Bad main board or power supply? Vizio E420-a0
  • S.gilletly
    • Nov 2017
    • 28
    Hello Friends,
    I have a Vizio E420-A0 and am trying to diagnose what the problem is. I'm getting no power and no sound. This is what voltage I get when I test the power supply.
    CN201 with tv off
    1. 5.3v stand by
    2. 5.3v stand by
    3,4,5 zero volts
    6. 0.15v or 151mv
    7. 0.15v or 151mv
    8,9 zero volts
    10.1.8v
    11.1.8v
    12. Zero
    When I press the power button I get the same readings. In addition I tested CN301 and get zero volts on vout1&2 and on LED with tv off or on. I also checked where the power button is located and that is also getting voltage. My gut tells me its probably the power supply. I don't have much experience and want to avoid buying the wrong replacement part. Any help would be greatly appreciated.
    Re: Bad main board or power supply? Vizio E420-a0
    1) We need pin names follow by the Voltage reading for each pin.Without the name those readings you report mean nothing.
    2) We need good clear pictures of the boards and how all the boards are connected together.
    3) We do not have the TV in front of us to look at so the more details you provide the more helps and correct information you will receive.
    • S.gilletly
      • Nov 2017
      • 28
      All right thank you. I'll post when I get home from work 👍
      • S.gilletly
        • Nov 2017
        • 28
        Okay I have attached pictures and here are the pins names with voltage.
        CN301 both on and off
        Led1 zero vdc
        Vout1 zero vdc
        Led2 zero vdc
        Vout2 zero vdc
        CN201 both on and off
        5. 1vsb =5.3vdc
        5. 1vsb=5.3vdc
        Gnd = zero
        Gnd = zero
        Gnd = zero
        12v = 0.15vdc
        12v = 0.15vdc
        Ps on/off = zero
        Blu on/off= zero
        Pwm 1 = 1.8vdc
        Pwm 2= 1.8vdc
        N.C = zero
        Thanks for your help
          Ps on/off = zero
          Blu on/off= zero
          The main board is not sending the PS-ON to turn on the rest of the power supply, it also does not send the BL-ON ti turn on the backlighst circuits.
          Go to shopjimmy.com to see if there is EEPROM that will fix this symptom or not.
          • S.gilletly
            • Nov 2017
            • 28
            Will do thank you much budm. I will update after repair.
            • CapLeaker
              Leaking Member
              • 8352
              Have you tried freezing the EEPROM with a can of air upside down, then plug the tv in and turn it on?
              • S.gilletly
                • Nov 2017
                • 28
                No I have not tried that. I'm curious as to what that is supposed to do. Could you elaborate as to what it does to the EEPROM that would cause it to work. Also how long would it correct the issue if it did work?
                • R_J
                  • 9625
                  I can't say what actually happens inside the ic but I do know freezing it can work, I have read a faulty ic and when a varify was done it failed. After freezing the ic and reading the data it was slightly different.
                  • CapLeaker
                    Leaking Member
                    • 8352
                    I have about a 70% success rate with that trick. It doesn't work always. It seems that if you really cool (freeze) an EEPROM or an IC, that some can be made to work again for a short time.
                    • S.gilletly
                      • Nov 2017
                      • 28
                      Quick update I believe you were correct it was the EEPROM chip. TVs up and running !!!! Thank you all for your help. ��������
                      • S.gilletly
                        • Nov 2017
                        • 28
                        I replaced a prom by the way. I didn’t even try to freeze the old one
                        • jasenpeters
                          • Sep 2015
                          • 53
                          Visio - E420-A0
                          Can't find a date mark....suggestions?
                          Symptoms - No Power LED indication, No Screen light or flicker, no Sound.
ID:	3501061 Click image for larger version
ID:	3501062 Click image for larger version
Name:	20241105_223607 - EEPROMs.png
                          1. Power Board
                          2. Control Board
                          3. Control Board - EEPROMs ??? (5 - total)
                          Which is the EEPROM chip ? (assuming it may be the issue)
                          Thank you in Advance.
                          • semiRocket
                            Toshiba 37bv701b power supply main rails
                            by semiRocket
                            The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                            I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                            Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                            10-26-2025, 01:55 AM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • alltvrepairs
                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                            by alltvrepairs
                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                            Any one met this problem in the past?...
                            10-08-2025, 07:34 AM
                          • mrtek
                            Vizio M65-C1
                            by mrtek
                            Hi.
                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                            07-14-2025, 07:28 PM
