Sanyo LCD-32E30A weak tuner
  • maxvalutech
    • 804
    • australia
    Owner says this set was going OK when stored away for a year or so then when put back into service would not tune stations in properly. The tuner only gets to around 35 - 37% signal strength on known very good antenna input. I checked for anything obvious such as connection and dry joints and also checked PSU outputs which are all as they should be. As the reception is both broken picture and erratic sound it does seem to be purely a tuner problem so I looked for voltages in that area and measured 5v with nothing else showing. Don't know what should be there as my first experience of a tuner was with a "cats whisker" and last look at one was with interlaced fins controlled by a knob!!
  • maxvalutech
    • 804
    • australia
    Re: Sanyo LCD-32E30A weak tuner
    OK managed to find a schematic showing tuner in detail and 5v is correct feed. Now to check associated components and would appreciate any comment on most likely cause of problem.
      • 12274
      • U.S.
      https://www.youtube.com/watch?v=IjX604XB3VA one thing to check.
      • maxvalutech
        • 804
        • australia
        As I sometimes find the schematics can be misleading. On this one I note both pin2 and the last pin are not connected in the set, otherwise I have 5v where it should be but no real idea on following output signal. All earths are good and both resistors in tuner read OK. Pic of tuner section of board posted herewith.
          • 12274
          • U.S.
          https://www.youtube.com/watch?v=FdS239NxIOU your tuner seems to resemble this one, fixed with some added solder.
          • maxvalutech
            • 804
            • australia
            Now certain fault is in tuner itself as I found a couple of old boards with similar tuners and measured continuity from connector centre pin to pin1 on board but not so on this set. Problem is as can be seen in pic that even if I can get the tuner out OK there is a heap of stuff on underside of its board and unless something simple shows I will be no further ahead as I don't have same configuration in tuners I have as spare. Apart from this its a 9 year old set and I sell these going for $50/60.
              • 12274
              • U.S.
              https://www.youtube.com/watch?v=SeKq9YDZMUc replacing tuner, didnt see anyone repairing one other than soldering and repairing connector.
              • mmartell
                • Oct 2013
                • 3189
                Try bypassing the connector and soldering a piece of coax directly to the proper tuner location. Maybe the inside of the connector itself is too dirty for some reason.
                • maxvalutech
                  • 804
                  • australia
                  NI had cleaned inside connector as best I could but no change so today turned tuner itself side on to board by unsoldering the 4 external locating pins. This allowed me to connect to rf input on underside of tuner board but with same result of broken picture and choppy sound. Have now ordered replacement tuner from China as no joy at all when searching for a main board.
                  • DXseekerMO
                    Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
                    by DXseekerMO
                    I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
                    As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
                    09-15-2021, 05:15 PM
                  • Xenon-Codex
                    Sanyo JT760L Tuner station memory
                    by Xenon-Codex
                    What keeps the presets in the memory? There's no battery, but the memory lasts only 1-2 hours without power. Could it be that large capacitor?
                    The thing is a Sanyo JT760L, it has its own power but the signal etc were via a ribbon cable. It now has a RCA-jack....
                    09-08-2021, 11:05 AM
                  • cj_reha
                    Mystery 80s Sanyo cap - perhaps polymer?
                    by cj_reha
                    Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                    01-06-2023, 09:24 AM
                    I need an answer to how to amplify my WiFi signal because it is so weak outside
                    by sam_sam_sam
                    I have a really bad situation right with a very weak WiFi signal outside of the house and I have been told that I can not have two routers on my modem because it cause issues so what is the solution for this issue
                    I can fix the garage door opener with a cat5 cable to device modem or at least that is what I call it and it works very well so far but by doing this I have no router in the garage and no WiFi signal inside the garage unless the door is open but it is extremely weak if not at all
                    The MyQ cameras can NOT hookup to a cell phone hotspot I have tried it need...
                    11-19-2023, 06:23 PM
                  • Ierwin
                    55PFL4908K/12 DVB-S tuner not available
                    by Ierwin
                    I have a rather strange problem with this Philips I just repaired.
                    The set came with startup problems, I checked the PSU, found some puffed caps, replaced them and now it is starting perfectly.
                    According to the philips website this tv should be equipped with a tripple tuner.
                    However there is no option to scan for satellite channels in the menu.
                    It only shows the option to search for DVB-T or DVB-C channels.
                    The set is equiped with the F-type connector in the back so to me it looks like it is indeed equipped with a Sat tuner....
                    11-10-2023, 12:05 PM
