Oscilloscope
  • 13Willie
    • Jan 2009
    Oscilloscope
    I own a 100MHz scope but do not know how to use it to troubleshoot TV circuits, for instance how to use the probe. Where should ground go for instance. If I connect the ground on the probe to the ground of the TV the power trip, the 220V AC. Can I use the scope from the powersupply side to the tube. Can I for instance use it alone without a sweep generator. Do anyone know where I can get information on troubleshooting with just a scope. Can someone please help.
  • i4004
    • Oct 2006
    • 2029
    Re: Oscilloscope
    ground
    https://www.badcaps.net/forum/showth...ound#post60210
    but practice on low voltage electronics first...tv has a great "bang" potential...heh..
    oh yeah, tv has 2 grounds..one is hot(220v ground) and other is not.
    when working on the hot side you must be especially carefull.
    infact i suggest you do use scope on hot side only if you can't really do anything else with conventional troubleshooting methods...
    how does it work?
    well, in electric diagrams(usually found in service manuals) you have oscillograms which you compare to what you see on the scope, for particular point you're measuring.
    if it's not the same, circuit is malfunctioning.
    problem is the following: you can't expect scope to show you exactly what element is faulty. for example it can happen one elelemnt failure is making the whole circuit have wrong waveform, and touching any point in it shows wrong waveform, and in such cases scope is not very usefull at all.
    ie you can't expect scope will magically isolate faulty element from the rest of the circuit.
    post your particular issue here and we'll probbaly be able to tell you some basics of troubleshooting you'll be able to use later...
    also, you can search the web for particular problems, but i think it's more fun if you reach conclucions yourself...
    again, be very, very carefull with tvs...do anything you can think of to increase safety...isolation transformers(read the thread i linked above), rubber gloves, rubber sole shoes... anything and everything...
    FIRST read this
    http://www.repairfaq.org/sam/safety.htm
    and THEN this
    http://www.repairfaq.org/sam/tvfaq.htm
    as repairing tv-set is such a piss-poor way to kill yourself...
    • 13Willie
      • Jan 2009
      Re: Oscilloscope
      Thanks very much, it is very helpful
      • Krankshaft
        • Jan 2007
        • 2328
        Re: Oscilloscope
        An isolation transformer is a MUST don't even think of using a scope on a transformerless TV without one.
        Here is what I use:
        http://www.mcmelectronics.com/product/72-6670
        Inexpensive comes in a nice box and worth its weight in gold.
        As for which ground to use you usually use the ground in reference to the circuit you are measuring. If you are checking a horizontal waveform from the IC for example you would use the ICs ground.
        Most scope probes have pretty short ground leads anyways so you'll need to clamp it nearby.
        Scopes have limited use for TV repair unless you are comparing waveforms from a service manual to isolate circuit faults.
        A high voltage probe is a nice addition too I only had to get zapped by a TVs HV once to realize the importance of this tool.
        I use it to slowly discharge the anode cap. I hate pops and sparks from the screwdriver method .
        Also fashion a shorting connector to attach between the CRT ground strap and the anode button since TVs just discharged can regain some of their HV (around 3,000-,5,000 volts when I measured) since they can store voltage deep in the glass.
        Not as bad as the original charge but startling enough for me not to want it to happen again.
        • Krankshaft
          • Jan 2007
          • 2328
          Re: Oscilloscope
          A wirewound resistor will discharge too solder wires onto the resistor and put alligator clips onto the ends alligator clip one end to a long flat head screwdriver and the other end to the ground strap.
          The screwdriver will keep you away from the HV with a high enough resistance resistor you can reduce the chance of sparking rather than just shorting to ground.
          • 13Willie
            • Jan 2009
            Re: Oscilloscope
            This is great stuff thanks alot.
            • irnard
              Micro SMD probe tip for Rigol oscilloscope ?
              by irnard
              Any advice where can I find micro SMD probe tip for Rigol oscilloscope ? Can't find anything online and factory one is just too fat to fit in some tight spaces on logic board. Thx
              02-09-2023, 09:22 AM
            • repair-it
              Need advice testing a samsung power supply board with scope
              by repair-it
              I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
              07-12-2025, 11:00 AM
            • SolomonMan
              Vintage BK Precision 1403 Oscilloscope....
              by SolomonMan
              All,
              Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
              Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
              I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
              12-03-2023, 10:39 PM
            • budwich
              ESD Diode on HDMI output of Yamaha a1050 RCVR
              by budwich
              I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
              I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
              09-11-2023, 12:21 PM
            • howardc64
              Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
              by howardc64
              Samsung have been using this style LED connector for few years now
              Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
              The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
              10-12-2025, 08:13 PM
