lg tv 42lv450 does not start
  • freakaftr8
    • Oct 2012
    • 3743
    Re: lg tv 42lv450 does not start
    When you replace the main board remove that resistor. There's a possibility that the main board during the resistor test went from bad to worse
    • freakaftr8
      • Oct 2012
      • 3743
      Also did you make sure that you put the Wire back in its socket for DRV-ON connector?
      Yes he bypassed the power on forcing it on however now you get no LG logo or backlights. Before it would display logo and then shut off but now got worse. You can try heating up the main board with a hairdryer and see if it comes on
      • Moddingscreen
        • Dec 2017
        • 65
        • Italia
        #43
        I put everything as it was, so if I buy a new motherboard it should work the tv? does the power supply card work?
        • freakaftr8
          • Oct 2012
          • 3743
          The power supply appears to be operating so far.
          • Moddingscreen
            • Dec 2017
            • 65
            • Italia
            #45
            Reflow bga?
            • freakaftr8
              • Oct 2012
              • 3743
              You could try before ordering a new board
              • Moddingscreen
                • Dec 2017
                • 65
                • Italia
                #47
                do i have to remove the power on from 3.5? after reflow?
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Yes if you like. But maybe leave it for now to see if you get a picture.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Note that this could also be an EEPROM issue. No amount of reflow will fix that.
                    • Moddingscreen
                      • Dec 2017
                      • 65
                      • Italia
                      #50
                      is clear, but if I change motherboard then I always have problems with the eprom? can I mount that of another but identical model?
                      • Moddingscreen
                        • Dec 2017
                        • 65
                        • Italia
                        #51
                        run reflow but nothing has changed, another question and then do not bother you anymore, I ordered the motherboard found for the same model of TV, mounting the new one I have to remove the resistance from 1ohm from power on? thank you for your time
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Yes. Don't have that resistor there with new board.
                          • Moddingscreen
                            • Dec 2017
                            • 65
                            • Italia
                            #53
                            thanks again I will keep you updated
                            • Moddingscreen
                              • Dec 2017
                              • 65
                              • Italia
                              #54
                              can I install this main? the product code is different but the data is identical
                              • Moddingscreen
                                • Dec 2017
                                • 65
                                • Italia
                                #55
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  I'm not to sure I can't read the data on the 2nd picture. If they have a return policy could probably get away if it doesn't work
                                  • Moddingscreen
                                    • Dec 2017
                                    • 65
                                    • Italia
                                    #57
                                    thanks again for your help, the original card has the following serial: eax64113202 (0). I would like to mount the following model: eax64290501 (0). what data do you need?
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Sometimes even if the model number of the TV is the same they may have changed panels or some other significance throughout the model year. Sometimes those numbers change sometimes you get lucky and it works anyway
                                      So the model number of the TV the board is coming out of is the same as yours?
                                      • Moddingscreen
                                        • Dec 2017
                                        • 65
                                        • Italia
                                        #59
                                        the model of my tv is the following: LG 42LV450A-ZC. while that of the card I would like to buy is this: LG 42LV450U-ZC. practically changes (A) and (U)
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          That's interesting that it's in front of the character designator after the- Usually anything That has to do with the model number before the hyphen usually means a product change. Like I said before the least you could do is try it if it doesn't work return it.
                                          I have used Samsung main boards that were for a year difference same size and swapped T cons between 2 different models with no problem before so you may get lucky
                                          • mohsinrizwan
                                            LG TV 49LW5700 does not power no Standby Voltage(PSU EAX62865401)
                                            by mohsinrizwan
                                            I have LG 49LW5700 which is not turning on, when I checked there was no standby (3.5V) can anyone guide how I can trace which component is faulty.
                                            05-28-2022, 10:35 AM
                                          • mohsinrizwan
                                            LG TV 47LW5500 does not power on (PSU EAX62865401/Main board EAX64405501)
                                            by mohsinrizwan
                                            My LED died while checking on PS-ON test not seeing any voltage.
                                            Here is result on PS-ON Pin 1 jump to Ping 9-10-11 or 12 (3.5V)
                                            23 - N.C -> 0V | 24 - ERROR -> 0V
                                            21 - 12V -> 0V | 22 - PWM -> 0V
                                            19 - 12V -> 0V | 20 - N.C -> 0V
                                            17 - 12V -> 0V | 18 - DRV-ON -> 0V
                                            15 - GND -> 0V | 16 - VSYNC -> 0V
                                            13 - GND -> 0V | 14 - GND -> 0V
                                            11 - 3.5V -> 3.52V | 12 - 3.5V -> 3.52V
                                            9 - 3.5V -> 3.52V...
                                            08-02-2020, 01:53 PM
                                          • desone01
                                            Changing Dell Asset Tag
                                            by desone01
                                            I have dug through my Dell utilities and located an old Dell Engineer's program which changes the Dell Asset Tag. I have used this SUITE of programs in the past to amend the Asset Tag on second hand motherboards I have installed.
                                            I don't know if it works with the newer Dell laptops. You should use extreme caution in using these programs. As you can see the program is fairly old one.
                                            Here are the instructions from the README file:
                                            SVCTAG.EXE
                                            Dell Internal Use
                                            09-04-2020, 07:33 PM
                                          • atari1968
                                            LG TV 42LW5700 does not power on fully (PSU EAX62865401/Main board EAX64405501)
                                            by atari1968
                                            My LG 42LW5700 doesn't power on. when tv plugged on the standby light is
                                            a very week until I switch power on then the standby light blinking slowly.
                                            After checking the power supply,
                                            I measured the output voltage after switch on and everything looks okay
                                            Please see the attached picture of the voltage test for the output ports.
                                            So probably the power supply is ok and the problem could be on the mainboard EAX64405501,
                                            The standby led is always very dim until I switch on and then the led start to blink (high and dim not in the same...
                                            08-16-2019, 08:20 AM
                                          • Flasman90
                                            Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
                                            by Flasman90
                                            Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
                                            My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
                                            What I have done so far:
                                            - All of the routine diagnostic methods including...
                                            08-29-2025, 08:38 AM
