Sharp LC-LE830u PS problem
  • TVnovice3
    • Feb 2018
    • 7
    The TV doe snot tun on even though there is standby voltage. With no PS_voltage applied, the DC voltage across the two main caps reads over 800VDC (405 is normal I think with PS_ON and about 130 without the PS_On). The voltage slowly drops away to zero if you leave the DIM connected. Any idea where to start looking? Thanks for any leads.
  • nomoresonys
    • 12276
    • U.S.
    Re: Sharp LC-LE830u PS problem
    You are measuring one capacitor at a time right?
      Please verify that your meter is OK and properly set to the correct mode.
      And what did you use for GND ref. for the meter.
      Please also upload good clear pictures of the whole backside of the TV showing all the boards, and then the pictures of the TOP and BOTTOM side of the power supply board.
      • freakaftr8
        • Oct 2012
        • 3743
        Read my old post on this. May have to do the keypad combination. It's on page 3 post 50.
        https://www.badcaps.net/forum/showthread.php?t=31895
        By the way I never did successfully repair the problem. I ended up selling that T V-2 years ago with the new owner knowing how to start it if it gets unplugged.
        On post number 50 I did not mention that you have to hold the 2 buttons while you plug the TV in at the same time
        Do you have a flashing indicator on the front of the TV when you plug it in or is it not doing anything at all?
        • TVnovice3
          • Feb 2018
          • 7
          Yes one at a time. If I apply 3v to PS_on I get all the correct voltages on the main board connector but absolutely nothing in the inverter section. 405 v now on the main caps slowly going back down to 167 (the PS off voltage).
            So you can force on the power supply using the PS-ON pin but if you do not have PS-ON, BL-ON, DIM control signals when power switch is activated, none of those signals toggle high for second?
            BTW, what is the correct model number of this TV?
            Requested pictures?
            • tvguy12012012120
              Samsung UN55NU6900F Standyby voltage is 1V higher than expected, is this a problem?
              by tvguy12012012120
              This is the zombie UN55NU6900F I wrote about in this original post.
              It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
              The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
              1. What could cause the standby voltage to be 1V higher than expected
              2. Is this a problem
              3. Could it have led to the failure at RM819, or was that...
              02-12-2025, 11:22 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • ashan000
              yx-305d bench power supply decreasing voltage problem
              by ashan000
              This power supply is 30v 5amp. Problem is when turned on after about 3 minutes voltage starting to decrease slowly. (like - 5.8 > 5.7 > 5.6 > 5.5) can't see any damaged component or dry solder joints. Checked main 2 transistors with multimeter. Reading seems ok. Tried changing potentiometers(both coarse and fine) still the same situation. Can any one help me to troubleshoot? What voltages to check? Any ideas helps to fix this. thank you.!
              07-12-2025, 08:43 PM
            • rattlesnake
              Voltage issues SY-5SSM, where's the problem? Help needed
              by rattlesnake
              I'm trying to fix this SY-5SSM motherboard (Socket 7).
              When the PSU is connected it powers on by itself but there's nothing on the POST card, no beeps.
              The BIOS EEPROM is ok (latest BIOS was flashed).
              All the jumpers are set ok.
              All the 1000µF 6.3v (14) and 1500µF 16v (2) caps are in spec.
              There are two 76129D MOSFETs (datasheet). I took them out and tested them and they are ok (no continuity from drain to source) in off state.
              But the voltage in the gate of the second 76129D fluctuates between 1.468-1.649,...
              01-26-2025, 11:26 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
