Soniq L32V12A 32" LCD - Flickering Screen - when cold
    Hi
    So my out laws have had this LCD for several years now.
    It was given to me as it wasn't turning on, ie: it would get the Soniq tune, but no picture.
    I found the SMD fuse on the TCON board was intermittent/open, so replaced that, and we now get a picture. However, the picture is not constant....at least, not until we've warmed up.
    When the machine is cold, its unstable and the picture flickers.....when its warm, its solid and on, no issues.
    It has the infamous 1117 SM regulators, however, they seem to be doing a good job and working fine, ie: those with 5V supply give a 3.4V constant and the one with a 3.4v supply gives a 1.898v supply.
    Theres a couple of previous posts about the ribbon cables not being the best and sure, when you move them hot OR cold the picture flickers. But when left alone, all is well.
    I'm leaning towards caps/filtering supply issues which don't come good until they have warmed up. Whats folks thoughts here? Is my diagnosis on the right track?
    Thanks in advance,
    Re: Soniq L32V12A 32" LCD - Flickering Screen - when cold
    Not my favourite set for sure however possibly a dry joint so selective heat treatment at switch on may pin point the problem area. Hair dryer thru small funnel or the like on these small boards.
      You should not get flicker when moving cables
        Dskall correct and with bad fuse on t-con the set may be telling us something.
          Did you watch this video?
            what video dskall?
            i had it running for a while this morning and it went blank completely (backlight on, no picture) while it was warm.
            something definately not right here.
            nothing like an intermittent fault to keep you on your toes
              maybe this video?
              https://www.youtube.com/watch?v=9nSK-BwMzXw
                Sorry forgot to inset link: https://www.youtube.com/watch?v=orFkIXO0uUI
                  thanks vinceroger. i've flashed the firmware and the energy saving mode is off. ironically i've just powered it up and was running with no flickering at all. now its started flickering after about 3 minutes of being powered on.
                  dskall ; yes ; i've seen that video with dave. thats the exact model of flamin TV mate that i have ere. i replaced that stupid fuse as well with the exact same one i ordered from element14 here. i'll try that with the TCON and ribbon cable, i do agree with him the connection into the TCON board is pretty shithouse.
                  as it stands the thing has an entirely blank screen at the moment. grrr.
