General question about duplicating voltage for test
  • johns1mj
    • May 2015
    • 242
    For the last little while I have been using a model train transformer to test led lights. I can control the voltage with the dial indicator on the transformer itself.
    The questions I pose are:
    Can I use the transformer to duplicate signal voltage?
    For instance back light on voltage?
    What are the forseen problems with this?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: General question about duplicating voltage for test
    You don't say what the voltage can be varied between or what the current is. Is it a DC controller?
      What kind of Backlight driver are we talking about? DC logic level control?
      BTW, when testing the LED, always use current limiter power supply to test the LED, LED string. If you are testing the bad LED string that may have one or two shorted out LEDs, so when you apply the Voltage, lots of current will flow due to shorted out LEDs which at that point you can damage the good LEDs.
      LED is a current device.
      • petehall347
        • Jan 2015
        • 4450
        one of these might get you close to what you want to do . UA723CN
        obviously needs some other parts .
        • johns1mj
          • May 2015
          • 242
          I am using a small dc controller lionel model 4660. It only goes up to 18 volts dc. I can control the output with its dial indicator.
          So if say I wanted to test a TV that was not getting the backlight signal on, assuming its a 5 volt signal, could I fake the signal with the controler and turn the back lights on? Would I risk shorting out other components introducing additional voltage into the circuits?
            Typical control signal for ON command is around 2.5~5VDC range, using 1.5V batteries in series will be more than enough to simulate the signal, But what ever you use you should put small resistor 470 ~1000 Ohms) in series to limit the current in case you connected it to the wrong pin.
            You need to control the current when testing LED so at least you should have DC Amp meter connected in series with your load so you can see how much current you are forcing into the load (LEDs).
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • bauto601
              KDM 480W PSU upgrade succes! (opinions?)
              by bauto601
              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
              A "nice" YoungYear unit? - Badcaps
              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
              12-26-2023, 03:05 PM
            • Fernon@Repair
              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
              by Fernon@Repair
              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
              VCCIO voltage ok
              VCCSA Voltage OK
              VCCPLL Voltage OK
              Ram Voltage ok
              RamVTT OK
              VPP 2.5 OK
              But No Core Voltage
              and i want to this vrm ic datasheet or pinout (ISL69269)
              anyone have this ic pinout voltages?...
              06-25-2025, 07:19 AM
            • C152Heavy
              Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
              by C152Heavy
              Summary for TL-DR readers:
              • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
              • Have obtained Samsung schematic & service documents - Can upload if helpful.
              • Have read ALL applicable threads
              • C1818 and CP820 replaced as low hanging fruit
              • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
              • VCC pin (18) of PFC...
              01-11-2023, 02:53 PM
