VIVAX Imago LCD TV-3215
  • kixo
    • Mar 2018
    • 10
    • Croatia
    I'm trying to replace some resistors on power board from VIVAX Imago LCD TV-3215, but I can't identify them because they are badly burned.
    They blew up after near lightning strike. Any advice on how to identify them?
    Power board model: SLT689 VER:1.0
    Resistors: R129B, R129C, R129D
    Already searched the internet for schematics or board replacement, but with no luck. Perhaps someone has spare lying around?
  • maxvalutech
    • 804
    • australia
    Re: VIVAX Imago LCD TV-3215
    If you can find a clear enough image of that board on the net you can identify the resistors by their banding colours.
      May be you should stick to one thread instead of making two threads:
      https://www.badcaps.net/forum/showthread.php?t=68086
      All I can say is the total resistance will be less than 1 Ohms for the Source resistors that blew up for that STBY SMPS.
      Did you check MOSFET Q11 to see if it has very low resistance between Source and Drain pin.
      You also have bad caps on the cold side of the circuit.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        These are SMD resistors...they will not have coloured bands but Numbers to identify their values.
        • jetadm123
          • 2169
          It may be the angle, but don't a few of those filter capacitors next to the white connectors look a little swollen?
            I see at least 3 caps with bulging top, one has liquid leaking on the top too.
            He should re-cap in both the cold side and in the HOT side but no need to replace the large main filter cap.
            • kixo
              • Mar 2018
              • 10
              • Croatia
              Thank you for quick response. I just checked the MOSFET and it has .5 Ohms between drain and source and it passes continuity test between all pins. (but I haven't desoldered it yet). Yes, 1000uF caps also look suspicious.
                So the MOSFET shorted out which means the SMP IC7 may be damaged also. Check the components between the GATE pin and the GATE drive output pin to see if those parts are OK or not.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • thesame
                  DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                  by thesame
                  Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                  The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                  02-27-2024, 04:31 AM
                • k-krzych
                  Identify board to board connector
                  by k-krzych
                  Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
                  07-08-2025, 12:32 PM
