Vizio e55-c1, Plug in, standby light on, then fade off in 2 sec
  • momo2000
    • Oct 2017
    • 20
    I have a Vizio e55-c1 that is 23 months old. Today I went to power it on, and nothing. Upon further investigation, I notice that the “standby” light was not on. However, I notice that the USB drive that I had plugged into it (to show some pictures) is glowing (the USB drive is one of those that has a light that turns on when you plug into a USB port). Strange. I unplug the TV and plug it back in and here is what happens: The “standby” light comes on, for about 2 seconds, and then fades out and goes off over the following 2 seconds. I tried this repeatedly leaving it unplugged anywhere from 1 min to 3 hours and the result is the same . . . standby light on for 2 seconds, and then it fades out. I have tried to power the TV on at various times, but of course nothing happens.
    This just “feels” like a power supply issue, but not really sure. I do a little with electronics (I know the basic components and can test a few things) and have a soldering iron and multi-meter. I'm not in a big hurry, and think it might be fun project for me. And I just hate to throw this in the trash ;0
    I see the “LCD TV and Monitor basic troubleshooting guides” that BUDM has posted. I have not tried any of the tests yet, but it looks like section #1. “The power supply module” would be a very good place to start.
    QUESTION: Does the standby light coming on (for 2 seconds) when I plug it in, then fading to off (in the next 2 seconds) give a clue to move in any other direction, or point to the power supply even more strongly? Just looking for the right steps for this curious amateur to start. Thanks!
  • CapLeaker
    Leaking Member
    • 8214
    Re: Vizio e55-c1, Plug in, standby light on, then fade off in 2 sec
    Pretty easy. With the back off the TV, plug the TV in, while measuring the STBY voltage with you DMM set to DC V at the PSU. See if it disappears. We are going to need some high resolution, straight shot pictures of your PSU and main board.
    • momo2000
      • Oct 2017
      • 20
      Thanks, CapLeaker. Happy to be your 3,000th post!!!!! OK, thanks for the advice/direction. I'll get that done over the next 5-10 days (I had to leave town) and will report back my results here. Thanks so much.
      • SLK001
        • May 2014
        • 264
        The "standby" light is supposed to act that way. Use a flashlight to see if you have a picture, but no backlight. If you have a picture, see this post: https://www.badcaps.net/forum/showthread.php?t=53880
        It is for an earlier model of this TV, but it might still be applicable.
        • momo2000
          • Oct 2017
          • 20
          You say the standby light is supposed to act that way. Are you sure? To be clear, I am just plugging in the TV, AND THEN NOT TOUCHING THE TV OR REMOTE, and then the standby light fades off. As I recall it stays on when the TV is powered off (but plugged in), and then turns off when the TV is powered on. Did we have a misunderstanding, or am I incorrect?
          • SLK001
            • May 2014
            • 264
            My earlier model of this TV turns on the standby light when I turn it on, then slowly fades to off (while the TV is booting up). It stays off until you power the set off, then it comes on while TV is shutting down (about 1 second). A lot of these Vizios operate like this.
            • maxvalutech
              • 804
              • australia
              With a problem lurking in the background these type sets can turn themselves on as soon as power connected. I have a similar set that self starts when switched on at power point. I can turn it off normally but if power still available exactly 5 minutes later it self starts again. Possible eeprom problem for mine but may well be a backlight problem for yours.
              • momo2000
                • Oct 2017
                • 20
                UPDATE=>
                #1. I took it off the wall and brought it to an area where I could work on it. Plugged it in before I start taking it apart . . . It works perfectly! So I did not do any meter readings. I'm guessing it will tough to fix the problem if it is intermittent. Any suggestions? I'm guessing I just keep turning it on/off once or twice a day and see if I can get it to fail again? Other ideas? I've read bits/pieces about EPROM issues. Any chance it was just "mucked up" and a few days being unplugged and then repowered helped? Just trying to figure out if this was a one-off, or an intermittent problem.
                #2. I was WRONG on the standby light. Now that it is working, the standby light operates just like SLK001 said it did earlier in this thread. Sorry I doubted you SLK001 ☹
                #3. As requested, I have attached photos of the PS, Main, and T-Con Boards.
                Any ideas on what do do/check next?
                • SLK001
                  • May 2014
                  • 264
                  Check that all your cables are properly seated. Also, make sure all the screws to ground are tight to the chassis.
                  Looks like the right cable from the TCON to the panel is not all the way in. Also pull the power supply and look for fractured solder joints at the connector.
                  • momo2000
                    • Oct 2017
                    • 20
                    Finally had time to do this tonight. I did seat/reseat all cables and checked ground screws. Also pulled the PS to look for fractured solder joints (I have seen these before so believe I would recognize), but I found none. TV still working fine. Pretty hard to fix something if it won't fail so guess I'm going to button it up and let it run and turn it off on when I can, and see if it will fail. Thanks so much to all of you for your suggestions/advice. Really appreciate it. If it fails, I'll repost, but other than that, I think this thread is CLOSED.
                    • SLK001
                      • May 2014
                      • 264
                      ... I think this thread is CLOSED.
                      Naw, that's not how this works. This thread will keep getting added to as others have the same problem and seek the wisdom of the crowd.
                      • momo2000
                        • Oct 2017
                        • 20
                        OK, thanks, SLK001 !!!
                        • x_orange90_x
                          Vizio E550i-A0 no power, no standby light
                          by x_orange90_x
                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                          11-20-2023, 09:49 AM
                        • p-top
                          Vizio, E60u-D3, no standby light, no ps_on
                          by p-top
                          Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                          main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                          PS voltages
                          1 VSNS -2mV
                          2-5 LED-OUT -2mV
                          6-10 GND -2mV
                          11 +16VS 16.29V
                          12 AC-DET 3.929V
                          13PS-ON -3mV
                          14 +16VS 16.29V
                          15 +16VS 16.29V...
                          11-27-2023, 10:44 AM
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • bunting78
                          Vizio D650i-B2 wont trun on and no standby light
                          by bunting78
                          First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
                          09-23-2021, 08:53 AM
                        • fharris1977
                          Vizio D50u-D1 Dead Set No Standby
                          by fharris1977
                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                          12-28-2023, 10:25 AM
