LG 42ln5300 - Only 1 HDMI Input Work
  • caphair
    • Nov 2011
    • 1249
    Bought this TV for $10 with original symptom of no power every now and again but other times powers on fine.
    Did some research and found that many LG sets suffer from bad solder connections under the BGA processor so I reflowed it using a hot air station with lots of flux to the point where I could nudge the chip to confirm all solder had become liquid.
    That got the set turning on everytime but now noticing that only HDMI 2 works and HDMI 1 stays at “no signal”
    Both lead to the main processor that I reflowed, would it still be a bad solder connection or something else?
    Here’s a photo I found of the exact mainbord in my set. Currently have it assembled and since one HDMI works for now don’t have any urgency to take it apart again but I’m curious on any feedback or possibly someone that encountered same issue and resolved it so if HDMI 2 stops working I know where to start looking
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 42ln5300 - Only 1 HDMI Input Work
    Yes this would most likely be a processor problem. Check to make sure all solder connections on the other H DMI port that is not working are properly making connection
    • caphair
      • Nov 2011
      • 1249
      The processor just shorted out randomly while the tv was on. Can these be purchased or entire board needs replacing?
      • diif
        • Feb 2014
        • 6978
        • England
        Yes, they can be bought separately, they are attached by BGA though.
        • caphair
          • Nov 2011
          • 1249
          Do you know where they can be purchased?
          • caphair
            • Nov 2011
            • 1249
            Originally thought this was a backlight issue so I removed the panel and tested the leds. Quesiton, if there were fingerprints on the back of the panel that weren’t wiped off. Will they be visible with the set running?
            • diif
              • Feb 2014
              • 6978
              • England
              I've bought them from Aliexpress, it's possible the fingerprints are visible, I wear nitrile gloves when I am moving screens to avoid any issues.
              • ngth82
                • Jul 2015
                • 541
                Originally thought this was a backlight issue so I removed the panel and tested the leds. Quesiton, if there were fingerprints on the back of the panel that weren't wiped off. Will they be visible with the set running?
                Finger prints, dust and whatever sticks to the inside of the screen and diffuser screens via static.
                I always wear nitrile gloves as well - right after i remove the plastic bezel to prevent any issues. I had finger prints on the first panel i took apart but only noticed it after i reassembled the entire thing.
                -Thomas
                I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                • caphair
                  • Nov 2011
                  • 1249
                  So I found an exact main board replacement on eBay cheap which I purchased. Now with the new one I have different symptoms. No flashing standbylight, no light at all actually and the only voltages I measure now are the two 3.3v.
                  With my original mainboard I get all voltages 3.3v 3.3v 12v 12v and 24v and the standby light would flash twice before going out completely. No backlight flicker at all with either mainboards. Possible I purchased a faulty mainboard?
                    Sounds like the new board is not sending out the PS-ON signal to turn on the rest of the power supplies.
                    You need to check the Voltage on all the pins of the power supply connector that goes to the main board to see what are there and not there.
                    • caphair
                      • Nov 2011
                      • 1249
                      I’m missing the 12v and 24v rails with the replacement
                        We know you are not getting 12v/24v. no PS-ON = no 12V/24V, that is typical topology.
                        But how about the Voltages I am asking for on the power supply connector? We need to know what the Voltages are on the power supply connector that goes to the main board. Read my post #10 again.
                        You should read the LCD TV basic troubleshooting to understand what are required for the TV to work.
                        Show us the pictures of the whole backside of the TV showing how all the boards are connected, then good clear straight shot of the power supply board, the connector should be labeled to tell you what each pin is for.
                        • caphair
                          • Nov 2011
                          • 1249
                          Ok here are some pics. Best I could do right now with lighting. Let me know if you need clearer ones I'll try during the day.
                            https://www.badcaps.net/forum/attach...1&d=1577585031
                            The exposed pins you can see from the top side of the board are the odd number pins (Left column of the pin's chart). To measure the EVEN number pins you will need to use skinny probe to probe the connector at the wire entrance side of the connector, but for now we are interesting in the PWR-ON pin.
                            As you can see, the pin with the black dot is pin one and it is corresponding to 'PWR-ON' (same as PS-ON), it should be around 3VDC for the 12V/24V power supplies to turn on.
                            • caphair
                              • Nov 2011
                              • 1249
                              Ok and the mainboard provides this 3.3v right? So the mainboard has a fault?
                                Main board control that PWR-ON (PS-ON) line.
                                So beside not having PS-ON, what other control signals are you missing?
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  Also missing PDIM and DRV-ON. Do those come on when PWR-ON is high?
                                    They are separated signals.
                                    Bottom line: Your replacement board is bad.
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      Can it be repaired or does this indicate an issue with the microprocessor?
                                      Have another question, found the exact main board but for a 50” lcd half the price even though all components and placement are identical. If I swap eeproms would it work for my 42”?
                                        • 12328
                                        • U.S.
                                        Eeprom there, looks like a match: https://www.shopjimmy.com/lg-42ln530...eprom-only.htm
                                        • s_henya
                                          EPSON EB-X18 No HDMI input
                                          by s_henya
                                          Not my usual equipment repair, Projector works great but no HDMI input.
                                          motherboard: H550MA_R1
                                          HDMI socket was a bit chipped on the side, but no critical damage, i replaced it anyways but still no signal.
                                          Im assuming other damage in the mainboard.
                                          Can anyone give me some pointers on where to begin?...
                                          06-13-2025, 09:06 AM
                                        • rp748
                                          HP E233 display HDMI no input
                                          by rp748
                                          Hi
                                          The display is working great except for the HDMI. VGA, DisplayPort is fine.
                                          i have tried several cables and sources with no luck.
                                          Board number is 715G8912- but i didn't find its schematic anywhere.
                                          The main chip is RTD2526FR which i didn't find its datasheet as well.
                                          Main board looks fine without any blown components or soldering issues.
                                          When an HDMI source is connected the screen goes blank for a few seconds and then it says, "HDMI is inactive" and enters to sleep mode.
                                          Tested Components:
                                          HDMI...
                                          09-02-2023, 10:05 AM
                                        • reessi
                                          LG 42LC55 - Fixed power fault caps, now NO input on HDMI & VGA, also freezes & B/L !
                                          by reessi
                                          This TV had the well known power supply issue, took ages to turn on etc until one day it never turned on, I removed and tested all output caps on the PSU with an ESR meter and replaced the ones I've marked in blue on the photo (they are the new ones).
                                          After this it turns on fine but no signal is displayed when selecting VGA or HDMI 1 & 2 but the laptop always correctly sees the tv and brings up the name and resolution...
                                          My new flatmate assured me the hdmi's had previously worked after waiting a long time for the TV to turn on but he...
                                          04-30-2021, 04:28 AM
                                        • japlytic
                                          Not all TVs can handle surround sound on a HDMI input
                                          by japlytic
                                          With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
                                          So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
                                          08-31-2022, 10:09 PM
                                        • ugamazing
                                          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                          by ugamazing
                                          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                          04-10-2024, 08:06 AM
