Samsung UE40ES5700S blinks 5x2 in loop
  • fluxflux
    • Mar 2017
    • 46
    • @MyCountry
    #41
    Re: Samsung UE40ES5700S blinks 5x2 in loop
    Just mapped the connections between the Mainboard and the T-Con.
    51 ????
    50 ????
    49 ????
    48 ????
    47 ????
    46 ???? (NC)
    45 GND
    44 GND
    43 GND
    42 ODD_TX0-
    41 ODD_TX0+
    40 ODD_TX1-
    39 ODD_TX1+
    38 ODD_TX2-
    37 ODD_TX2+
    36 GND
    35 ODD_TXCLK-
    34 ODD_TXCLK+
    33 GND
    32 ODD_TX3-
    31 ODD_TX3+
    30 ODD_TX4- (NC)
    29 ODD_TX4+ (NC)
    28 GND
    27 EVEN_TX0-
    26 EVEN_TX0+
    25 EVEN_TX1-
    24 EVEN_TX1+
    23 EVEN_TX2-
    22 EVEN_TX2+
    21 GND
    20 EVEN_TXCLK-
    19 EVEN_TXCLK+
    18 GND
    17 EVEN_TX3-
    16 EVEN_TX3+
    15 EVEN_TX4- (NC)
    14 EVEN_TX4+ (NC)
    13 GND
    12 PANEL_SCL
    11 ????
    10 ???? (NC)
    09 PANEL_VCC
    08 PANEL_SDA
    07 GND
    06 ????
    05 ???? (NC)
    04 ???? (NC)
    03 ???? (NC)
    02 ???? (NC)
    01 ???? (NC)
    Does sonmeon know the ???? (see also atachement)
    • fluxflux
      • Mar 2017
      • 46
      • @MyCountry
      #42
      Just found this :-) for the 46"
      https://www.electronica-pt.com/esque...d5500-r-32807/
      But this is not really matching mine (Isn't it?). Compare SDA/SCL for example
      Found out that
      51 - 47 is Panel VCC 12V
      09 was 3,3 V when the set was on (if I remember correct).
      • fluxflux
        • Mar 2017
        • 46
        • @MyCountry
        #43
        Atached the updated mapping
          • 12206
          • U.S.
          #44
          https://www.ebay.com/itm/Samsung-LCD...0AAOSw1vlUr8~Q
          This could be good, especially for the harder to find mainboards.
          • fluxflux
            • Mar 2017
            • 46
            • @MyCountry
            #45
            Hi nomoresonys,
            thank you. Sending the board to the US and back will be also too expensive. The seller also "May not ship to Germany" according to the shipping description. In Europe there are also people who offer the repair of a Samsung bord. Most times they reflow the BGA or they swap the NAND / EEPROM for ~80 Euro. Prices for a new D5700 Mainboard are rising. Just seen someone wants 129,-- Euro for a used board. Crazy.
            kr
            fluxflux
            • fluxflux
              • Mar 2017
              • 46
              • @MyCountry
              #46
              just attached a V.56 from Banggood with such a LVDS Cable . Beware, you need the "right" one.
              Here and here are good sources for knowledge seekers.
              I've had some 5 Key pad laying around from such a lvds controller.
              v.56 Firmwares Link 1
              v.56 Firmwares Link 2 from this site
              I've also added the Samsung SmartTV logo as bootlogo.
              Next steps will be to connect "somehow" the original D5700 keypad to the V.56 board and also connect the Samsung Power Supply as currently I have two power cords to the set. Do you know how?
              Note:
              You have to change the LVDS mapping to 0 via the Service Menu (1147 on the remote)
              Also flip the picture (Mirroring via the Service Menu)
              The CPU is getting hot. I will add a heatsink.
              The IR is sticked to some jumperwire. Those wires are soldered to the bottom pins of the V.56
              I've added the Firmware I've used as attachement
              Cheers
              fluxflux
              • vinceroger69
                • Mar 2012
                • 6714
                #47
                Note:
                Cheers
                fluxflux
                Hi i have just been looking at these universal boards on ali express i see they do a digital Aeriel type and a analogue Aeriel type so thats good as analogue has finished here in the uk also how did you add the smart tv logo too it was it easy?
                  • 12206
                  • U.S.
                  #48
                  Looks like you're making great progress, wonder what's making the cpu get hot.
                  • fluxflux
                    • Mar 2017
                    • 46
                    • @MyCountry
                    #49
                    @vinceroger69
                    It was Easy. Got the Info from here
                    1. Take a JPEG and store it on a thumb drive
                    2. Change Source to MEDIA on the V.56
                    3. Select the picture -> scroll right -> select "capture".
                    Thats it.
                    @nomoresonys
                    I think it's the Full HD resolution. As these types of boards are primary used for turning an old LCD/LED Monitor to a TV the most computer panels have lower resolutions.
                    There are also Mainboard on the market with LAN/DVB-S2/DVB-T2/ANDROID...
                    As said; I had the old V.56 boards laying aroud as I got them for a few bucks on banggood sale.
                    For me the time paying unrealistically high prices for used mainboards are over.
                    Example 1 : ZL.VST.3463GSA.LB
                    Example 2: T.V56.81
                    Example 3: MSD628V6.0
                    • fluxflux
                      • Mar 2017
                      • 46
                      • @MyCountry
                      #50
                      @vinceroger69
                      Thats it.
                      @nomoresonys
                      Example 2: T.V56.81
                      Example 4: TP.MS338.PB801 and here a video (all in one board with PSU and SSB and LED driver)
                        So how do you adjust the backlights level? I do not see any interface between the backlights circuit and this new main board, or turning the power supply board on and off.
                        Great works getting the interface to work.
                          • 12206
                          • U.S.
                          #52
                          @vinceroger69
                          Thats it.
                          @nomoresonys
                          Example 2: T.V56.81
                          +1
                          WIZARDRY
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #53
                            maybe from 9.00 minutes in on this video budm shows it on the screen in a setting menu
                            https://www.youtube.com/watch?v=w20h...YioeUwvS1Uen_s
                              OK, I see that the connector by the DC jack is being used in the Video.'
                              I did not see that in OP picture.
                              https://www.badcaps.net/forum/attach...5&d=1520892991
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #55
                                This is a better video budm it shows where there soldering the wires too on the reverse of the pcb although i did not see anything regarding the back light levels although it is in the service menu
                                https://www.youtube.com/watch?v=QzXp...1Uen_s&t=1394s
                                • fluxflux
                                  • Mar 2017
                                  • 46
                                  • @MyCountry
                                  #56
                                  I have not yet done it. That's one of my "next steps"
                                  Currently I have two seperate Power Cords (12V AC-DC to the V.56) and the original PSU. I'm not sure if the Samsung PSU can deliver the 4A current that is needed by the V.56. Have to measure it. I belive that the 4A is used if the V.56 delivers the 12V to the LCD Backlight inverters only. So I need to somehow wire the V.56 to the PSU that this one starts up and activates the LED Backlight.
                                  Found some other intresting video. ;-)
                                  This shows an V.56 implemntation into a 42" LCD
                                  Will keep you updated.
                                  • fluxflux
                                    • Mar 2017
                                    • 46
                                    • @MyCountry
                                    #57
                                    Here's the update:
                                    Original IR Sensor works
                                    Original LED works for triggering Remote Control buttons.
                                    The Power indicator LED does not work.
                                    Original touch sensitive buttons do not work (as they are chip controlled)
                                    Backlight power on works
                                    Backlight dimming does not work! (I see the Voltages change on my DMM - but it does not have any impact on the Backlight)
                                    The PSU is always on as there is no quick standby solution possible.
                                    The V.56 needs always 12 V for Standby. But if I put the Samsung PSU into standby mode there are no 12 V present (Henn Egg Problem)
                                    Will do a video later the day.
                                    Next steps:
                                    Drill some holes for Micro Buttons to the Backcover.
                                    Attach a Power Switch to the Backcover.
                                    • naoume500
                                      • Apr 2019
                                      • algeria
                                      #58
                                      thaaaaaaaaaaank's
                                      • Takeatry
                                        Yet another Samsung QLED Boot Loop
                                        by Takeatry
                                        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                        10-04-2024, 02:57 PM
                                        09-07-2024, 05:50 AM
                                      • Nairolf
                                        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                        by Nairolf
                                        I have a Samsung DM32D display.
                                        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                        Here’s what I have tried so far:
                                        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                        From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                        Yesterday, 03:47 AM
                                      • eigma
                                        Samsung UN40H5003 boot loop every ~8 seconds
                                        by eigma
                                        Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                        Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                        SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                        Main board: BN94-07592P / BN97-08922R...
                                        11-20-2024, 10:31 PM
                                      • brkie
                                        Samsung UE75TU6905 reboot loop
                                        by brkie
                                        I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                                        I read on Samsung's website (reviews)...
                                        09-04-2024, 01:45 AM
