42LK450-UB Noob question
+ More Options
Posts
  • NanoTesting
    Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
    by NanoTesting
    I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
    With charger it turns on, fan spins but gives no image.
    Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
    Reflashed BIOS, same problem.
    Replaced both main mosfets.
    Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
    10-30-2024, 10:48 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • reset1986
    MacBook A1278 main 820-2530b not charge, it turns on only with battery
    by reset1986
    hi, I have this macbook that works correctly with battery inserted, if I connect the power supply the light turns green but it does not charge, if I disconnect the battery and connect only the power supply the light turns green and the mac enters the ignition loop 4/5 sec, turns off and repeats itself,
    on the motherboard there are no traces of liquid or damaged components,
    I tested the 3.42 and they are constant both with power supply and with battery,
    advice on what signs I can start checking?
    the power supply indicator light never turns orange,
    power...
    10-26-2021, 02:46 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
