I revived my Toshiba (Vestel) 24W1433DB using the mb90_en.bin file from this thread only now the screen output is upside down. The picture quality is perfect but upside down.
I believe that the panel settings are configured in the file VESTEL_D1_Plus_PNL.bin - does anyone have a working 24W1433DB from where they could take a copy [1] of this file? Or does anyone know how to hack this file to rotate the screen by 180 degrees?
Thanks,
Jim.
[1] This file, and others, can be copied to a USB stick using the 'USB Operations' option on the Service menu. The Service menu can be accesssed from the regular menu by entering 4725 on the remote. If you place an empty txt file on a USB stick called: DownloadPq.mb95, and then trigger the 'USB Operations' option on the Service menu, it will copy a bunch of files to the USB stick, one of which will be: VESTEL_D1_Plus_PNL.bin - I'd really like a copy of that one.
There are other files you can grab too using an empty DownloadProfile.mb95 file, or an empty DownloadSpi.mb95 file. Files can also be written back to the Pq, Profile, and Spi folders. For example, if the USB stick has the folder: 'Profile' containing the file: mb95_hwprofile.bin, and you trigger the 'USB Operations' option this will cause the mb95_hwprofile.bin file on the USB stick to replace the one on the TV. Turning the TV off and on should then load any new file(s).
Thanks,
Jim.
