LG 42ln5300 - Only 1 HDMI Input Work
  • nomoresonys
    • 12331
    • U.S.
    Re: LG 42ln5300 - Only 1 HDMI Input Work
    $9.95 there: https://www.ebay.com/itm/LG-42LN5300...MAAOSwHgVW7EuY
    • caphair
      • Nov 2011
      • 1249
      Response to this question?
      “ Have another question, found the exact main board but for a 50” lcd half the price even though all components and placement are identical. If I swap eeproms would it work for my 42”?”
      If so I already have the eeprom from my original board
      • nomoresonys
        • 12331
        • U.S.
        https://www.ebay.com/itm/Main-Board-...AAAOSw3vNdI1Oc
        • nomoresonys
          • 12331
          • U.S.
          Good question, I'm not sure if it would, I myself would grab an eeprom from ebay and throw it on there, there seems to be quite a few on ebay, must be some demand for them.
          • nomoresonys
            • 12331
            • U.S.
            Do the numbers on the white stickers on both mainboards match?
            • nomoresonys
              • 12331
              • U.S.
              #26
              This is just a for instance, the part number on the sticker starts with EBR, does it match with your sticker number?: https://www.ebay.com/itm/LG-50LN5300...0/262649206895
              • nomoresonys
                • 12331
                • U.S.
                #27
                Poses the question, how do you know that your eeprom is good?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  Can it be repaired or does this indicate an issue with the microprocessor?
                  Maybe just the eeprom, I've poked about a few mainboards and some have an i2c eeprom with the model type in. It depends what else is on the motherboard.
                  • caphair
                    • Nov 2011
                    • 1249
                    #29
                    They're different but every component and layout looks identical
                    • nomoresonys
                      • 12331
                      • U.S.
                      #30
                      Not sure, maybe start by checking if they both take the same firmware, is that yours there? see if it also applies to the 50: https://www.lg.com/us/support/product/lg-42LN5300.AUS
                      • s_henya
                        EPSON EB-X18 No HDMI input
                        by s_henya
                        Not my usual equipment repair, Projector works great but no HDMI input.
                        motherboard: H550MA_R1
                        HDMI socket was a bit chipped on the side, but no critical damage, i replaced it anyways but still no signal.
                        Im assuming other damage in the mainboard.
                        Can anyone give me some pointers on where to begin?...
                        06-13-2025, 09:06 AM
                      • rp748
                        HP E233 display HDMI no input
                        by rp748
                        Hi
                        The display is working great except for the HDMI. VGA, DisplayPort is fine.
                        i have tried several cables and sources with no luck.
                        Board number is 715G8912- but i didn't find its schematic anywhere.
                        The main chip is RTD2526FR which i didn't find its datasheet as well.
                        Main board looks fine without any blown components or soldering issues.
                        When an HDMI source is connected the screen goes blank for a few seconds and then it says, "HDMI is inactive" and enters to sleep mode.
                        Tested Components:
                        HDMI...
                        09-02-2023, 10:05 AM
                      • reessi
                        LG 42LC55 - Fixed power fault caps, now NO input on HDMI & VGA, also freezes & B/L !
                        by reessi
                        This TV had the well known power supply issue, took ages to turn on etc until one day it never turned on, I removed and tested all output caps on the PSU with an ESR meter and replaced the ones I've marked in blue on the photo (they are the new ones).
                        After this it turns on fine but no signal is displayed when selecting VGA or HDMI 1 & 2 but the laptop always correctly sees the tv and brings up the name and resolution...
                        My new flatmate assured me the hdmi's had previously worked after waiting a long time for the TV to turn on but he...
                        04-30-2021, 04:28 AM
                      • japlytic
                        Not all TVs can handle surround sound on a HDMI input
                        by japlytic
                        With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
                        So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
                        08-31-2022, 10:09 PM
                      • ugamazing
                        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                        by ugamazing
                        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                        04-10-2024, 08:06 AM
