LG 26LD350-ZA repair, PSU LGP26-10P, 24V and 12V problem
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This LG 26LD350-ZA TV suffered from premature oxidation due to proximity to an air conditioner indoor unit output. It tries to start, red LED blinking, then solid blue and after a few seconds it goes back to red.
    Visual inspecton: greenish oxidation in PSU axial components. Ceramic caps C502 and C504 legs are close to break. Same for all 3 LiteON LTV-817-BN photocouplers, with very rusty top legs. Solder side with some oxidation in large tracks, but nothing cut or severely affected.
    I brush off most evident oxidation from circuit and components and replace mentioned ceramic caps and photocouplers. No changes. Then I read voltages: they're all present, but "24V" are 28V and "12V" are 14V. Inverter ERROR line is at 3.3V (=error). Panel specs (AUO T260XW04 V.3) show that above 26V is an abnormal condition. Inverter fuse is OK.
    I disconnect Inverter from PSU and short ERROR line with GND. TV turns on and sound can be heard. There's something wrong with 24V and 12V, and both are driven from IC100 (ST half-bridge switcher L6599D) and both have common feedback/regulation.
    Check secondary side feedback circuit and discover that R255 (10kΩ 1%) is open! It's directly connecting 24V to a photocoupler (I can check schematic from very similar PSU LGP32-09P, schematic posted somewhere in this forum). Replace it and it's working, with normal values at 24V and 12V lines.
  • eccerr0r
    inverter H tree driver imbalance in an AC inverter
    by eccerr0r
    My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
    11-16-2025, 12:34 PM
  • x_orange90_x
    Vizio E55-E1 bad backlights or bad inverter?
    by x_orange90_x
    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
    I don't know how exactly to test the inverter itself. Is it...
    01-29-2025, 09:24 PM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
  • valvashon
    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
    by valvashon
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
    01-04-2024, 01:44 PM
  • eccerr0r
    A modified sine wave inverter + a grid tie inverter?
    by eccerr0r
    If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
    Next thing is trying to charge the batteries using solar power, but that's another issue ...
    08-31-2023, 09:14 PM
