LG 50UH5500-UA - No picture
  • diif
    • Feb 2014
    • 6978
    • England
    Re: LG 50UH5500-UA - No picture
    Originally posted by nwcs
    I found that two of the wires one led- and one led+ were unseated from the power supply. After making sure they were in the tv now has backlight but one side is darker than the other. I hope it is not a bad panel and think it might be a bad tcon. Does any one have a suggestion?
    Looks like half of the panel isn't illuminated. It's not the tcon.
    • emersonvier
      • Apr 2019
      I only need one bar, someone could give a tip where can I buy?
      • nwcs
        • Dec 2015
        • 311
        • usa
        I will check at my shop tomorrow and let you know if I have it. Could you give me the Part number of the one you need.
        • nomoresonys
          • 12331
          • U.S.
          Nice thread, so in this model it looks like it failed the flashlight test BUT was still a bad led in backlights, that's GOOD info. and should help a lot of people with similar issues.
          • neilc6
            • Nov 2015
            • 1550
            I don't even do a flashlight test. If a LED TV fails to turn on without backlight or backlight flashes on power up, I will suspect a bad LED and can probe the LED connection with my LED tester or open it up. LG LN, LA & LB series, Samsung EH and H series, any RCA, Hisense, Haier, or Insignia. Currently 2014 model years are the most common.
            • emersonvier
              • Apr 2019
              The PN 5835-W50002-2P00.
              I found in several places complete package (12 bars) around 69$.
              • Charleyd
                • Aug 2016
                • 42
                I've had two of these same LG's. Identical symptoms. No image with flashlight. One LED failed open. Unless you are fixing the TV for yourself, I recommend replacing the full set of backlights with NEW. 10% savings at shopjimmy through the end of April. And reduce backlight setting!
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • mrautom8
                  Samsung TV UN75H6350AFXZC main board schematics?
                  by mrautom8
                  Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                  Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                  While relay is on, all voltage rails are present and steady (scoped) on main board.
                  I love a good logic puzzle but getting lost without any schematics.
                  No shorts on ANY capacitor main board.
                  Thermal camera shows 3.3V inductor getting warm instantly but...
                  10-19-2025, 06:32 PM
