LG 50UH5500-UA - No picture
  • diif
    • Feb 2014
    • 6978
    • England
    Re: LG 50UH5500-UA - No picture
    Originally posted by nwcs
    I found that two of the wires one led- and one led+ were unseated from the power supply. After making sure they were in the tv now has backlight but one side is darker than the other. I hope it is not a bad panel and think it might be a bad tcon. Does any one have a suggestion?
    Looks like half of the panel isn't illuminated. It's not the tcon.
    • emersonvier
      • Apr 2019
      I only need one bar, someone could give a tip where can I buy?
      • nwcs
        • Dec 2015
        • 311
        • usa
        I will check at my shop tomorrow and let you know if I have it. Could you give me the Part number of the one you need.
          • 12081
          • U.S.
          Nice thread, so in this model it looks like it failed the flashlight test BUT was still a bad led in backlights, that's GOOD info. and should help a lot of people with similar issues.
          • neilc6
            • Nov 2015
            • 1550
            I don't even do a flashlight test. If a LED TV fails to turn on without backlight or backlight flashes on power up, I will suspect a bad LED and can probe the LED connection with my LED tester or open it up. LG LN, LA & LB series, Samsung EH and H series, any RCA, Hisense, Haier, or Insignia. Currently 2014 model years are the most common.
            • emersonvier
              • Apr 2019
              The PN 5835-W50002-2P00.
              I found in several places complete package (12 bars) around 69$.
              • Charleyd
                • Aug 2016
                • 42
                I've had two of these same LG's. Identical symptoms. No image with flashlight. One LED failed open. Unless you are fixing the TV for yourself, I recommend replacing the full set of backlights with NEW. 10% savings at shopjimmy through the end of April. And reduce backlight setting!
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
