Sanyo DP50749 not switching on
  • Chuper
    • Sep 2017
    • 36
    With everything connected when you press power button relay clicks, the green light comes for about 3-4 seconds, relay clicks light goes away, in one second tries again, clicks, green light comes for 3-4 seconds, clicks, light goes away.
    At this moment on the PSU BN44-00274A:
    Connector CN802 has:
    Pin1 - 5.3V - 0V
    Pin2 - 5.3V - 0V
    Pin3 - GND
    Pin4 - GND
    Pin5 - PS_ON - 3.058V
    Pin6 - VS_ON - 0V
    Connector CN801 has:
    Pin1 - PS_ON - 3.058V
    Pin2 - VS_ON - 0V (no connected wire)
    Pin3 - STBY - 5.285V
    Pin4 - GND_STBY
    Pin5 - GND_15Vmp (no connected wire)
    Pin6 - GND_15Vmp
    Pin7 - 15Vmp - 0V
    Pin8 - 15Vmp - 0V
    Pin9 - GND_5.3V (no connected wire)
    Pin10 - GND_5.3V
    Pin11 - GND_5.3V
    Pin12 - GND_5.3V
    Pin13 - 5.3V - 0V
    Pin14 - 5.3V - 0V
    Pin15 - 5.3V - 0V
    Pin16 - 5.3V - 0V
    Pin17 - GND_15V (no connected wire)
    Pin18 - GND_15V (no connected wire)
    Pin19 - 15V - 0V (no connected wire)
    Pin20 - GND_15V
    Pin21 - 15V - 0V (no connected wire)
    Pin22 - 15V - 0V
    Pin23 - N.C (AC_DET) - 5.266V
    Pin24 - N.C (Vt) - (no connected wire)
    Visual check gives no burned elements. All fuses are good.
    I found a service manual and the procedure of eliminating Main Signal Board. I did that with no luck meaning TV is not generating internal patterns without the Main Signal Board attached. So here during this test relay clicks ones (stays on) and in my understanding the PSU must be on. On three big capacitors CP801, CP802, CP803 I only got 158.2V across them. On the DX807 - 5.285V; on DX806 - 27V(must be 15V I guess), DS801 - 0.2V (must be Va with is 55V), DS825 - 0V (must be Vs wich is 210V).
    So the question is should I order a power supply? Or someone on here will help me track the problem down?
    Re: Sanyo DP50749 not switching on
    Does PS-ON Voltage change state when power switch is toggled on and off?
    Power supply board is SAMSUNG BN44-00274A.
    Most SAMSUNG Plasma power supply uses active low for PS-ON, MEANING <1V = ON, >2V = OFF.
    Please upload the service manual.
    • Chuper
      • Sep 2017
      • 36
      PS_ON does change it's value to low 0.022Vdc for those 3-4 seconds.
      • dskall
        • Oct 2016
        • 2905
        • usa
        If you cannot generate test pattern. Most likely power supply. Repair kits available
        • dskall
          • Oct 2016
          • 2905
          • usa
          I have this same TV. I have found the 3.3v regulator is about 2.7v. Ic 1630 P.47 in above SM. I removed it and applied 3.3v externally and tv works. My question. It is a sharp 5 terminal regulator and is a little difficult to find. Can I use a common 3.3v reg. to replace. Or other substitute. I believe one terminal is an enable pin. Not that good with circuits yet.
            If it is a switched LDO the you will need to replace it with the same type, they put switched LDO due to the circuit is required to be powered up in sequence.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Will keep looking for reg. It did power up from external power
              • Chuper
                • Sep 2017
                • 36
                Ok, took a long time to get it from Korea but in my case ICQ805 (KIA78L15F) voltage regulator quit working. Replaced it and voilĂ  TV is working again.
                • wnlewis
                  New wire for my RDE3340 Whirlpool electric range
                  by wnlewis
                  OK. I got the rocker switch figured out thanks to the good advice on this forum.
                  Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                  This is a Whirlpool RDE3340 electric range.
                  The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                  Where may I find parts...
                  01-08-2025, 11:21 PM
                • technicalspecialist
                  Vintage fan repair, copper wire question
                  by technicalspecialist
                  I currently have a customer's vintage fan on the work bench to repair.
                  It uses an induction motor with 4 poles. One of the poles is open.
                  I couldn't find the break so i cut off the original wire.
                  I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                  I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                  The enamelled copper...
                  03-16-2023, 12:54 PM
                  Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                  by sam_sam_sam
                  I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                  I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                  12-16-2023, 08:39 PM
                • SolomonMan
                  Nest Thermostat Discussion...
                  by SolomonMan
                  All,
                  I was over my sons place helping him with projects today. (Broken Dryer Belt, a Couple leaking pipes (One cracked - that got me over there),and Thermostat swap.
                  The Energy company offered a Rebate on the Nest Thermostat System (Not the Learning One) last year and we picked it up and its sat in the shipped box for about a year now.
                  Anyways I was thinking it would be a quick job as I currently have a Nest Learning Thermostat at my place and it was not a problem to install. (Old Rheem 90 Furnace)
                  At my boy's place he has a York Stellar...
                  12-11-2022, 10:54 PM
                • manymonsteras
                  Macbook Pro - A2251 - No power when battery is connected
                  by manymonsteras
                  I am hoping to get some advice. I have a 2020 13" Macbook Pro - A2251 that wouldn't turn on. I have done lots of electronics repair in the past but never on Macbooks. I have had this laptop sitting around and I finally decided to take a look at it and see if I could spring some life into it.
                  First, it wouldn't boot up at all. I did a DFU restore and managed to get it to power on. Did a full restore but the battery was dead and wouldn't charge. I put in a new battery in it but now it won't boot up when the new battery is connected. I ordered a second new battery just in case,...
                  11-20-2025, 09:42 PM
