Samsung LN32A330J1D - Discolored Image
  • fire84rescue
    • Aug 2017
    • 29
    Hello, all. I have been going through several threads looking for information on discolored picture on my Samsung LN32A330J1D. The picture shows up in black, white, gray, and some orange/red. When the menu is selected it appears perfectly fine. I have gone into the "hidden menu" and attempted to adjust things as I have seen that fix similar problems on YouTube, with no success. I was leaning towards replacing the main board vs the T con at this point, so I have ordered a Main Board. I am hoping this fixes it, although I am told it could easily be the t con or the screen itself? Much of my research shows similar issues, although, many have distorted screens that are full of color and not the black, gray, and white as I have. Any suggestions/guidance would be greatly appreciated! My buddy has a home entertainment business and I am now collecting his throw aways since I just found out he doesn't repair any of them! His trash, my treasure!
    Re: Samsung LN32A330J1D - Discolored Image
    How about uploading the screen shot so we can see what the actual image looks like?
    • fire84rescue
      • Aug 2017
      • 29
      I will grab one once I get home for sure!
      • fire84rescue
        • Aug 2017
        • 29
        These are what I get when the tv is on...and I got more color than before
          That is GAMMA Voltages problem, you will need to test bunches of GAMMA Voltages on the T-CON board.
          • fire84rescue
            • Aug 2017
            • 29
            Ah ok. Thank you for the quick response! Wish I found this site before I ordered the main board! The menu shows up perfectly normal (I should've taken a picture). I will be ordering a t con replacement!
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Yes...a new T-CON Bd will fix your problem. This is a common fault with these sets.
              • fire84rescue
                • Aug 2017
                • 29
                Thank you for the help! Will be ordering asap!
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  you could try changing out the as15 chip yourself. if not, hold on to it and give it a try down the track.
                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  • augiedoggy
                    • Aug 2016
                    • 62
                    • united states
                    there is a small square chip called an AS15 or AS10 chip ( http://www.ebay.com/itm/1PCS-AS15-F-...8AAOSwNSxVDBlk ) when these fail you get this problem... I have replaced about a half dozen myself for this same issue... they have a fairly high failure rate and a heatsink will help them last longer.
                    • fire84rescue
                      • Aug 2017
                      • 29
                      Well I ended up ordering a new t con board of eBay. Everything turned out great. Thank you all for your input and gudiance!!!
                      • fire84rescue
                        • Aug 2017
                        • 29
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Thanks for the feedback....Good job!!
                          • fire84rescue
                            • Aug 2017
                            • 29
                            Absolutely! I wish every tv I came across was this simple and inexpensive to fix!
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              Yeah...I wish that, too.
                                Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                09-07-2024, 12:10 AM
                                09-07-2024, 05:50 AM
                              • shlomim412
                                samsung ua55es6800 - no image
                                by shlomim412
                                hi
                                having problem with samsung ua55es6800
                                tv had backlight on, sound working - responds to the remote control but no image.
                                check tcon board - had 12v in but no other voltages present.
                                when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                when leaving only left side connected - again no voltages and no image.
                                put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                kept trying to block less pins on the left ribbon cable...
                                05-15-2024, 05:00 AM
                                09-06-2024, 11:40 PM
