Bad main board or power supply? Vizio E420-a0
  • S.gilletly
    • Nov 2017
    • 28
    Hello Friends,
    I have a Vizio E420-A0 and am trying to diagnose what the problem is. I'm getting no power and no sound. This is what voltage I get when I test the power supply.
    CN201 with tv off
    1. 5.3v stand by
    2. 5.3v stand by
    3,4,5 zero volts
    6. 0.15v or 151mv
    7. 0.15v or 151mv
    8,9 zero volts
    10.1.8v
    11.1.8v
    12. Zero
    When I press the power button I get the same readings. In addition I tested CN301 and get zero volts on vout1&2 and on LED with tv off or on. I also checked where the power button is located and that is also getting voltage. My gut tells me its probably the power supply. I don't have much experience and want to avoid buying the wrong replacement part. Any help would be greatly appreciated.
    Re: Bad main board or power supply? Vizio E420-a0
    1) We need pin names follow by the Voltage reading for each pin.Without the name those readings you report mean nothing.
    2) We need good clear pictures of the boards and how all the boards are connected together.
    3) We do not have the TV in front of us to look at so the more details you provide the more helps and correct information you will receive.
    • S.gilletly
      • Nov 2017
      • 28
      All right thank you. I'll post when I get home from work 👍
      • S.gilletly
        • Nov 2017
        • 28
        Okay I have attached pictures and here are the pins names with voltage.
        CN301 both on and off
        Led1 zero vdc
        Vout1 zero vdc
        Led2 zero vdc
        Vout2 zero vdc
        CN201 both on and off
        5. 1vsb =5.3vdc
        5. 1vsb=5.3vdc
        Gnd = zero
        Gnd = zero
        Gnd = zero
        12v = 0.15vdc
        12v = 0.15vdc
        Ps on/off = zero
        Blu on/off= zero
        Pwm 1 = 1.8vdc
        Pwm 2= 1.8vdc
        N.C = zero
        Thanks for your help
          Ps on/off = zero
          Blu on/off= zero
          The main board is not sending the PS-ON to turn on the rest of the power supply, it also does not send the BL-ON ti turn on the backlighst circuits.
          Go to shopjimmy.com to see if there is EEPROM that will fix this symptom or not.
          • S.gilletly
            • Nov 2017
            • 28
            Will do thank you much budm. I will update after repair.
            • CapLeaker
              Leaking Member
              • 8147
              Have you tried freezing the EEPROM with a can of air upside down, then plug the tv in and turn it on?
              • S.gilletly
                • Nov 2017
                • 28
                No I have not tried that. I'm curious as to what that is supposed to do. Could you elaborate as to what it does to the EEPROM that would cause it to work. Also how long would it correct the issue if it did work?
                • R_J
                  • 9535
                  I can't say what actually happens inside the ic but I do know freezing it can work, I have read a faulty ic and when a varify was done it failed. After freezing the ic and reading the data it was slightly different.
                  • CapLeaker
                    Leaking Member
                    • 8147
                    I have about a 70% success rate with that trick. It doesn't work always. It seems that if you really cool (freeze) an EEPROM or an IC, that some can be made to work again for a short time.
                    • S.gilletly
                      • Nov 2017
                      • 28
                      Quick update I believe you were correct it was the EEPROM chip. TVs up and running !!!! Thank you all for your help. ��������
                      • S.gilletly
                        • Nov 2017
                        • 28
                        I replaced a prom by the way. I didn’t even try to freeze the old one
                        • jasenpeters
                          • Sep 2015
                          • 53
                          Visio - E420-A0
                          Can't find a date mark....suggestions?
                          Symptoms - No Power LED indication, No Screen light or flicker, no Sound.
ID:	3501061 Click image for larger version
ID:	3501062 Click image for larger version
Name:	20241105_223607 - EEPROMs.png
                          1. Power Board
                          2. Control Board
                          3. Control Board - EEPROMs ??? (5 - total)
                          Which is the EEPROM chip ? (assuming it may be the issue)
                          Thank you in Advance.
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • mrtek
                            Vizio M65-C1
                            by mrtek
                            Hi.
                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                            07-14-2025, 07:28 PM
                          • UglyBetty
                            Need some help with Epson Printer Power Supply C655 MAIN
                            by UglyBetty
                            Here is the back story. This printer had been sitting for about two years not used. I removed the print head to clean it (completely dried out). I cleaned it and reinstalled in. Powered the printer on, the printer started going through it's normal start-up procedure and part way through it was like the power just shut off. No sound, not lights, no error messages, it just went completely off. I suspect the power supply.
                            At any rate, the schematic for the power supply is included.
                            There is a lot going on on the low voltage side that I am not able to make heads or tails...
                            01-06-2022, 03:54 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
