lg 50LB659 screen problem -help
  • shopy
    • Jan 2012
    • 7
    hello experts
    i have this problem on my lg
    when i start the tv the screen is black but the back light is on .if i disconnect one side of the reebons that is connected from the lcd to the main board i get a picture on the half of the screen .but when i connect this side back there is no picture at all.so i assume the other half of the screen cause a short to the tcon board and prevent it ro display .the tcon is integrated in the main board not separate.
    is it possible that the half of a screen will be defected.anyone has experience this ??
    any suggestions??
    thanks
  • freakaftr8
    • Oct 2012
    • 3743
    Re: lg 50LB659 screen problem -help
    This sounds likke a defective LCD panel unfortunately. The only thing you can do is look at the panel driver boards on the side that shuts the screen off completely and check for shorts against small SMD style MLCC capacitors
    • sangeet101
      • Jan 2020
      • 9
      • usa
      I have the same problem. I checked the SMD caps they show short. I took out one smd cap to check if that was really short but it was not short. I test the two points where the cap was sitting it shows short. there were 6 cofs on that side of the driver board. Do i have to change all short smd of each cofs. are they related ? or is the short really coming from lcd panel. Please help.. Thanks
        • 12331
        • U.S.
        Is there caps next to the one you took out? If so it could be one of those.
        • sangeet101
          • Jan 2020
          • 9
          • usa
          Yes there were 3 but only one was beeping on continuity mode
            You will need to remove the cap one by one and see if the shorts will go away or not, if not then the COF may be shorted out.
            BTW, are testing the caps on the tab bonding board without the T-CON still connected to the tab bonding boards?
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • mmccomputer
              problem with replacing lcd screen
              by mmccomputer
              I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
              otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
              If anyone has any information on the subject...
              12-15-2024, 03:44 PM
            • seve91
              ACER XV340CK 34" black screen
              by seve91
              I got this monitor with black screen problem.
              I thought the problem was in the motherboard, so I bought 2 smashed monitor same model to disassemble boards and swap them, but same issue remains.
              After some tries I've found out that connecting LVDS cable on-fly after powering on the LCD panel let me see the whole screen for half sec, then goes black again.
              TCON got two output flats, because each flat goes to a tiny board with some COF, each tiny board manages half LCD panel.
              I discover that if I leave connected only right side (right flat of the TCON),...
              07-30-2025, 02:32 PM
            • jimjoe123
              LCD TV Green/Pink screen problem
              by jimjoe123
              I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
              Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
              Then each time...
              02-23-2020, 01:29 AM
            • vf fa
              EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
              by vf fa
              Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
              I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
              So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
              01-31-2024, 01:40 PM
