Vizio E320VA shows logo then black screen
  • KGJC616
    • Mar 2018
    • 12
    So basically the TV turns on shows the Vizio boot logo for a couple of seconds then goes to black screen. The indicator like is still lit up showing the TV is on. I can turn the TV off with the power button and the light indicator light goes dim.
    I can then repeat TV boot logo comes up and then couple seconds back to black screen.
    I have a blue LED that comes on, on the T-Con board with logo and backlights working then when logo disapears the backlights turn off and the blue LED does as well.
    I was told the sound was starting to go out on the TV as well before it went completely out like this. Was also told that sometimes they could get it to work sometimes but they had to power cycle the TV a lot, and it would also turn itself off randomly usually around 10mins of use.
    This TV was given to me so I'm not at any kind of a loss, any help would be greatly appreciated thanks.
    Re: Vizio E320VA shows logo then black screen
    http://www.shopjimmy.com/catalogsear...q=Vizio+E320VA
    You may want to look into the EEPROM or the repair kit for the main board.
    • KGJC616
      • Mar 2018
      • 12
      Thanks budm, Any Idea which repair kit I should be getting? lol
      Top Board # 715G3715-M01-000-004K
      Sticker #'s
      (T)TQACB 5K00208 TOP:A MB:A V2.23
      Also Which one is the EEPROM?
      • KGJC616
        • Mar 2018
        • 12
        Okay I found the eeprom and the audio chip
        rom: U418
        audo: U602
        Now just need a little help figuring out which one I need to order.
          • 12181
          • U.S.
          What is your FULL model number of tv or the whole number on the little white sticker on your mainboard?
          • KGJC616
            • Mar 2018
            • 12
            Main Board small right sticker
            (T)TQACCB 6K00208 - First Image
            Second Image I think is the T-con board driver
            Third Image Sticker on back of TV
            • KGJC616
              • Mar 2018
              • 12
              Okay I got the part figured out, now to just wait for it to get here.
              http://www.shopjimmy.com/vizio-cbpft...for-e320va.htm
                • 12181
                • U.S.
                Ok, yes it matches up with the first part of your serial number.
                • KGJC616
                  • Mar 2018
                  • 12
                  Okay Should be final Question lol. I got my new chips today and the audio chip "U602" has a metal plate on the under side of the chip. does this mean that it is soldered underneath the chip?
                  I'm leery to try and remove this chip since I'm not sure, and all I have is a soldering iron and not sure how to desolder this. Also how I would go about soldering it back to the board. If I get it removed
                  • KGJC616
                    • Mar 2018
                    • 12
                    Okay well I got the new EEPROM soldered in and it's still doing the same problem. everything lights up shows logo, then back to black screen.
                      • 12181
                      • U.S.
                      Could be a separate issue with the mainboard. Usual place to start troubleshooting unless you have a real good idea is the powersupply voltages. Look at the second video in my signature, HEED THE DEADLY VOLTAGE WARNING.
                        • 12181
                        • U.S.
                        https://www.youtube.com/watch?v=mUvclBfaMXg
                        • nwcs
                          • Dec 2015
                          • 311
                          • usa
                          I would check the LED's. If you turn the tv on and press the menu button then hold a flashlight up to the screen and see if you have the menu showing.
                          • nwcs
                            • Dec 2015
                            • 311
                            • usa
                            Never mind. I did not see the picture with the led's lit up
                              "I was told the sound was starting to go out on the TV as well before it went completely out like this. Was also told that sometimes they could get it to work sometimes but they had to power cycle the TV a lot, and it would also turn itself off randomly usually around 10mins of use."
                              I am beginning to think if that statement from the old owner is true or not because I do not expect bad LEDs to cause those issues as stated by original owner, that sounds more like main board problem that is why I suggested to look into EEPROM.
                                • 12181
                                • U.S.
                                https://www.youtube.com/watch?v=AclsDZ8glK4
                                  • 12181
                                  • U.S.
                                  Check your solder work over and check for bad solder joints all over and underside of mainboard.
                                    • 12181
                                    • U.S.
                                    Get the hair dryer out and heat up the mainboard, see if anything changes, if it does you're closing in on the faulty area.
                                      • 12181
                                      • U.S.
                                      So it's 2 seconds to black, could be a backlight issue.
                                        • 12181
                                        • U.S.
                                        Do the testing in video post #16, do it just like he does it and do the flashlight test in post 13. There's a tcon test you can do too.
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • abajor
                                          A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                          by abajor
                                          Having this very weird issue.
                                          The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                          I swapped with a working screen from an A2141 waiting for parts.
                                          The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                          The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                          04-27-2024, 01:37 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • David82827372
                                          Dropped MacBookPro 15” 2012 shows black screen
                                          by David82827372
                                          MacBookPro 2012 15” A1398.
                                          No visual damage was found.
                                          Mac was inside of suitcase and it was inside of a bag.
                                          Mac boots up,I can hear the chime,but the screen is totally black,not even “light” black. Caps lock light doesn't work.
                                          I tried SMC,PRAM reset, didn't work.
                                          Reconnecting screen display by unplugging those two things didn't work. I used this video
                                          Reconnecting battery didn't work.
                                          I also tried SMC,PRAM reset while the battery was disconnected and Mac was getting...
                                          01-12-2024, 08:16 AM
