VESTEL_D1_Plus_PNL.bin for 24W1433DB
  • Jim Trent
    • Feb 2018
    • 8
    I revived my Toshiba (Vestel) 24W1433DB using the mb90_en.bin file from this thread only now the screen output is upside down. The picture quality is perfect but upside down.
    I believe that the panel settings are configured in the file VESTEL_D1_Plus_PNL.bin - does anyone have a working 24W1433DB from where they could take a copy [1] of this file? Or does anyone know how to hack this file to rotate the screen by 180 degrees?
    Thanks,
    Jim.
    [1] This file, and others, can be copied to a USB stick using the 'USB Operations' option on the Service menu. The Service menu can be accesssed from the regular menu by entering 4725 on the remote. If you place an empty txt file on a USB stick called: DownloadPq.mb95, and then trigger the 'USB Operations' option on the Service menu, it will copy a bunch of files to the USB stick, one of which will be: VESTEL_D1_Plus_PNL.bin - I'd really like a copy of that one.
    There are other files you can grab too using an empty DownloadProfile.mb95 file, or an empty DownloadSpi.mb95 file. Files can also be written back to the Pq, Profile, and Spi folders. For example, if the USB stick has the folder: 'Profile' containing the file: mb95_hwprofile.bin, and you trigger the 'USB Operations' option this will cause the mb95_hwprofile.bin file on the USB stick to replace the one on the TV. Turning the TV off and on should then load any new file(s).
  • aftronica
    • Jan 2016
    • Portugal
    Re: VESTEL_D1_Plus_PNL.bin for 24W1433DB
    http://www.fanzo.org/forum/viewtopic...ADHsUClZJ844Fs
    • Koster
      • Jan 2020
      • 3
      • Madrid
      Hello Jim
      I am in the same problem, but I have got the files.
      Specifically the one you mentioned at the time on VESTEL_D1_Plus_PNL.bin, but I don't know what line to modify to rotate the screen 180 degrees.
      Thanks,
      Jim.
      • diif
        • Feb 2014
        • 6978
        • England
        Originally posted by Koster
        Hello Jim
        Watch this https://www.youtube.com/watch?v=LunDXQiRioQ he rotates the video 180 on a Vestel.
        • Koster
          • Jan 2020
          • 3
          • Madrid
          I had already seen that video, what it does not say is how it does the whole process.
          • diif
            • Feb 2014
            • 6978
            • England
            I know I have watched a video of his where he edits the code. He was/isd a member on here.
            It might be this https://www.youtube.com/watch?v=eYNjLvq9ekQ it's late here, so I'm not got my amp on, so I can't confirm.
            • Koster
              • Jan 2020
              • 3
              • Madrid
              I had also seen that video and more or less you see part of the screen and the process used to edit the .BIN, but at least it is not very clear to me.
              Yesterday I got a program (Vestel Toolbox) to configure the .BIN file without having to deal with ASCII. But I have not had time to use it, this afternoon / night if I get any progress I will put it.
              • Shotgun25
                • Feb 2014
                • 90
                How did you get on with this issue in the end?
                • yokoono
                  • Apr 2010
                  • 515
                  Do you have problems and want a bin?
                  • Jim Trent
                    • Feb 2018
                    • 8
                    I haven't been here in a long time!
                    I still believe the fix is to use a VESTEL_D1_Plus_PNL.bin file for a compatible TV. In my case the Toshiba 24W1433DB which I believe has a VES236WNEC-01 panel inside - does yokoono have one of these?
                    I'm not convinced that VESTEL_D1_Plus_PNL.bin can be easily hacked. The YouTube video just demonstrates the novelty of changing the word TOSHIBA to DRANFIELD which, while interesting, isn't really useful.
                    To properly hex-edit a file you really need the precise offset, or a unique hex string to search, plus the new hex values to enter. The Vestel Toolbox thing can't do anything with this particular file
                    I was hoping that someone had a working 24W1433DB and could supply the VESTEL_D1_Plus_PNL.bin from that. I then believe it would be possible to replace the 'bad' file with the 'good' file. I outline how to do that in the OP.
                    In the mean while (2 years now) I have the TV mounted upside down on a generic monitor stand.
                    Jim.
                    • arizanotlari
                      • Nov 2014
                      • 158
                      • Turkiye
                      Hi.
                      Backup panel file and send me, may be i fix it.
                      https://www.badcaps.net
                      • Jim Trent
                        • Feb 2018
                        • 8
                        This one comes from having installed mb90_en.bin (v2.1.9z) for a Toshiba 32W1333B - found in this thread.
                        It works for me a part for the screen being upside down.
                        Jim.
                        • arizanotlari
                          • Nov 2014
                          • 158
                          • Turkiye
                          try 1 first.
                          • Jim Trent
                            • Feb 2018
                            • 8
                            Thanks for that!
                            I've had a look at the files. For OFFSETs : 0x0000A789 + 0x00011CD8 we have these values:
                            Code:
                            0. 310D0A + 85852E0D0A (original)
                            1. 310D0A + EFBFBDEFBD2E0D0A
                            2. 300D0A + EFBFBDEFBD2E0D0A
                            I'd love to know the meaning of those changes
                            Now, I believe the next problem is that, according to my notes from 2 years ago, having replaced the VESTEL_D1_Plus_PNL.bin file you also need to delete something called /conf/panel.bin, then at startup the VESTEL_D1_Plus_PNL.bin file is used to recreate the panel.bin file. Only I have no idea how to delete panel.bin!
                            Is it just a case of using an usb_auto_update_A1.txt file with:
                            rm /conf/panel.bin
                            Is that it, and then panel.bin gets deleted and recreated?
                            Jim.
                            • arizanotlari
                              • Nov 2014
                              • 158
                              • Turkiye
                              This code change screen rotation vertically or/and horizontally.
                              Do you know how to install this files to tv?
                              • Jim Trent
                                • Feb 2018
                                • 8
                                I know how to replace VESTEL_D1_Plus_PNL.bin using 'USB Operations' option on the Sevice menu. But I believe that I also need to delete /conf/panel.bin and I don't know how to do that.
                                Jim.
                                • Diah
                                  • Feb 2013
                                  • 6562
                                  you need to log in the tv by using such Putty or WinSCP on windows platform , via serial USB to TTL, and use the scart socket pin 10 as rx and pin 12 as tx and 13 as GND.
                                  • arizanotlari
                                    • Nov 2014
                                    • 158
                                    • Turkiye
                                    Jim.
                                    this files rewrite panel.bin file. no need to delete local file.
                                    • Jim Trent
                                      • Feb 2018
                                      • 8
                                      Success!
                                      File number 2 has flipped the screen the correct way up. where were you two years ago!
                                      Gold medal to Ariza.
                                      Jim.
                                      • sapciu
                                        Success!
                                        Jim.
                                        Hi
                                        Could you explain step by step how to rotate 180 screen ?
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
