AWA JTM32K212A-T ir sensor
  • maxvalutech
    • 804
    • australia
    The set works aok with buttons on set. It came without remote and I have tried two different brands universal remotes on it with no result whatsoever. I know these remotes are working OK otherwise. So question is there any easy check I can do - the standby led is getting current and changes colour OK.
    Re: AWA JTM32K212A-T ir sensor
    You can use DC meter connect between GND and Signal pin the use the remote to see if you will see any Voltage fluctuation when you activate the remote, this does not mean it is putting out the correct signal but it showing if the IR module is active or not. You can also try the same test on other TV IR receiver to get some idea how much fluctuation you will get from working IR module.
    You do have DCV at the VCC pin of the IR module, right?
    • maxvalutech
      • 804
      • australia
      Thanks budm yes there is 5v on IR pin and this fluctuates when pwr button activated on remote. Must just have an odd set which these universal remotes don't suit but that is unusual.
      • R_J
        • 9555
        If the universal remote has a find code function, where you can step through them untill it finds it, that might work better than just punching in a code
        • maxvalutech
          • 804
          • australia
          Did run them both through auto search but no power off reaction. Set wasn't connected to a signal but channel number it was last on came up a couple of times. That was probably just the way it works unless remote was activating "info".
          • CapLeaker
            AcuRite 5 in 1 temperature sensor replacement repair
            by CapLeaker
            Got a new victim:
            AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
            A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
            B: stuck at some temperature and maybe updating once in 12 hrs or so.
            Easy solution is to go to AcuRite website and purchase the sensor. Right?...
            04-15-2025, 01:32 PM
          • Jackching
            Hisense 65R6107 remote sensor
            by Jackching
            Does anyone know if there is a repair for the remote sensors for these televisions? It only seems to work when it wants to. I tried a different remote and also tried factory resetting the TV. I find if i go close to the sensor that it'll work but outside 2 feet it wont.
            10-30-2023, 11:35 AM
            Lenovo ThinkPad T14 + Universal USB-C Dock Notebook T Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad T14 + Universal USB-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T14 + Universal USB-C Dock boardview and T14 + Universal USB-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-07-2024, 05:00 AM
