LG 47LG50 No Backlight
  • neilc6
    • Nov 2015
    • 1550
    Initially, I found a blown fuse on the main AC input (ceramic 8A/250V). After replacement, the tv powers on with no backlight. The front LED flashes red and then turns to a very faint, barely visible blue on state. The backlights flash for a millisecond.
    Inspected caps on inverter boards and none are bulging. Caps on PS are non-bulging as well though there are some Samwa's there.
    In on-state, big filter caps at 371 VDC
    Left Inverter Connector
    24V = 25.0
    BRI = 1.7
    ON/OFF = 3.4
    PWM-DIM = 2.8
    ERROR = 0
    Right Inverter Connector
    24V = 24.9
    BRI = 1.7
    ON/OFF = 3.4
    Main board Connector
    BRI = 1.7
    PWRON = 2.8
    ERROR = 3.3 *****Problem here???***
    PWM-DIM = 2.8
    ON/OFF = 3.3
    ACD = 5.0
    5V = 5.1
    12V = 12.5
    16.5V = 16.7
    Symptom is similar to this thread https://www.badcaps.net/forum/showthread.php?t=51391
    I have touched up the joints at transformers T101, T102, MOSFET Q110, Q111, Caps C114, C125 with no improvement.
    I suspect ps board (error signal, blown fuse) or inverter boards.
    Re: LG 47LG50 No Backlight
    No blown fuse on either one of the inverter boards?
    • neilc6
      • Nov 2015
      • 1550
      There are 4 white fuses on each inverter board. They all tested ok.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Are there any brown scorch marks on the underside of the inverter board?
          How about the small black fuse F1 with '15' (0.75A) printed on top?
          Look at both boards for the black fuse.
          https://www.badcaps.net/forum/attach...3&d=1508868265
          • neilc6
            • Nov 2015
            • 1550
            Found the "15" black fuse on the master and it tests ok. Can't find one on the slave board.
            Back of the boards shows slight browning behing top and bottom transformers.
              Check the resistance of the High Voltage winding of all transformers to see if they are within 3% from each other, especially the one that has heat marking on the bottom side of the board.
              • neilc6
                • Nov 2015
                • 1550
                Using the test points and everything disconnected. Starting from top to bottom. In Kohms.
                Master - 5.72, 5.70, 5.71, 5.72, 5.71, 5.71, 5.72, 5.74, 5.72, 5.74
                Slave - 5.71, 5.70, 5.74, 5.72, 5.73, 5.71, 5.71, 5.74, 5.73, 5.73
                There are some black marks on connector #3 and #4 from the top on the slave board. There is continuity from the transformer pin to the connector pin. Pic attached.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  have you got a ccfl tube tester as maybe a tube failed
                  • neilc6
                    • Nov 2015
                    • 1550
                    Don't have a tube tester. If everthing points to a failed tube, then I would scrap the TV and sell the boards. Would a failed tube blow the main fuse??
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      sorry i didnt notice the blown mains fuse part, im not honestly sure maybe budm will have some more tests you can try
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        If the fuse on the power supply board had not blown then I would ignore the fact that the 8A fuse had blown in the mains lead. Perhaps it's not the original lead for the set.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          I would say you have found your fault. That white connector is in a terrible state and I suspect the connection plug and socket may also have burnt or badly corroded pins.
                          • neilc6
                            • Nov 2015
                            • 1550
                            The fuse that blew was on the PS board, right beside the AC input connector.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              The power supply has a ceramic 3.15A anti-surge fuse so where does 8A come into this?
                              • neilc6
                                • Nov 2015
                                • 1550
                                The top part of the plastic is black but the pin underneath looks fine and there is still continuity from the transformer output pin to the connector pin.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  But what do the plug pins looking like. You definitely have an issue with that connector.
                                  • neilc6
                                    • Nov 2015
                                    • 1550
                                    The socket pin looks ok. The plug has a scorch on top. Here are some more pics.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Personally I would cut the plug off and remove the socket from the pcb board and solder the pink and white wires directly to the circuit board.
                                      Are any of the other CCFL connectors / plugs showing similar signs?
                                      • neilc6
                                        • Nov 2015
                                        • 1550
                                        There are no other connectors with burn marks. I did pop everything back together and it is still the same. Slight backlight flicker when turning on. The fuse which was blown is F100 on the PS board rated at 8A/250V beside the AC input. Pic enclosed.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • kalemaroni
                                          Gigabyte Aero 15 GA-RP65W no backlight, blown MOSFET
                                          by kalemaroni
                                          The hinge broke on this laptop and caused damage to the LCD cable. Replacement screen and cable produced no backlight. Upon board inspection discovered blown MOSFET as shown in pic.
                                          The MOSFET and spec is P6402FMG/SOT23/950pF/64m https://datasheet4u.com/datasheet-pd...php?id=1093860
                                          I have a ton of old Macbook boards - are there any I can pull one from does anybody know?
                                          01-15-2025, 09:03 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • jimbofz
                                          lg 32LC46 backlight inverter board fault
                                          by jimbofz
                                          Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                          still no b/l this uses inverter type:1315 B1-16A,
                                          im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                          all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                          this allows protect to be temporary overridden.
                                          b/l now comes on
                                          but the left hand side of pic is gradually darker than the right side
                                          i have the cct for the tv
                                          but it does not have inverter cct.
                                          i opened it up to inspect the ccfl tubes
                                          and they dont have any...
                                          12-19-2021, 06:58 AM
