Macbook Pro - A2251 - No power when battery is connected
  • manymonsteras
    • Nov 2025
    I am hoping to get some advice. I have a 2020 13" Macbook Pro - A2251 that wouldn't turn on. I have done lots of electronics repair in the past but never on Macbooks. I have had this laptop sitting around and I finally decided to take a look at it and see if I could spring some life into it.
    First, it wouldn't boot up at all. I did a DFU restore and managed to get it to power on. Did a full restore but the battery was dead and wouldn't charge. I put in a new battery in it but now it won't boot up when the new battery is connected. I ordered a second new battery just in case, but it gave me the same result. If I disconnect the battery management cable, it boots up and let's me into MacOS (albiet very slowly). I don't think I damaged anything on the logic board while I was putting in the new battery, but I guess it's a possibility.
    My USB C multimeter reads 5V and 0.15-0.3A on all 4 ports when the battery is connected. And it powers on normally when the battery is disconnected.
    I would appreciate any advice if someone has some knowledge on this.
    Thank you!
  • mon2
    • 15629
    If the BMS cable is disconnected, the logic board will sense this and throttle the CPU speed and likely force a high fan spin. Confirm the BMS cable is seated ok and is not damaged. If available, test with a known good BMS cable (Amazon?).
    • CornholioGSM
      Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
      by CornholioGSM
      I have here one interesting problem.
      Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
      I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
      Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
      06-25-2024, 12:27 PM
    • mavaro
      MacBook A1990 — No Display With Battery Connected
      by mavaro
      Hi, I have a problem with MACBOOK A1990 - The laptop starts with no image when the battery is connected, but without the battery it starts with an image - however, when using only the power supply, when logging into the system it turns off and resets again.
      Battery replaced with another unit → same problem.
      ISL9239 replaced → no change.
      SMBUS_BATT_SCL / SDA measure ~20-50kΩ to GND with battery disconnected (normal).
      Any ideas or advice would be a huge help!
      Thanks in advance for your time.​
      04-18-2025, 08:07 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • platinumsteel
      Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
      by platinumsteel
      Hi guys i have a 820-00840 that works fine and boots up as long a battery is not connected. I initially thought it was a bad battery so i went ahead and bought a new battery for it and slapped it in yesterday and realize that the same fault exists. When i screw in the battery and connect the little battery strip and i press the power button it will not power on.At that time If i connect the charger i get fan spin for 10 seconds then stops but the machine won't power on.If i disconnect the little battery strip and re-plug the charger the machine boots as normal.It's not the battery connector strip...
      03-03-2023, 10:17 AM
    • code share
      Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
      by code share
      I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
      Here's what I've tried so far:
      • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
      • Booted successfully on AC power only with the battery disconnected
      • Visual inspection of the battery — no swelling, burn marks, or connector damage
      • Battery
      04-21-2025, 12:50 PM
