Insignia NS32L450A11
  • pcardoso73
    iMac power supply short-circuit diode to ground
    by pcardoso73
    I have an iMac with the power supply reference: ADP-200DFB.
    This power supply is not working and when trying to debug the problem with a multimeter, I found what I thought to be a short circuited diode (the short-circuit is to ground).
    With the continuity test it beeps both ways, so doesn't block current flow at all then reverse biased. But after removing the diode the beep continues and the diode seems healthy. It seems to exist a real short-circuit.
    As I have another ADP-200DFB power supply (faulty one as well), I have checked the same...
    06-09-2020, 08:47 AM
  • Astonished
    Fixing the Charge Circuit of the Batteries of the DC Motor
    by Astonished
    Hi friends of electronics
    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
    Please help me fix this circuit.
    (the datasheet of the IC: https://pdf.datasheet.live/28...
    01-28-2025, 06:24 AM
  • Askic
    Testing for short circuit in diode mode
    by Askic
    Hello electronics experts,
    On a few occasions I notice experienced technicians inspect for short circuit in diode mode on multimeter. This is OK and in some way equivalent to resistance mode, but more specifically I noticed that they put red probe on ground and black probe (connected to COM input on multimeter) is placed on the rail or pin.
    I wonder why is that. Why not place black probe of multimeter on the ground and red probe on the rail which is tested for short?
    Can you clarify this? When I test if something is short I use diode mode First and then double check...
    02-21-2021, 12:05 PM
  • asr
    Finding replacement diode iPad Pro 3rd gen A1701
    by asr
    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
    07-09-2024, 06:24 PM
  • unimatrix93
    TV backlight zener diode
    by unimatrix93
    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
    The led strips has 9 6V leds.
    02-10-2025, 12:13 PM
