philips 50pfp5332d/37 plasma both boards arcing
  • ib6
    • Mar 2012
    • 16
    I have a Philips plasma I'm trying to fix. I have the back off and have checked all the fuses and they are good. I don't see any bulging capacitors or any burned areas. The blue light comes on and I hear the clicking sound from the speakers but screen is black. I can unplug each sustain board but when I plug them back in they both give off a spark. It happens when the unit is unplugged and it has happened when its been unplugged for several days. I am not sure where to go from here and could use some insight on what to do next.
    An additional note - the set has never been used it has been setting under a patio area outside for years in the box. No real signs of the weather affecting it and the box was not rained on just sat in the sun.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: philips 50pfp5332d/37 plasma both boards arcing
    Can you post good clear pictures of all the boards? You need a volt meter and first it sounds like mainboard is coming up since you have sound, however we need to check the line from the power supply that is labeled VS.
    • ib6
      • Mar 2012
      • 16
      I do have a meter and can upload pics when I get to my phone a little later this evening. I see the VS power supply. But I am not sure what settings to use on the meter. If you could walk me through this I would appreciate it.
      • R_J
        • 9540
        You use the DC voltage setting on your meter, use a range that is above the vs voltage which is usually around 200 volts. black(-) lead to metal chassis.
        If you remove the Vs plug and power up the tv, you need to wait untill the Vs voltage from the power supply drains down before pluging it back on the Ysus, Also DO NOT remove or install the plugs when the tv is pluged in.
        Even when the plug has been disconectedfor a while there may be a small spark when re connecting the plug.
        • ib6
          • Mar 2012
          • 16
          I am familiar with checking fuses and batteries with the meter but that's about it. When you say check the line - black(-) lead to metal chassis I understand. But with the red do I put it on the plug from the power supply or the wire or to the plug on the y board?
          • ib6
            • Mar 2012
            • 16
            here are the pics:
            the board in the last pic has a few green lights one of them flashes constantly.
            • freakaftr8
              • Oct 2012
              • 3743
              OK black lead to chassis red lead to power supply output to SY connector pin labeled VS. Use Dcv setting. Power up tv. This voltage should match the voltage on the panel label. Probably somewhere around 204v DC thereabouts.
              See if the voltage holds steady
              • ib6
                • Mar 2012
                • 16
                When I touched the pin labeled VS it sparked, popped, and a saw small amount of smoke. I unplugged the set and held in the power button for a few seconds and then waited about ten minutes. I then powered the set back up and the same leds on the boards lit up and I could hear the sound humming again.
                • ib6
                  • Mar 2012
                  • 16
                  A quick note. The set was off and I went to hit the power button on the side and I hit the channel up button by accident and the set still came on.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    I'm not entirely sure what all the arcing is about But unplug the TV stick the red probe into the connector labeled VS black probe to chassis make sure your voltmeter is on DC v Then plug in the TV and turn it on and read what the meter says. It sounds like there seems to be a lot of stored up voltage for some reason. Just be careful not to touch the leads. You should have around 204 to 215 V DC.
                    On another note channel buttons will turn Philips tv's on. That's normal.
                    Buzzing sounds from either side of the boards are normal. Are you sure there are no cracks in the screen?
                    • ib6
                      • Mar 2012
                      • 16
                      I had wondered if the gas had escaped but I don't see any scratches or cracks on the screen.
                      I see a couple different spots that say VS on the power board not sure which one to check.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Check any. Try the VS on the SY connector. Make sure both boards are connected.
                        • R_J
                          • 9540
                          The quickest way to check the Vs is on the Ysus board fuse. It is located just above the metal heatsink slightly behind the metal bracket. another easy place would be on the Zsus board fuse.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            True, but the OP stated that a lot of arcing was going on, so I gave him a good reference point that will hold the DMM probe by itself.
                            • ib6
                              • Mar 2012
                              • 16
                              Ok been tied up with work so I kinda started over here is what I have so far:
                              power cord voltage - 117
                              fuses good capacators look good
                              vs from power board to y reads 206 states it should be 207
                              vs from power board to x reads 206 states it should be 207
                              va from power board reads 61 states it should be 63
                              On the logic board there is a green led that constantly blinking its right by the markings BA1
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                So far everything sounds good. Those voltage readings being a little off are not going to matter at all. Can you post a clear pictures of the long boards that go vertically on the far left side of the TV. They're connected to the Y board. They have square IC chips up-and-down the board they are called buffer boards
                                • ib6
                                  • Mar 2012
                                  • 16
                                  I split them up. If not clear I could redo.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Ok. Is there anyh light output on the panel at all? Look In a dark room. If so move on to my next step.
                                    That logic board with the BA1 on it. There should be a set of pins sticking out. These are considererd jumpers. We need to find pins 3 and 4 and jump them together. But before you do that, you need to disconnect the LVDS cable from mainboard to the BA1 board.
                                    • ib6
                                      • Mar 2012
                                      • 16
                                      Ok went into a dark room there was not a total screen coverage of light at all but there were little specks that would flash in different areas of the screen. They were fast and mostly green a couple looked white. They were small and most of them were round. It was kinda like a laser pointer.
                                      The BA1 board is located down under the chassis. I can see 2 pins and in a different spot there are 5 pins. Any ideas on how I could jump without taking it apart? Or should I given the info above?
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        So, no dark grey lighting of the screen.
                                        You say you can hear the sustained boards buzzing and humming this is normal. If you press the menu button when you hear the boards buzzing do they sound like they change in pitch?
                                        There will be a fair amount of disassembly to access the BA1 board. This board is also known as the logic board. From the sounds of it there could be 1 of 2 problems here the 1st problem could be a failed mainboard. The other could be a failed logic/BA1 board. But since you seem to be getting drive signals and you can hear the sustains buzzing maybe not.
                                        On the SY board do you see a location that says VSCAN?
                                        • celiabrown
                                          Issue with Plasma Philips 37inch chassis FTL2.1
                                          by celiabrown
                                          Hello guys,
                                          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                          Can someone has any symptom like this ?
                                          Thanks​
                                          05-09-2024, 10:56 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
                                        • ArMaaN376
                                          Samsung PS51E550 Plasma TV
                                          by ArMaaN376
                                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                          Opened TV cover & observed foll
                                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                          How to confirm Y -Buffer board...
                                          06-19-2024, 04:05 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
