lg tv 42lv450 does not start
  • freakaftr8
    • Oct 2012
    • 3743
    Re: lg tv 42lv450 does not start
    You did remove the Pin from the connector at the main board 1st right for DRV-ON?
    • Moddingscreen
      • Dec 2017
      • 65
      • Italia
      but if I unplug the connector from the motherboard how do I turn on the TV?
      • freakaftr8
        • Oct 2012
        • 3743
        You will not be unplugging the whole connector just the individual pin for that DRV-ON. You can use a knife tip To pull up the plastic tab what that will allow the pin to come out
        • Moddingscreen
          • Dec 2017
          • 65
          • Italia
          I did not understand, do I have to cut it?
          • Moddingscreen
            • Dec 2017
            • 65
            • Italia
            now I understand sorry, but the DRV is not the first to the right does not do anything? Here's the picture
            • Moddingscreen
              • Dec 2017
              • 65
              • Italia
              #26
              I tried to disconnect the pin as pictured and the TV turns on and remains the black screen, if I try to disconnect the 1st right from the motherboard the TV does not turn on has the initial problem or red led flashing white flashing and then nothing
              • Moddingscreen
                • Dec 2017
                • 65
                • Italia
                #27
                nothing I also removed the DRV ON 3.5v the relay snaps but the TV does not stay lit red LED that flashes, after the flashing white and after no LED help
                • Moddingscreen
                  • Dec 2017
                  • 65
                  • Italia
                  #28
                  Help me! Please
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    So what your saying is back to trhe way it was with no DRV-ON connected and pin back the way it was your not getting any backlights?
                    • Moddingscreen
                      • Dec 2017
                      • 65
                      • Italia
                      #30
                      practically with the jumper between pwr on and 3.5 volts the tv first showed the LG logo. Now always with only the jumper between PWR ON and 3.5 volts the TV does not start, the red LED flashes, the white flashes and then goes off
                      • Moddingscreen
                        • Dec 2017
                        • 65
                        • Italia
                        #31
                        The DVR ON I removed it from 3.5 volts
                        • Moddingscreen
                          • Dec 2017
                          • 65
                          • Italia
                          #32
                          with only the PWR ON at 3.5v the TV turned on and for a few seconds showed as photos
                          • Moddingscreen
                            • Dec 2017
                            • 65
                            • Italia
                            #33
                            while now the relay is triggered the red LED lights up, after the white led and then dies
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              So do you get the LG logo now or not?
                              • Moddingscreen
                                • Dec 2017
                                • 65
                                • Italia
                                #35
                                No, I'm at the starting point with the only difference that before the relay did not attack, now it attacks but the TV does not start
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  With the DRV-ON removed?
                                  • Moddingscreen
                                    • Dec 2017
                                    • 65
                                    • Italia
                                    #37
                                    exactly
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      You have a mainboard problem. Most likely the main processor on the board or a voltage regulator not sending PWR-ON. Id try replacing mainboard
                                      • Moddingscreen
                                        • Dec 2017
                                        • 65
                                        • Italia
                                        #39
                                        but because before he could make me display the LG logo and now not?
                                        • Moddingscreen
                                          • Dec 2017
                                          • 65
                                          • Italia
                                          #40
                                          but the power on in this way is not bypass?
                                          • mohsinrizwan
                                            LG TV 49LW5700 does not power no Standby Voltage(PSU EAX62865401)
                                            by mohsinrizwan
                                            I have LG 49LW5700 which is not turning on, when I checked there was no standby (3.5V) can anyone guide how I can trace which component is faulty.
                                            05-28-2022, 10:35 AM
                                          • mohsinrizwan
                                            LG TV 47LW5500 does not power on (PSU EAX62865401/Main board EAX64405501)
                                            by mohsinrizwan
                                            My LED died while checking on PS-ON test not seeing any voltage.
                                            Here is result on PS-ON Pin 1 jump to Ping 9-10-11 or 12 (3.5V)
                                            23 - N.C -> 0V | 24 - ERROR -> 0V
                                            21 - 12V -> 0V | 22 - PWM -> 0V
                                            19 - 12V -> 0V | 20 - N.C -> 0V
                                            17 - 12V -> 0V | 18 - DRV-ON -> 0V
                                            15 - GND -> 0V | 16 - VSYNC -> 0V
                                            13 - GND -> 0V | 14 - GND -> 0V
                                            11 - 3.5V -> 3.52V | 12 - 3.5V -> 3.52V
                                            9 - 3.5V -> 3.52V...
                                            08-02-2020, 01:53 PM
                                          • desone01
                                            Changing Dell Asset Tag
                                            by desone01
                                            I have dug through my Dell utilities and located an old Dell Engineer's program which changes the Dell Asset Tag. I have used this SUITE of programs in the past to amend the Asset Tag on second hand motherboards I have installed.
                                            I don't know if it works with the newer Dell laptops. You should use extreme caution in using these programs. As you can see the program is fairly old one.
                                            Here are the instructions from the README file:
                                            SVCTAG.EXE
                                            Dell Internal Use
                                            09-04-2020, 07:33 PM
                                          • atari1968
                                            LG TV 42LW5700 does not power on fully (PSU EAX62865401/Main board EAX64405501)
                                            by atari1968
                                            My LG 42LW5700 doesn't power on. when tv plugged on the standby light is
                                            a very week until I switch power on then the standby light blinking slowly.
                                            After checking the power supply,
                                            I measured the output voltage after switch on and everything looks okay
                                            Please see the attached picture of the voltage test for the output ports.
                                            So probably the power supply is ok and the problem could be on the mainboard EAX64405501,
                                            The standby led is always very dim until I switch on and then the led start to blink (high and dim not in the same...
                                            08-16-2019, 08:20 AM
                                          • DrewPhillips
                                            SFX PSU - Need High Current on 3.3V & 5V Rails?
                                            by DrewPhillips
                                            I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
                                            The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
                                            02-18-2025, 01:03 PM
