LG 26LD350-ZA repair, PSU LGP26-10P, 24V and 12V problem
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This LG 26LD350-ZA TV suffered from premature oxidation due to proximity to an air conditioner indoor unit output. It tries to start, red LED blinking, then solid blue and after a few seconds it goes back to red.
    Visual inspecton: greenish oxidation in PSU axial components. Ceramic caps C502 and C504 legs are close to break. Same for all 3 LiteON LTV-817-BN photocouplers, with very rusty top legs. Solder side with some oxidation in large tracks, but nothing cut or severely affected.
    I brush off most evident oxidation from circuit and components and replace mentioned ceramic caps and photocouplers. No changes. Then I read voltages: they're all present, but "24V" are 28V and "12V" are 14V. Inverter ERROR line is at 3.3V (=error). Panel specs (AUO T260XW04 V.3) show that above 26V is an abnormal condition. Inverter fuse is OK.
    I disconnect Inverter from PSU and short ERROR line with GND. TV turns on and sound can be heard. There's something wrong with 24V and 12V, and both are driven from IC100 (ST half-bridge switcher L6599D) and both have common feedback/regulation.
    Check secondary side feedback circuit and discover that R255 (10kΩ 1%) is open! It's directly connecting 24V to a photocoupler (I can check schematic from very similar PSU LGP32-09P, schematic posted somewhere in this forum). Replace it and it's working, with normal values at 24V and 12V lines.
  • x_orange90_x
    by x_orange90_x
    01-29-2025, 09:24 PM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
  • valvashon
    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
    by valvashon
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
    01-04-2024, 01:44 PM
  • eccerr0r
    A modified sine wave inverter + a grid tie inverter?
    by eccerr0r
    If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
    Next thing is trying to charge the batteries using solar power, but that's another issue ...
    08-31-2023, 09:14 PM
  • caseyjay_48
    Sony KDL-46BX450 Inverter Troubleshoot Logic
    by caseyjay_48
    I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
    I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
    09-23-2022, 08:08 PM
