Samsung un60eh6003f horizontal lines
  • Moreno83
    replied
    Re: Samsung un60eh6003f horizontal lines
    I agree with Davi.P. It is not a clear picture of the fault. Just looking at that picture it is just a 1 vertical band that has gone wrong. So your having a panel problem. The gate drivers in the LCD panel have failed OR the side tab drivers failed.
    You need to figure out which side is causing the issue , left or right. As someone already said , rubb with your fingers on the side tabs...if you notice any difference on the tabs then remove all side tab drivers on that side.
    This is not a fix that will last forever. The side tabs on the other side will have to do double as much work.
  • Davi.p
    replied
    "That picture is pretty damn clear lol, red lines on left, blue on the right lol"
    Are you a lcd expert? What the hell you laugh? It's not simply "red on left blue on right.." ..Poor..
    "I remember few years ago on here many samsungs would have problems with top tab bonds due to wall mounting"
    Interesting, are you sure? Top side edge bonds or top edge side bonds?
  • heavymachines
    replied
    Side tabs drivers, they can go bad as well as the bond to the glass goes to hell. try rubbing your fingers along the edge of ribbon that is connected to the glass.
    Theoretically that would make perfect sense as the tabs get stiff with age and heat when you moved the tv apparently had enough twist or flex to break the bond to the glass. I remember few years ago on here many samsungs would have problems with top tab bonds due to wall mounting and flimsy internal brackets would cause the tabs go bad due to weight and sag and the sets that sat on their base would be unaffected of the same model.
    Also i could be wrong but i am certain top tab bonds caused vertical lines or double image slo mo blur with dark spots sometimes and side tabs can cause horizontal lines, making it somewhat tricky to tell bad panel or t-con. There are far more knowledgeable folks can put a second opinion on this.
  • jb.
    replied
    Ok, sorry for all the posts... It's not a twisting motion, but if I push the plastic frame on both sides on either side of the lines, it goes away, once I let go it comes back... There is a small tab that hangs off the screen on either side, but they don't connect to anything... What do they do,? And why does pressure fix my line problems? Thanks
  • jb.
    replied
    All tab bonds to screen look fine, pressure on any of them doesn't change the outcome, only when twisting the tv from close to the top, on the right side when facing the front do the lines go away... Weird
  • jb.
    replied
    Well, bit of an update, so if I grab the tv about 1/4 ways from the top on both sides and slightly twist the tv, the lines go away... Guess I'm taking more apart
  • jb.
    replied
    Originally posted by Moreno83
    It is the plastic cover that pulls on the panel OR on the mainboard. I have read that somewhere before....
    What happens when you push on the mainboard without the backcover?
    Watch out with any work on the panel itself though...once the ribbon cable ( Tabbonding ) is loose you can throw away the tv.
    Youtube for tabbonding repair. Norcal75 has a video about your issue... ( vertical and horizontal
    I'm leaning toward the plastic cover, pushing on mainboard doesn't change anything, only when I'm buttoning plastic up.. When I get back to the garage tonight I'll see what I can find
  • jb.
    replied
    Originally posted by Davi.p
    Photograph is too poor to understand!! Need some video source put in.
  • Davi.p
    replied
  • Moreno83
    replied
  • jb.
    replied
    So I've had some weird results which I don't like, working on this bugger is a pain with no help hahaha, so with everything apart, and metal plate over the board that runs to the skinny boards.. When I powered up the lines were gone... So I started to put the plastic back on so u could get the base on, and the lines are back... So if it's what you say, I have to figure a way to make the connection solid enough it can't move.
  • heavymachines
    replied
    Possible tab bond problem looks like to me. You tried reseating all the ribbons from the t-con right? as well as the connectors on the tab bond boards the connectors coming from the t-con the long skinny boards? if you twist the casing little bit does the lines come and go?
  • jb.
    started a topic Samsung un60eh6003f horizontal lines
    I've got this 60 inch Samsung here with some vertical lines in the screen... We moved it and the lines showed up, I have it open but all ribbon cables look good, if I unplug the video board ribbon cable and leave the backlight board on, the screen is lit and lines are gone... If I do the opposite, and shine a light on the screen I can see the video with the lines.. I added a picture, any ideas?
  • x_orange90_x
    Samsung UN46C8000XFXZA vertical bars/horizontal lines
    by x_orange90_x
    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
    09-04-2023, 12:09 PM
  • arctor
    samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
    by arctor
    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
    04-26-2025, 05:22 AM
  • x_orange90_x
    Samsung UN46C8000XFXZA Horizontal lines
    by x_orange90_x
    I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
    I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
    07-15-2023, 05:06 AM
  • porfyriadhs
    Tv Samsung UE50TU Horizontal lines
    by porfyriadhs
    Hello to everyone. I tried the tape method to by pass the on and off problem for the Samsung tv I mentioned. But unfortunately lines starts to appear. My question is if someone knows how to fix the lines problem...
    05-16-2024, 02:44 AM
  • blaster_
    Samsung UE49MU6105K - boot loop, horizontal lines
    by blaster_
    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
    06-22-2022, 05:19 PM
