WXXY version DA01
                        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                        11-27-2023, 04:54 AM
