LG 55LB5600 LED voltage
  • freakaftr8
    • Oct 2012
    • 3743
    So I got this TV in with a flashing back light immediately took the TV in disassembled it down to the backlighting system. Found 5 burned out in various places. These appear to be a 5 V LED with a bucket style diffuser lens. Unfortunately I do not have any of these in 5v. Anyone have any ideas where to find these single LEDS?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 55LB5600 LED voltage
    have you got a picture of a old led and the rough size of it
    • freakaftr8
      • Oct 2012
      • 3743
      Some more pics. Oddly the LED is about the same size as the 3v ones LG makes.
      Sorry I meant 6v, not 5v. These appear to be 6v. Can I just the in 2 3v piggyback? I know this is dumb but it's for someone who lost everything and just needs a tv not caring on bright spots on the screen.
      • vinceroger69
        • Mar 2012
        • 6714
        ive got some of those in 6v but i ordered them from ali express not sure how long stuff takes to get to the usa
        https://www.aliexpress.com/item/50pc...828702089.html
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4543
          • Italy - Milan
          "Can I just the in 2 3v piggyback? "
          ??? You want to put 3v ones and ruin a giant 55inches? It's out of logic.
          LG produces tv with 2 types of 6v leds, you better search the web shops for your precise model, if there is a sheet of led data then you start from there to search on the various web markets, i found mines on aliexpress.
          ---bought from ebay:
          50PCS LED Backligh 2W 6V 3535 Cool white LCD Backlight for LG LED TVs
          Product description
          Forward Current (IF ): 500mA
          Pulse Forward Curren t1 (IFp): 800mA
          Reverse Current (IR): 50mA
          Reverse Voltage (VR): V (mA)
          Power Dissipation (PD): 2W
          Operatin Tgemperature (Topr): -40 - +85 °C
          Storage Temperature (Tstg): -40 - +100 °C
          Soldering Temperature (Tsld): Reflow Soldering:260 °C
          for 10secs
          Hand Soldering:350 °C
          for 3secs
          Junctio Tnemperature (Tj ): 162°C
          Forward Voltage (VF): 6.0-6.8V (250mA)
          Luminous Flux (LM): 150lm (250mA)
          Luminous Intensity ( IV ) : cd (250mA)
          Wavelength (nm) : -nm mA
          CIE : x=0.255 y=0.223 (250mA)
          Color Correlated Temperature (CCT):
          CRI :
          Viewing angle : 120°
          Lead Frame Type LED Package: 3.5x3.5x0.65 mm LxWxH d=mm
          ---bought from Aliexpress:
          50pcs LED 3535 3537 Light Beads Cool white High Power 1.2W 6V 97.7LM For SHARP Original LED LCD TV Backlight Application
          MODEL NAME : GM5F20BH20A
          Manufacturer : SHARP
          Power Dissipation (PD): 1.2W
          Forward Voltage (VF): 6V
          Luminous Flux (LM): 97.7LM
          Color Correlated Temperature (CCT): Cool white
          Lead Frame Type LED Package: 3.7x3.5x0.8 mm LxWxH d=2.58mm
          https://it.aliexpress.com/item/SHARP...796564458.html
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            by sam_sam_sam
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
            Based on Intersil's Robust Ripple Regulator...
            11-05-2024, 03:24 PM
          • ruletero
            Acer a515-43 low battery charge voltage
            by ruletero
            Hi
            Acer A515-43
            LA-H801P
            Fail: Does not charge battery, has low voltaje on connector.
            Laptop didn't want to turn on, only charge led blinked.
            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
            10-24-2022, 02:31 PM
