Samsung UE40EH5000K No Power
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    hi guys I have the above mentioned TV and it appears completely dead.
    no power light nothing
    I have removed the mainboard to see if the back lights would fire up incase it was a mainboard issue
    and its still dead ?
    does this link to a bad PSU ?
    thanks for any help
    Jason
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Re: Samsung UE40EH5000K No Power
    here are photo's of the PSU guys
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    • dskall
      • Oct 2016
      • 2905
      • usa
      Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
      Format:
      Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
      1 - XXXXXXX - XXv - XXXv
      2 - XXXXXXX - XXXv - XXXv
      3 - XXXXXXX - XXXv - XXXv
      4 - etc.
      • jasonr2000
        Advance Tech
        • Nov 2013
        • 209
        Hi there.
        Thanks for the reply there is no output at all i have done some further testing and the fuse FP8015 T5.0AH 250V
        Has blown
        So no power at all on any connector
        Samsung UE46D6530
        Samsung BD-F7500
        Samsung HT-ES6200
        • dskall
          • Oct 2016
          • 2905
          • usa
          Well I would say a bad power board
          • jasonr2000
            Advance Tech
            • Nov 2013
            • 209
            Thanks for the reply im going to do some more testing and if no go ill just get a replacement power supply
            Samsung UE46D6530
            Samsung BD-F7500
            Samsung HT-ES6200
            • dskall
              • Oct 2016
              • 2905
              • usa
              Try checking bridge rectifier. Thought you just wanted to know what board is bad.
              • jasonr2000
                Advance Tech
                • Nov 2013
                • 209
                Anything else to check ?
                Samsung UE46D6530
                Samsung BD-F7500
                Samsung HT-ES6200
                  Check all the Devices that are mounted on the heatsink in the primary side of the circuit for shorts.
                  • jasonr2000
                    Advance Tech
                    • Nov 2013
                    • 209
                    Thanks Budm will post back what i find
                    Samsung UE46D6530
                    Samsung BD-F7500
                    Samsung HT-ES6200
                    • thoma
                      • Sep 2012
                      • 268
                      https://www.electronica-pt.com/esque...-00496b-29976/
                      • jasonr2000
                        Advance Tech
                        • Nov 2013
                        • 209
                        ive discovered a few parts are bad on the PSU
                        DM855C
                        DM857C
                        DM853C
                        DM851C
                        have no continuity at all
                        and the main input fuse
                        is there any point repairing them ?
                        or should I just replace the board ?
                        thanks
                        Samsung UE46D6530
                        Samsung BD-F7500
                        Samsung HT-ES6200
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Seems strange you have blown fuse and open diodes
                          • jasonr2000
                            Advance Tech
                            • Nov 2013
                            • 209
                            I agree with you it just went dead for no reason,
                            ive checked most of the others and they test out ok
                            whats the worst that would happen if I replace the fuse with the same one and replace the diodes ?
                            the diodes that have gone are on the backlight circuit
                            ive noticed that
                            Jason
                            Samsung UE46D6530
                            Samsung BD-F7500
                            Samsung HT-ES6200
                            • R_J
                              • 9627
                              How are you measuring the diodes? are you using the diode test mode on the meter or just checking their resistance?
                              If the diodes are indeed open, that will not blow the fuse.
                                https://www.badcaps.net/forum/attach...7&d=1513635033
                                So the MOSFET mounted on the heatsink where the bridge rectifier is also mounted tested OK?
                                • jasonr2000
                                  Advance Tech
                                  • Nov 2013
                                  • 209
                                  hi guys ive tested the diodes for continuity
                                  all the other diodes check out ok
                                  the mosfet doesn't appear to be shorted guys,
                                  the bridge rectifier is also ok
                                  thanks for all the help so far,
                                  im having issues finding a PSU for this tv the part number of the PSU is BN44-00666B
                                  can I use the Revision BN44-00666A ?
                                  all the pin outs are the same
                                  Samsung UE46D6530
                                  Samsung BD-F7500
                                  Samsung HT-ES6200
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Diodes don't show continuity. Test in diode mode, put the leads on one way then the other.
                                    How are you testing the other components ?
                                    As for repairing than replacing, it's uncommon to find a board cheaper than the components for a repair, it just depends on your skills/tools.
                                    • jasonr2000
                                      Advance Tech
                                      • Nov 2013
                                      • 209
                                      Hi guys
                                      Sorry ive not been in touch sooner.
                                      Happy new year to you all.
                                      Well anyway the mosfet is shorted to ground as ive discovered that by testing it with a multimeter.
                                      Ive got a replacement mosfet but its slightly less on the spec
                                      The original one is a 60R580P
                                      And the replacement one is a 13N50C
                                      Do u think it would be ok for testing purposes as im still learning all this.
                                      Samsung UE46D6530
                                      Samsung BD-F7500
                                      Samsung HT-ES6200
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        Underspecd component may work for testing but will not last.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
