Sharp LC-70C8570U
  • nelson6861
    • Jul 2016
    • 67
    Re: Sharp LC-70C8570U
    Originally posted by budwich
    look at my post 33... anyways best of luck with your card replacement.
    Ok.
    When i plug tv in i get v light lit then i hit power button and get 2/5 blink code...
    I get no backlights at anytime
    • nelson6861
      • Jul 2016
      • 67
      Originally posted by nelson6861
      Ok.
      I get 12v on tcon board also
      • nelson6861
        • Jul 2016
        • 67
        Ok.
        I had removed the panel and tested all led backlights.
        I used my led backlight tester.
        All leds lit up bright
        • budwich
          • Jul 2015
          • 3097
          OK. well, i would do the "disconnect the corner cable" as suggested earlier and see what the results are from doing that... this "test" is done with all tcon cables connected.
          • nelson6861
            • Jul 2016
            • 67
            Ok disconnected the left corner and nothing.
            V light lit up
            Did not have flash fault code re-appear.
            Im thinkin maybe backlight led issues...
            I took some measurement with dmm with leds connected and power on.
            Might have power board issues or whats preventing leds from coming on...
              PWM signals from the T-CON are used for controlling the brightness of the backlights base on the scene of the video for dimming control so they can claim fake high contrast ratio, no PWM = no backlights. You have 3 sets of edge-lit LEDs, thus 3 LED drivers circuits.
              What do happen if you disconnect just that cable from the T-CON? Also test the PWM pins too without the cable in place.
              Those 83 V LED voltage reading are made against chassis GND?
              STB = BL-ON, that siganl will be locked out if ERROR pin is HIGH.
              You are 100% sure that PNL-12V is present and not drops out afetr seconds or two?
              Sharp RUNTKA935WJQZ (DPS-171CP A) Power Supply / LED Board.
              • nelson6861
                • Jul 2016
                • 67
                Ok
                The 83 volts for led is against chasis ground.
                Pnl-12 is pin 16 reads 3v
                Error voltage is reads 0v
                I have a new tcon coming
                  PNL_POW PIN 16 (3V =ON) is the command signal to turn on switched 12V to feed the PNL-12V pin on the other connector that goes to the T-CON board.
                  So do you have 12VDC at PNL-12V or not for sure?
                  • nelson6861
                    • Jul 2016
                    • 67
                    I get 12v on tcon connector to the board... but i think tcon board is back... i will see when i get new tcon board
                      So the 2/5 error did not shutdown the PNL-12V supply.
                      • nelson6861
                        • Jul 2016
                        • 67
                        No...
                          the 2/5 error detect if the PNL-12V is present (or loaded down too much by bad T-CON) or not, so we just have to wait for the new T-CON to see what happen.
                          • lonewolf55
                            • Jan 2019
                            • 30
                            I know this is an old Thread, I have been searching the forums for RUNTKA935WJQZ information myself.
                            I have similar issue with an LC-70LE847U .... I see the OP ordered a T-CON but then the thread goes Dead... my guess is this did not fix the issue and that the issue is most likely a Dead LCD Panel.
                            the symptoms I have are:
                            No Backlight
                            No Video (Picture) when using the old Flash light method
                            with the 4 white Panel cables disconnected, there is still no Backlight
                            all LED strips were tested with SID-GJ2C 0-300v tester and no defects.
                            I notice when I touch the metal frame there is presence of Voltage (about 10VAC leakage from Chassis to GND) <<=== this is gone when the PSU Board is Isolated from the Chassis.
                            I'll post PD voltages but they look Normal at this point IAW the SM.
                            I suspect the LCD Panel is most likely Dead, and right now I'm building a simple test fixture to try turn on the Backlight section of the supply.
                            There are no V flash codes, so I'm not Positive what I have yet.
                            • lonewolf55
                              • Jan 2019
                              • 30
                              Ahhh I see now all voltages are good, but PWM-1 signal not happening, so I removed the Pin 17 and then after powering the set up I jumped pin 17 to pin 15 which is BUSY @5.05v. <<<== EDIT: Just to be clear, the PD Connector is what I jumpered the PWM1 Line that I removed comes from the Main Board and it was left hanging loose so as not to damage things by Arbitrarily shorting things out.
                              Low and behold we have full Backlighting, so this means the Main Board is not giving PWM-1 signal.
                              So now a question, what function tells the Main Board to turn on PWM-1 ?
                              probably comes from the T-CON .... sucks to have to Reverse engineer all these boards as I cannot find a Schematic
                              • lonewolf55
                                • Jan 2019
                                • 30
                                BTW there is no such TV as the LC-70C8570U ... I think the OP meant LC-70C8470U anyway really same as the LC-70LE847U
                                Maybe I should have made a new Thread my Bad
                                  • 12111
                                  • U.S.
                                  #56
                                  No Backlight
                                  It's very possible that the tcon did fix the issue, some people just don't bother themselves to report back, just another eternal mystery, sucks but happens frequently.
                                  • lonewolf55
                                    • Jan 2019
                                    • 30
                                    I think I might have a Main Board issue DKEYMF953FM01 (KF953, QPWBXF953WJN1)
                                    Problem is I don't have one to substitute and all I see for sale are Used NOT WORKING for parts only @ around 150 Bux, I guess fine but the parts I need are most likely what failed on the boards all those folks are selling LMAO
                                    Looks like this one might go in the Dumpster.
                                    I don't have an LVDS cable that will fit my Panel tester for this one either (it's a 41 Pin Cable) Maybe I can make one.
                                    • lonewolf55
                                      • Jan 2019
                                      • 30
                                      OK found it PWM1 comes off the T-CON and just passes thru the Main Board.
                                      As I suspected earlier, so now it's down to T-CON or the Panel, most likely the Panel.
                                      Love it when I answer my own Questions
                                      Well, it could still be Main Board need to check PNL ENABLE and a few other things
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        you checked that you have 12v at the tcon?
                                        instead of disconnecting all of the tcon to panel cables, you can try one at a time and also a "disconnect of the small corner cable" at the bottom of the panel... interconnecting the bottom edge board to the side... this is done with all other cables in place. that might tell you more.... maybe.
                                        • lonewolf55
                                          • Jan 2019
                                          • 30
                                          yes I have 12V to the 4 pin connector it is GND GND 12V 12V and all good.
                                          I don't see "Corner Cable Connectors" on this Sharp LC-70LE847U TV, maybe one needs to remove the panel to get to them.
                                          The T-Con board is Duntkf961fm01
                                          on the LVDS test points I have no PWM1 signal out (this turns on Backlight inverters) so I just finished checking PNL_EN this is Pin 3 of the 41 Pin LVDS connector and I see a toggle at power up and Power Down so looks like it works....
                                          I thought that the Backlight should turn on with the 4 T-Con ribbons removed, I'm not sure but most tell me it should. That being the case with those 4 removed the Panel is out of the equation. <<== at least for now, was my thinking
                                          BTW the History of the set is........ it was working fine then was powered off over night, then when it was powered back up, it turned on and only the V LED under the Sharp name was lit up solid, not flashing any code and there was no Backlight and no Picture seen on the screen, even when looking with the old Flashlight, But there is sound.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                          • joblo37pam
                                            Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                            by joblo37pam
                                            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                            10-26-2023, 02:17 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • koby058
                                            vostro comes up with back light but no picture
                                            by koby058
                                            Hi people!!
                                            The owner said it showed bad picture once in a while (attached)
                                            I see that there is back light but no picture.
                                            I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                            Also attached schematic and BDV
                                            LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                            07-13-2025, 01:03 PM
                                          • freakaftr8
                                            Asus a15 FA507RE-A15.R73050T failure
                                            by freakaftr8
                                            So this laptop seems to have some kind of failure. I bought it second hand and originally the previous owner said that they went to turn it on and it was presented with a quick flash of the power light the keyboard lit up and then the keyboard shut off and the power light went off as well but the battery indicator was white and after about 5 to 7 Seconds flashes orange really quick then shuts off and goes back to White. If the power button is pressed again the keyboard lights up really quick and then repeats. When I got it I could press the power button multiple times the keyboard light would...
                                            03-28-2024, 10:58 PM
