Samsung un60eh6003f horizontal lines
    replied
    Re: Samsung un60eh6003f horizontal lines
    You have to do testing to know for sure, I just had a couple bad caps and it presented just like a screwed up panel.
  • neilc6
    replied
    Vertical lines are panel faults and typically not repairable. Horizontal lines may be repairable if one side is good (confirmed with the bad side disconnected) using the tape cutoff method.
  • stefanie21
    replied
    Originally posted by jb.
    I've got this 60 inch Samsung here with some vertical lines in the screen... We moved it and the lines showed up, I have it open but all ribbon cables look good, if I unplug the video board ribbon cable and leave the backlight board on, the screen is lit and lines are gone... If I do the opposite, and shine a light on the screen I can see the video with the lines.. I added a picture, any ideas?
    did you ever solve this issue I have the exact same problem
  • tvsteve2
    replied
    These don't have a metal frame retaining the panel just outer bezel plastic holding the panel. usually moisture or cleaning fluids get under the bezel and mess up the connections, Last week I fixed a UN50EH6003f that had bars-- I found corrosion on one of the bottom drive strips. I scrubbed the strips with 91% Alcohol with a toothbrush while leaving the set on it's back with the bezel removed. after it dried I tested it running without the bezel and all was ok after 2 days on.
  • budwich
    replied
    it is likely a "panel fault" related to the bonded tabs. If the set has tabs along each side, you could try gently pressing on the tab associated with the line to see if things change (unlikely but never know). If it does, then possibly putting some pressure padding on it, may help. If not, then there are plenty of posts about this type of failure whereby people removing the tabs along the bad side... NOTE: this process is a "one way" method and can not be reversed so be sure to read, read, read before going down that route to make sure that you understand your problem and possibly alternatives (if any) as tv designs are different across various sets / types / makers.
  • mppx
    replied
    I have the same problem here see picture below. I replace the tcon board and still with the horizontal line. Any suggestion?
  • jb.
    replied
    Originally posted by heavymachines
    Really need to lay it flat on it's back so you can easily do this by yourself. Table is necessary or bench.
    yeah its flat, but without the plastic bezel, its pretty fragile...my pool table may get a second use lol
  • augiedoggy
    replied
    hahahahahah hows that? geeze lighten up man...and no i am not an lcd expert,(its actually an led) but as others have said, its pretty clear in the picture....had i put a movie on, it would be harder to see then it would in contrast to the black background....clearly you are too ornary to help, so please move along
    Its lcd.. leds are just used the backlighting... Its called an led tv as a marketing gimmick to make people think the cheaper crap is better when the reality is the led are the #1 failure on led sets... #1 failure on samsung sets in my experience is bad lcd panels. ironically the panels they sell to other oem tv brands dont seem to fail as much as the ones they use in their own sets?
  • heavymachines
    replied
    yeah im leaning toward the tab itself...i'll be back at it tonight...i really need another set of hands in here to hold the set while i test stuff....60 with no stand is tough with 1 person in a crowded garage lol..
  • jb.
    replied
    I can't find the exact video of the fix been few years buried on youtube somewhere however you can try to do this on every tab in the general area of the lines on screen and you can do this while tv is running. instructions on edited picture.
  • jb.
    replied
    Originally posted by Moreno83
    The tabs on the side are "COF" chips. Chip on film. They got the same kind of function as the ones on top.
    If the ones on top fail you usually get vertical lines , applying some pressure on the tabs make the lines go away ( temporary ).
    When the side tabs fail you get horizontal lines or no picture at all. What you need to do is apply pressure on the side tabs/panel , probably the one on top of the side tabs. Maybe bend the tabs with your finger. The bezel itself probably bends the area of the failed COF.
    Dont they get hot? It is something you need to figure out yourself....it is not measurable. If you remove the failed COF chip the picture will be ok and you can do it while the tv is on. It looks like a curtain that opens... very cool to watch
    thanks for the info! ill spend some more time tonight
  • jb.
    replied
    Originally posted by budwich
    your problem is that you need to isolate which side is the issue. At the bottom of the set, the edge boards are "interconnected" with clampable flex cables. Look along each side of the bottom and disconnect the flex cable clamp / cable at that point. Does the remaining picture clear up? Repeat the "test" on the opposite bottom "half".... any difference? Go from there.
    PS. you still didn't follow my suggestion of putting up a known test pattern. :-(
    yeah, i know, its tough without a stand,my garage isnt best area to be doing this either lol, i was lucky enough to get one of my kids to hold while i hooked up my laptop hahaha, being even still its only that one section in both pictures...the black screen, and the blue one from my laptop.
  • Moreno83
    replied
  • budwich
    replied
  • heavymachines
    replied
  • jb.
    replied
    ok don't think we're on same page, i'll see if i can find some examples online.
    In the middle picture is that oval you see in the tab what you are referring to?
  • heavymachines
    replied
  • jb.
    replied
    The shiny part not touching the glass loses the picture, with finger pressure no bezel, touching the glass brings back the picture, but doesn't affect the lines... I was hoping a simple shim work around, but it's puzzling for sure... On the inside of the bezel is what looks like metal tape all the way around, does that need to be in contact with tabs? Is it possible when pushing on bezel and the tape makes contact it fixes the issue?
  • heavymachines
    replied
    With the bezel off I can't change anything touching the tabs, only when the bezel is on when I give pressure near the tabs on both sides do the lines go away
    Weird indeed. So pushing on tabs at the glass edge does nothing, ok try this, you see the shiny mirror elongated ic's on those tabs? put something non conductive under those ic's like a rubber drawer bumper or wood even for this test and apply pressure carefully on the topside and see if it makes any difference sometimes those ic's will start to detach from the printed circuit. Pressure on ic like a sandwich.
  • jb.
    replied
    *double posted
  • x_orange90_x
    Samsung UN46C8000XFXZA vertical bars/horizontal lines
    by x_orange90_x
    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
    09-04-2023, 12:09 PM
  • arctor
    samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
    by arctor
    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
    04-26-2025, 05:22 AM
  • x_orange90_x
    Samsung UN46C8000XFXZA Horizontal lines
    by x_orange90_x
    I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
    I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
    07-15-2023, 05:06 AM
  • porfyriadhs
    Tv Samsung UE50TU Horizontal lines
    by porfyriadhs
    Hello to everyone. I tried the tape method to by pass the on and off problem for the Samsung tv I mentioned. But unfortunately lines starts to appear. My question is if someone knows how to fix the lines problem...
    05-16-2024, 02:44 AM
  • blaster_
    Samsung UE49MU6105K - boot loop, horizontal lines
    by blaster_
    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
    06-22-2022, 05:19 PM
