Testing for short circuit in diode mode
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello electronics experts,
    On a few occasions I notice experienced technicians inspect for short circuit in diode mode on multimeter. This is OK and in some way equivalent to resistance mode, but more specifically I noticed that they put red probe on ground and black probe (connected to COM input on multimeter) is placed on the rail or pin.
    I wonder why is that. Why not place black probe of multimeter on the ground and red probe on the rail which is tested for short?
    Can you clarify this? When I test if something is short I use diode mode First and then double check by measuring actual resistance against the ground.
    One more thing, if multimeter shows me on one place (in diode mode) 380 and on some other place 680 to the ground, what I should conclude from this reading?
    I know that in both cases there is no short to ground, but what this 2x number in second case should tell me?
    Thank you!
    • 31304
    Re: Testing for short circuit in diode mode
    your talking about Rossmann.
    i wouldnt advise what he does - most meters diode-test at over 2v and sometimes as much as 4v or more.
    checking digital circuits that may be running as low as 1.8v could do some damage
    • Askic
      • Sep 2018
      • 187
      • BIH
      Exactly, I have watched dozens of his videos and I noticed that.
      Do you recommend only resistance mode on multimeter? What would be recommended practice here?
      Does this depends on the multimeter type itself? I notice that most repair guys use Fluke.
        • 31304
        fluke only has one model even close to suitable for electronics,
        they are overpriced and targetting electricians.
        to know if you should use resistance or diode mode you need to check the manual for the meter.
        if you cant find one - find a datasheet for the chip in it.
        diode test can light an led - i consider that risky.
        • redwire
          • 3912
          Older digital multimeters had "low power ohms" that apply under 0.4V which keeps diodes and most semiconductors off, allowing you to make ohms measurements in-circuit.
          You would use both with semi's: First diode-test (both polarities) and if a suspicious/low V is measured, then check on ohms. Because a shorted or leaky semi no longer has the barrier voltage and will give a reading on low power ohms.
          If in doubt, lift a pin/lead and remeasure.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            Most DMMs (at least I have yet to find a DMM, even old ones) do not supply enough current in ohms mode to damage semiconductors. They may still turn them on which may affect your readings depending on whether you forward bias or not. Yes, the low power mode was intended to keep semiconductors off in older DMMs which got obsoleted with the low voltage newer DMMs.
            This is not true with analog VOMs, but it depends on the particular meter. I've found pretty much all battery powered passive VOMs in Rx1 and a Heathkit VTVOM in Rx1, Rx10 to be able to fry sensitive semiconductors. I would suspect a lot of old VTVOMs to be the same way.
            However I have a old analog FETVOM that does not supply enough current in Rx1. Unfortunately the sample size = 1 so I don't know if all analog FETVOMs are ok or not.
              Originally posted by redwire
              older digital multimeters had "low power ohms" that apply under 0.4v which keeps diodes and most semiconductors off, allowing you to make ohms measurements in-circuit.
              You would use both with semi's: First diode-test (both polarities) and if a suspicious/low v is measured, then check on ohms. Because a shorted or leaky semi no longer has the barrier voltage and will give a reading on low power ohms.
              +1
              Diode mode does not show resistance reading, it shows Voltage drops reading of the device under test.
              • Askic
                • Sep 2018
                • 187
                • BIH
                Ok, I know that if I test diode and I see 605 on my multimeter, that these are mV. But what about practice to place red probe on the ground and black (common multimeter) on point of interest. Is this some kind of preventive practice (reduced risk of damaging components)?
                • aaronkatrini
                  Help me find the short circuit on this WORKING Nvidia GTX1650
                  by aaronkatrini
                  Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                  Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                  04-18-2024, 03:15 PM
                • M1NEBLANK SHOW
                  MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                  by M1NEBLANK SHOW
                  Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                  (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                  Schematic and Boardview here
                  04-04-2025, 03:57 PM
                • quicknick
                  Dead Corsair TX650M
                  by quicknick
                  PSU is made in late 2019 and seems barely used judging by the lack of dust on its innards.
                  +5Vsb is all right, grounding PS_on results in a relay clicking and nothing more, all outputs dead without even a flinch.
                  Checked inside, at first glance all seemed ok but then noticed something on the primary heatsink, which I promptly removed along with all its attached devices - there were clear signs of insulation breakdown above the C3D04060 diode. The device was overtightened from factory and the tab squished the sil-pad, it all was a matter of time,...
                  10-09-2024, 02:52 PM
                • rumpumpel1
                  Fault source of a short circuit
                  by rumpumpel1
                  I have a mainboard with a short circuit (approx. 0 Ohm) on the 3.3V rail. As usual, I injected current and observed the mainboard with the thermal camera. Instead of individual components becoming warm, I observed that an area of several square centimeters became evenly warm from approx. 2A.
                  Has anyone ever seen anything like this? Is it possible that there is a short circuit between two layers of the mainboard? The visual inspection of the mainboard did not reveal any abnormalities....
                  10-21-2025, 01:38 AM
                • privato89
                  Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                  by privato89
                  I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                  Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                  Let's begin:
                  Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                  03-26-2024, 06:37 AM
