ACER XV340CK 34" black screen
  • seve91
    • Oct 2013
    • 75
    • Italy
    I got this monitor with black screen problem.
    I thought the problem was in the motherboard, so I bought 2 smashed monitor same model to disassemble boards and swap them, but same issue remains.
    After some tries I've found out that connecting LVDS cable on-fly after powering on the LCD panel let me see the whole screen for half sec, then goes black again.
    TCON got two output flats, because each flat goes to a tiny board with some COF, each tiny board manages half LCD panel.
    I discover that if I leave connected only right side (right flat of the TCON), the monitor works perfectly.
    As soon as I connect the left board (left flat of TCON) the monitor goes black, and then got no voltages even on the working right side.
    Looks like TCON goes in protection due to a short, but I didn't found any short on the left tiny board, also COF looks ok.
    COF flat is marked NOVATEK NT66956H-C12V2A, COF chip is market OTBOT52C.
    Left tiny board is marked MV340VWB-N20, TCON is marked MV340VWB-N20-DDP0
    Any advice guys?
  • StefanNg
    • Oct 2022
    • 20
    • Malaysia
    Tape the left flat ribbon. You either have to identify which pins are the clock signal or you do it trial and error.
    But it might not last long if the right side also become short.
    My last panel fixed only lasted for 2 months. It is luck to have it fixed.
    • seve91
      • Oct 2013
      • 75
      • Italy
      Thanks for your reply.
      Yes, you're right.
      Each board got 6 COF, I've desoldered the last one of the left board and the LCD started, but without last row of the screen.
      Then I resoldered the ribbon again but black screen came up again, so the COF is burnt.
      Tried to reflow it without success.
      Don't have any test point on the COF, no datasheet, so I'm very sorry but I'll bin everything
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • ravi_1617
        HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
        by ravi_1617
        Hello to all ,
        I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
        Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
        on external VGA port image is perfect /normal , Attached image...
        07-25-2025, 12:07 AM
      • alltvrepairs
        Lg TCon test pins for screen test
        by alltvrepairs
        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
        Appreciate your help....
        06-13-2025, 06:33 AM
