Philips 52PFL5704D/F7--backlight, no picture
  • bdl1989
    • Nov 2017
    • 9
    One minute it's working--then I turn off, leave for 5 minutes, and turn it on to no picture. The backlight works, but there is no picture. Nothing--can't change input or bring up menu. Philips logo does not display on power up. Backlight flashes on, then off, then solid on again (consistent with what happens when Philips logo displayed prior to issue.
    Preliminary reading tells me it could be a t con board issue, but I'd like to be sure before dropping $80+. Can you help me out?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Philips 52PFL5704D/F7--backlight, no picture
    Need good clear straight on pictures of back of tv with cover off and each board.
    • bdl1989
      • Nov 2017
      • 9
      Will get as soon as possible, tonight, hopefully.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4453
        • Italy - Milan
        But audio?
        • bdl1989
          • Nov 2017
          • 9
          I haven't been able to pinpoint whether or not I have audio yet. We don't have cable, and the only device that was outputting to the tv was a (monitorless) streaming PC.
          I am going to try to connect a laptop via HDMI (so I can see what I am controlling) and have it play music as I blindly cycle through TV inputs, and will let you know if the TV outputs sound as I cycle through its inputs.
          • bdl1989
            • Nov 2017
            • 9
            So, I was able to confirm that I do indeed have sound, connecting laptop via HDMI. Eventually, I blindly found the correct input, and successfully played audio through the TV.
            So, current state:
            --no picture
            --backlight is very apparently working
            --I do have sound
            I will get into the back of the TV at first opportunity. It's currently on a mount, and I need a second set of hands before I can proceed.
            EDIT: Got the TV off the mount, but my torx screwdriver doesn't fit to remove the back panel screws, need a skinnier one. Will proceed ASAP.
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              from memory they are a t10 piece.
              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4453
                • Italy - Milan
                First thing to control are voltages on tcon
                • bdl1989
                  • Nov 2017
                  • 9
                  Makes sense--one size smaller than the long t15 bit I had, of course
                  EDIT: Unclear. I have the right size torx head available, as I was able to remove some of the screws. However, the piece that my torx bits go into on my screwdriver is too fat to reach the screws in the narrow channels around the periphery of the TV.
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    i have had that problem before. had to buy a security set as it had a longer handle and was not overly thick.
                    • bdl1989
                      • Nov 2017
                      • 9
                      Sorry for the delayed reply. By day I am a teacher, who just got through a very busy part of the year. Now I have some time again to try to diagnose and repair, if you'd be so kind as to offer some help .
                      I've attached pictures of the main board, power supply, and tcon board. What is the next logical step?
                      • attainteddragon
                        • Apr 2013
                        • 764
                        • australia
                        next thing to do is check that you have 12 volt on the t-con fuse. it is on the bottom left.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4453
                          • Italy - Milan
                          The tcon photo is the only one needed but need to be re done, without your shadow on.. and remove those 2 bottom silicon pads.
                          If you want to go ahead you can modify the photo with adding of each electrolytic voltage.
                          • bdl1989
                            • Nov 2017
                            • 9
                            Hopefully this photo is sufficient. Poor lighting in my basement .
                            • bdl1989
                              • Nov 2017
                              • 9
                              Sorry, I'm not clear on where I should be checking voltages. I can get a multi-meter, and point the leads where directed to, but I have no idea where...
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4453
                                • Italy - Milan
                                Do you see those silver cylinders? Them are electrolytic capacitor (EL.CO.) , test the voltage on them (purple band is the negative) and report measurements on the picture using Windows Paint or other SW..
                                • G33RT
                                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                  by G33RT
                                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                  It does power up when pressing the power button.
                                  I already try the power button while plugin the plug with no result.
                                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                  Could this be an PSU or eMMC issue ?
                                  07-19-2025, 03:43 AM
                                • Rauni
                                  Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                  by Rauni
                                  Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                  My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                  Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                  Read also that we should test what happens if we...
                                  10-01-2023, 12:06 AM
                                • Schwoin
                                  Philips 243v5lhsb00 Monitor Picture too bright
                                  by Schwoin
                                  Hey everyone,
                                  the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                                  While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                                  you can see them on the top half of the photo.
                                  At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                                  03-21-2023, 12:40 PM
                                • madyoyo
                                  Philips 37pfl560: Yellow picture
                                  by madyoyo
                                  HI.
                                  I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                                  Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                                  05-30-2025, 10:16 AM
                                • charlesdutcher
                                  No picture issue in Philips Chassis FTL2.1
                                  by charlesdutcher
                                  My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                                  Is there someone having any symptom like this? How to fix it?
                                  Thanks in advance!​
                                  08-06-2024, 09:55 PM
