Vizio E600i-b3 vertical box left side of screen
  • Smp4488
    • Sep 2017
    • 5
    I got a Vizio E600i-b3 from work for free because it was broken. The colors were off and I figured I could fix it. When I got it home, to my surprise, it worked fine. After a week the color issue returned. I googled around for solutions and found it could be the tcon board. I ordered one from shopjimmy.com. While I waited I went ahead and took the TV apart to get ready for the new board. I read about making sure the cables were seated correctly, but none of that helped. At one point I didn't realize the tv was plugged in while I was removing the ribbon cables on the tcon board. There is now a vertical box on the left side of the TV. The new tcon did fix the color issue, but I get the vertical box with either of the tcon board installed. My fear is that I fried part of the panel while messing with the ribbon cables. What are your alls thoughts? Pictures below.
    I was thinking of ordering the full repair kit from shopjimmmy.com which includes the power, control, and tcon boards. I wanted to see what your alls thought were before I spent $60 on it.
    https://i.imgur.com/buQC173.jpg
    https://i.imgur.com/dU3F9dV.jpg
    After unplugging the two ribbon cables on the tcon board going to the panel the screen in now all white. This makes me think the panel isn't bad, but I have no idea. With the LVDS cable unplugged the screen is backlit and all black
    Do you all think the panel is bad?
    https://imgur.com/gallery/Rn5IO(tcon disconnected from panel)
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vizio E600i-b3 vertical box left side of screen
    Check the tcon ribbon cables at each end. The gold contacts are very easily damaged.
    • Smp4488
      • Sep 2017
      • 5
      Thanks for the quick reply dick_barton. I just tried switching the left and right ribbon cables and the picture shows the same issue.
      • R_J
        • Jun 2012
        • 9625
        If this panel has the t-con at the bottom of the screen, I would check the small board that connects the t-con to the panel for any water/cleaning fluid damage in that area of the screen. Cleaning liguid has a tendancy to run down the screen and corrode either the connection to the panel or the small thin board itself, might be worth a look
        • Smp4488
          • Sep 2017
          • 5
          Thanks for the response R_J. It is the model where the panel connects below the tcon. I haven't been able to find out any information on what the board is called and I can't seem to be able to remove it. Do you know what it's called? I have posted pictures of what it looks like.
          https://imgur.com/gallery/8RTy7
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            You have to remove the bezel around the set to get at that board.
            • R_J
              • Jun 2012
              • 9625
              The board is part of the lcd panel, so I don't think you wil find a specific name for it.
              The board can't be disconnected from the lcd panel, the ribbon cables are bonded from the board to the panel.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Although the board cannot be removed as RJ stated, you can check it for water damage which unfortunately does occur with sets having the Tcon's located at the bottom of the set and also check that there are no overheated COF chips. (the little IC glued to the ribbon between the thin pcb and the panel)
                • Smp4488
                  • Sep 2017
                  • 5
                  Thank you all for the replies and suggestions. The panel was working fine until I started moving the tcon ribbon cables while the TV was still plugged in so I don't think it is water damage. My suspicion is that I fried the panel and i'm looking for confirmation or if there is anything I can replace to try and fix it.
                  I'm kicking myself now because if I would have just waited for the new tcon instead of messing with things I would have a working TV right now.
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • Pinky Deepak
                    Vizio M60-C3 Left Edge problem
                    by Pinky Deepak
                    I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                    Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                    09-27-2024, 05:11 PM
                  • x_orange90_x
                    Vizio V585-J01 dancing lines and image doubling
                    by x_orange90_x
                    I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                    Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                    Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                    I swapped...
                    06-12-2024, 07:57 AM
