LG 60PB5600 Turning Off
  • ShaunM
    • Oct 2017
    • 37
    LG 60pb5600 plasma TV turning off after sound is initiated on startup. I thought that this was the YSUS board so replaced it with a new one. Unfortunately, there was a popping noise and then the TV returned back to this original problem.
    After research, I figured that I should had also replaced the Y-Buffers at the same time as the YSUS. Ordered these three new boards from Sears but, once installed, the problem persists. No popping noises or anything though. It powers up when I push the button and once the sound comes on it immediately turns off? Any ideas?
    I should also add, the reason I originally thought that it was the YSUS is because the tv power will stay on if I disconnect the YSUS board connection from the ZSUS(The YSUS power is routed through the ZSUS on this TV).
  • heavymachines
    • Mar 2011
    • 1028
    Re: LG 60PB5600 Turning Off
    pics of entire back of set?
    • ShaunM
      • Oct 2017
      • 37
      https://imgur.com/a/KJBFi
      • ShaunM
        • Oct 2017
        • 37
        Was not sure I could directly upload the TV pics to this server. Here they are.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Try running the test pattern by removing the ribbon cable from the logic board (little board in the middle of the set) which goes to the mainboard and jumper the two pads marked EXT_AUTO_GEN on the logic board.
          • ShaunM
            • Oct 2017
            • 37
            I shall try. What is the best way to jumper those pads?
            • ShaunM
              • Oct 2017
              • 37
              So, do I just run a conductive wire from the 2 pads I marked with a red box in the attached picture?
              • heavymachines
                • Mar 2011
                • 1028
                You can hold a paper clip to it or soldier a jumper wire to it. Probably best to soldier it so you don't slip and short something out. Simply bridge connection.
                • heavymachines
                  • Mar 2011
                  • 1028
                  Yes.
                  • ShaunM
                    • Oct 2017
                    • 37
                    They are actually not pads but holes which a paper clip can fit through(as suggested). Just want to make sure I do this right because they are holes(not pads) and I can see the paper clip ends protruding through the back end of the board.
                    By the way, a HUGE thanks for the help. I have already bought 2 YSUS boards and Y-Buffers and do not want to purchase a power board if it is not needed.
                    • heavymachines
                      • Mar 2011
                      • 1028
                      paper clip will work if holes rather than soldier wire to pads.
                      • ShaunM
                        • Oct 2017
                        • 37
                        Same issue. Power comes on and tv turns off as soon as sound is initiated.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          You did remove the ribbon cable from the mainboard before doing the test?
                          • ShaunM
                            • Oct 2017
                            • 37
                            Yes, I did. I did keep the power cable from the power board connected to the main board though.
                            • heavymachines
                              • Mar 2011
                              • 1028
                              i believe power cables to main needs to be disconnected as well i have done this before on plasma and main is to be totally disconnected. The board you're jumping will generate test patterns.
                              • ShaunM
                                • Oct 2017
                                • 37
                                OK. Shall try that now.
                                • ShaunM
                                  • Oct 2017
                                  • 37
                                  With both the ribbon and power cable disconnected from the main board there is no power on at all. Even the red stanby light does not illuminate. You can hear the power board click when it is plugged in but the power button from both the remote and on the TV will not power on the TV. Whereas before, the TV will turn on until the sound starts and then immediately turns off.
                                  • heavymachines
                                    • Mar 2011
                                    • 1028
                                    it is expected remote won't work as the main is disconnected. with main disconnected and Auto Gen is jumped it will automatically turn itself on and generate pattern. This is how to rule out main issue or problem in y or z.
                                    • ShaunM
                                      • Oct 2017
                                      • 37
                                      Actually, upon looking at the back of the TV, it looks like the logic board actually received power from the main board and there is no direct power cable from the power board to the logic board.
                                      • heavymachines
                                        • Mar 2011
                                        • 1028
                                        clearly you still have a problem in y or z sustain, since you swapped out y and buffers i am leaning with you got bad replacement or the z is blowing things. You will need to do short test on igbts on y and buffers and the z. And before you blow your new parts you should hook up bulbs in series to prevent blowing your replacement parts.
                                        • Truncatedhose
                                          Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                          by Truncatedhose
                                          Greetings all!
                                          Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                          Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                          07-04-2018, 10:59 AM
                                        • Sparklingx
                                          HP 450 g1 keeps turning on even tho shutdown/sleep
                                          by Sparklingx
                                          HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                                          09-23-2024, 12:34 AM
                                        • khelane
                                          Satellite PRO A50-A Not turning on after turning off Windows
                                          by khelane
                                          Hello
                                          A device with specifications
                                          Toshiba Satellite PRO A50-A is here to replace the hard drive.
                                          The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                                          The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                                          04-20-2023, 06:28 AM
                                        • Rabit
                                          VX3276-2K-mhd-2 Random Turning off
                                          by Rabit
                                          Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                                          When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                                          This can be signs of bad capacitors causing overheating PSU ?
                                          06-17-2024, 09:30 AM
                                        • shakib200
                                          Dell latitude E7240 not turning on if adapter plugged in
                                          by shakib200
                                          Laptop turns on only on battery but if I plugged the adapter with battery, it is not turning on. After turning on the laptop using only battery (no adapter plug in), then plugging the adapter everything works fine also charging ok. Anyone have any clue what’s wrong?...
                                          03-31-2024, 12:55 PM
